Topic: Communication With Java (Read 918 times) previous topic - next topic
bsouid
Hi I have a Duemilanove and an Uno. I am using two boards because I need 8 PWM pins (using 4 from each).
All I need to do is send 4 numbers to the Arduino and use those 4 values to set the PWM output on 4 pins.
I am having trouble sending serial communication to/from my Uno to a computer (the Duemilanove works great) and really need to get this solved today (thanks for the help)
I connect the Duemilanove to my computer and it shows up as device /dev/ttyUSB0 and I connect the Uno to my computer and it shows up as device /dev/ttyACM0.
If I send serial communication from the Arduino IDE the UNO communicates fine. If I try sending from my computer it fails to find the device.
I have debugged it and found that the method
     Enumeration portEnum = CommPortIdentifier.getPortIdentifiers();
does not return /dev/ttyACM0 as a device (it does return /dev/ttyUSB0 which is why the Duemilanove works)
Any way to get around this? I am kinda desperate on this.
This is my Arduino code (both boards have same code)
Code: [Select]
// Communication with Antenna
int inByte = 0;         // Incoming serial byte
int outputPin1 = 11;
int outputPin2 = 10;
int outputPin3 = 9;
int outputPin4 = 6;
void setup()  {
  // Open a serial connection to the computer
  // Set the PWM ports to output
  pinMode(outputPin1,OUTPUT);
  pinMode(outputPin2,OUTPUT);
  pinMode(outputPin3,OUTPUT);
  pinMode(outputPin4,OUTPUT);
void loop()  {
  if (Serial.available() > 0) {
    Serial.println("Recieved Message");
    // Get incoming byte, Echo the number back to
    // the computer then write voltage to PWN pin
    inByte = Serial.read();
    Serial.println(inByte);
    analogWrite(outputPin1, inByte);
    delay(20);
    analogWrite(outputPin2, inByte);
    delay(20);
    analogWrite(outputPin3, inByte);
    delay(20);
    analogWrite(outputPin4, inByte);
    delay(20);
This is my Java code:
Code: [Select]
package cessararduino;
import gnu.io.NoSuchPortException;
import java.io.InputStream;
import java.io.OutputStream;
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import gnu.io.SerialPortEvent;
import gnu.io.SerialPortEventListener;
import java.util.Enumeration;
import java.util.logging.Level;
import java.util.logging.Logger;
public class SerialTest implements SerialPortEventListener {
        SerialPort serialPort_09;
        SerialPort serialPort_10;
        /** The port we're normally going to use. */
private static final String PORT_NAMES_09[] = {
"/dev/tty.usbserial-A9007UX1", // Mac OS X
"/dev/ttyUSB0", // Linux
"COM3", // Windows
        private static final String PORT_NAMES_10[] = {
"/dev/ttyACM0", // Linux
                        "/dev/ttyACM1", // Linux
                        "/dev/ttyUSB1", // Linux
"COM3", // Windows
/** Buffered input stream from the port */
private InputStream input;
/** The output stream to the port */
private OutputStream output;
/** Milliseconds to block while waiting for port open */
private static final int TIME_OUT = 2000;
/** Default bits per second for COM port. */
private static final int DATA_RATE = 9600;
        public void initialize() {
            System.out.println("Initializing the object");
public void initialize_09() {
CommPortIdentifier portId_09 = null;
        try {
            CommPortIdentifier.getPortIdentifier("/dev/ttyACM0");
            // iterate through, looking for the port
        } catch (NoSuchPortException ex) {
            Logger.getLogger(SerialTest.class.getName()).log(Level.SEVERE, null, ex);
while (portEnum.hasMoreElements()) {
CommPortIdentifier currPortId = (CommPortIdentifier) portEnum.nextElement();
                        System.out.println(currPortId.getName());
for (String portName : PORT_NAMES_09) {
if (currPortId.getName().equals(portName)) {
portId_09 = currPortId;
if (portId_09 == null) {
System.out.println("Could not find COM port.");
return;
try {
// open serial port, and use class name for the appName.
serialPort_09 = (SerialPort) portId_09.open(this.getClass().getName(),
TIME_OUT);
// set port parameters
serialPort_09.setSerialPortParams(DATA_RATE,
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
// open the streams
input = serialPort_09.getInputStream();
output = serialPort_09.getOutputStream();
// add event listeners
serialPort_09.addEventListener(this);
serialPort_09.notifyOnDataAvailable(true);
} catch (Exception e) {
System.err.println(e.toString());
public void initialize_10() {
CommPortIdentifier portId = null;
for (String portName : PORT_NAMES_10) {
portId = currPortId;
if (portId == null) {
return;
try {
serialPort_10 = (SerialPort) portId.open(this.getClass().getName(),
TIME_OUT);
serialPort_10.setSerialPortParams(DATA_RATE,
// open the streams
input = serialPort_10.getInputStream();
output = serialPort_10.getOutputStream();
serialPort_10.addEventListener(this);
serialPort_10.notifyOnDataAvailable(true);
* This should be called when you stop using the port.
* This will prevent port locking on platforms like Linux.
public synchronized void close() {
            if (serialPort_10 != null) {
serialPort_09.removeEventListener();
serialPort_09.close();
serialPort_10.removeEventListener();
serialPort_10.close();
* Handle an event on the serial port. Read the data and print it.
public synchronized void serialEvent(SerialPortEvent oEvent) {
if (oEvent.getEventType() == SerialPortEvent.DATA_AVAILABLE) {
try {
int available = input.available();
byte chunk[] = new byte[available];
input.read(chunk, 0, available);
// Displayed results are codepage dependent
System.out.print(new String(chunk));
// Ignore all the other eventTypes, but you should consider the other ones.
public static void main(String[] args) throws Exception {
            SerialTest serialPort_09 = new SerialTest();
            SerialTest serialPort_10 = new SerialTest();
            try{
serialPort_09.initialize_09();
                //serialPort_10.initialize_10();
                // Wait 2 seconds for serial port to settle
                Thread.sleep(2000);
                System.out.println("Started");
                // Send 6 numbers to the arduino board
                serialPort_09.output.write(0);   // Output1
                serialPort_09.output.write(64);  // Output2
                serialPort_09.output.write(128); // Output3
                serialPort_09.output.write(255); // Output4
                serialPort_10.output.write(0);   // Output1
                serialPort_10.output.write(64);  // Output2
                serialPort_10.output.write(128); // Output3
                serialPort_10.output.write(255); // Output4
            catch (Exception e)
