Topic: variables (Read 1 time) previous topic - next topic
2632
I am having a problem getting variables to work as I intend.
I have declaring the variable a few different ways but can't get working results.
Here is what I have:
String LCD_line2 = "                ";             // Message for LCD line 2
// change it to this
  LCD_line2 = "! OVER VOLTAGE !";
// print 2nd line of LCD
 lcd.setCursor(0,1);
 lcd.print(LCD_line2);
I am getting a number on the screen, 8225?
frank26080115
did you check if the .print function accepts "String" types? Maybe it only accepts char* and not String.
2632
did not know that was an option...
2632
There must be a way to print a variable to the LCD?   :smiley-eek:
johnwasser
Try this:
  lcd.setCursor(0,1);
  lcd.print(LCD_line2.toCharArray());
The '.toCharArray()' method returns the pointer to the internal buffer as a 'char *'.
The '.getBytes()' method is similar but returns 'unsigned char *' instead.
2632
That will not compile;
error: no matching function for call to 'String::toCharArray()'
What is an unsigned char?
johnwasser
Great.  The reference manual installed with Arduino 22 fails to mention that there are two arguments required.  See: http://arduino.cc/en/Reference/StringToCharArray
char buff[17];
  lcd.setCursor(0,1);
  lcd.print(LCD_line2.toCharArray(buff,sizeof buff));
2632
#7
Aug 08, 2011, 04:24 am Last Edit: Aug 08, 2011, 04:52 am by 2660 Reason: 1
Ok I got it working but i don't know exactly why.
I think it was going from 'value' to "value"   :smiley-surprise:
lcd.print(lcd_line2); is now working
