Topic: ProtoShield using "Household" Items for < $5US (Read 5025 times) previous topic - next topic
br3ttb
Hi everyone,
I just posted an Instructable detailing how to make a ProtoShield that accesses all the pins (yes, even the offset ones)  using stuff that's cheap and widely available.  have fun making tons of cheap shields for all your projects!
http://www.instructables.com/id/Arduino_ProtoShield_from_quotHouseholdquot_Ite/
halley
#1
Dec 29, 2008, 08:08 pm Last Edit: Dec 29, 2008, 08:11 pm by halley Reason: 1
This turns out better than I would have expected, I like the way you pot the soldering job in epoxy.  However, have you taken an ohm-meter to your connections?  I was under the impression that the J-B Weld product mixes metal in with the epoxy to increase the strength.  The company does not list electrical properties on the J-B Kwik product information page.  http://www.jbweld.net/products/jbkwik.php  The plain J-B Weld info page says to "use it as an electrical insulator," so maybe my impressions were wrong.
br3ttb
I did a basic continuity test after everything was done, but that was more to test that I hadn't botched the soldering job.  (I really should have done that BEFORE epoxying, but oh well, at least now I can answer your question)
if there's any leakage it's minimal.  I'm with you that that could definitely impact things, especially on the analogread side.  if I get reports back that there's problems of this nature I'll find a more electrically inert epoxy (even regular glue might do,) and update the instructable accordingly.
retrolefty
I think the idea to be able to utilize standard 0.1" spacing perf board for homebrewed shields is a good one, but the implementation leaves a little to be desired.
There is no good reason to use wire and epoxy for all four header connectors, just use the wire/glue on the one non-aligned connector. Use the following to connect the other three headers:
http://www.sparkfun.com/commerce/images/products/00116-02-L.jpg
Doesn't that make a lot more sense and less mess to deal with  ;)
Lefty
br3ttb
yeah, someone posted something similar on the instuctables site.  that approch makes sense to me.  go for it.
just for reference, I'll paste my instructables reply to "why not just use male headers?"
"a few reasons:
   * this board only has metal on the bottom, so soldering a standard header would be tough at best. I suppose you could flip the board over, but...
   * there's still that offset female header to deal with. a standard male header won't work because it's rigid and straight, and the holes don't line up.
   * I like the idea of all the raw materials being readily available. some huge percentage of Americans (90%+ I think) live within 5 miles of a Radio Shack. male headers can be harder to come by. (Note: I realize that not only Americans are interested in this instructable, I just live here, and don't have electronic store distribution information from other countries ;) )
you do make a good point though. in one of my earlier attempts I used a flipped board, male connectors where they'd work, and wire for the 8 pins where they wouldn't. that definitely sped things up, but I figured I was already using the wire, why not go all the way."
retrolefty
""a few reasons:
  * I like the idea of all the raw materials being readily available. some huge percentage of Americans (90%+ I think) live within 5 miles of a Radio Shack. male headers can be harder to come by. (Note: I realize that not only Americans are interested in this instructable, I just live here, and "
I didn't mean to imply that your way was wrong, just that a lot of labor and time might be saved using premade strip headers.
And anyone using an Arduino should buy a lot of strip headers for hooking up connectors, sensors, etc as just sticking round wires into the Arduino hearders does not make a very mechanically strong connection. Just a suggestion.
Oh, by the way I should caution that using strip headers on SINGLED-SIDED perf-board can be somewhat unreliable over time unless they too have some epoxy glue support added.
Inserting and uninserting the board repeatably from the Arduino will eventually loosen the bonding between the solder pads and the perf-board causing the connecting PCB strip to flex and possibly break. After having seen that on one I build to plug into a solderless breadoard, I now try only to use perf-board stock that uses plated through holes. It does cost more and harder to source, but I would rather build it only once.  ;)
Lefty
Patzak
I make my shields with plated through boards and use male headers.  The only pins on the shield are the ones used.  Male headers are quite inexpensive when purchased in quantity.  I just tried a board with epoxy on the bottom (epoxy from Harbor Freight less than $1 USD).  I have not found any difference from the epoxy free boards, yet.  Scoping adjacent pins showed no leakage.
br3ttb
I give Lefty the credit for getting my wheels turning...
no more epoxy.  it's gone.  I came up with a much better method (a whole day after posting the other one! not embarrassing at all).  instead of using male headers and wire, how about using ALL male headers.  just modify one of them to handle the offset.
http://www.instructables.com/id/Embarassingly_Easy_Arduino_ProtoShield/
follower
Yeah, bending the header pins works as "well" as such a work-around can expect to--and definitely relatively straight-forward to do.
In my experience, at least.
--Phil.
nkcelectronics
UziMonkey
@nkcelectronics:  Do you have better shots of that shield?
Oracle
I don't really get the bend both ends and melt it.  I'm thinking it would be better to bend each pin out a bit and then back down a short distance away.
br3ttb
that's an interesting thought.  I'm kind of embarrassed that I never even considered it.  you could even hold the pin with a pair of needlenose and do both bends at once, with kind of a move-to-the-side while pushing in.
I think I'm going to stick with my method for one reason though.  it looks fantastic.  with the bend hidden within the plastic it looks exactly like a regular header when installed.  I've shown people the board from the instructable; inserting and removing it.  the reaction is pretty consistent:  "yeah, ok, so what?... hey wait!  how did you do that?!"  followed by 30 seconds of inspection before they figure it out.
at any rate, from an ease-of-implementation standpoint I think you've got me beat.  I'd be interested to know how it works for you!
/me
Oracle
Okay...I bent a header the way I described, it fits perfectly...but when I went to solder it I realized I'd have to solder on the component side, which I can't do on cheap single-sided proto board.
Looking at your instructable, the pins are on the "wrong" side because I'll have to mount all my components to the solder-side and, again, I won't have any pads to solder to.
If I buy a high-quality double-sides plated through perf board, I may as well buy some of ladyada's protoshields.  It would be about the same price.
br3ttb
that is a fantastic point.  I've come up with a solution and tested it.  no time for pictures.  will follow up later today or tomorrow with an update to the instructable.
here's the basics:
-locate the 8 holes that will be occupied by the header
-cover them with solder
-use your iron to re-open the holes, resulting in 8 holes rimmed with solder
-put the header in place
-for each of the 8 holes, touch the board as close as possible to the header.  the solder rim will melt around the pin, making the desired bond
Brett
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
