Topic: DS1307 adrress register help ! (Read 10635 times) previous topic - next topic
halejandro
Okay, what might be happening is that the recieved data is coming in as characters, so if you sent F049,
it would show up as
'F', '0', '4', '9'.
So you can test for 'F' no problem,
you can do the switch:case using '0', '1', '2', no problem.
The '2' and '7' you need to put back into 0x27 to send to the DS1307.
3rdchar = 3drchar-0x30; // or -48
4thchar - 4thchar-0x30; // or -49
then
databyte_to_write = (3rdchar<<4 + 4thchar); // should result in 0x27
3rdchar gets shifted left 4 bits, so 0x02 becomes 0x20, and then add 7.
Hello, Okay I´m testing this part but only works with numebers 0-9, and when I send 'F' shows 16, acording to the table 'F' is 46! In the last part why do I have to add 7?
CrossRoads
'F' was for the case where you had ascii characters coming in instead of HEX bytes.
If you are gettting 0x0F, that is decimal 16. No further processing needed.
if (commandByte == 0x0F)  will work the same as
if (commandByte == 16)
0x27 was just an example to show how to put two nibbles together to make up a byte.
So if you had '2' and '7' come in, you would do the math on them to get
0x02
0x07
so shift 2 left 4 bits:
highnibble = 0x02<<4; // hows its 0x20
add the low nibble 0x07, and you have 0x27, which will make the DS1307 happy when you send a seconds or minutes command.
But if you have HEX data coming in, like F027, then you can just pass along the 0x27 as data.
halejandro
How does your board knows when you type for example f145, f1 register and 45 data? Can you explain me that comunication part ????
CrossRoads
Its in the code halejandro:
RTC_write_command = incomingCommand & 0xF0;  // mask off high byte  <<< Make the byte equal to 0xsomething0
  if (RTC_write_command == 0xF0){  // check for Write command  <<< if the something was F, then continue
    RTC_register = incomingCommand & 0x0F;  // mask off low byte  <<< Now make the byte equal to 0x0something
    incomingCommand = 0;   <<< reset the byte so we don't re-execute before a new command is read
    new_data = incomingData;    <<< read  the data byte to send to the DS1307
    Serial1.print (" Sending a command ");
    switch (RTC_register){
    case 0: // write seconds   <<< now if the 0x0something == 0, do this case, or 1, or 2, etc.
halejandro
I´m using the modulo operator with the ASCII chars, everything is fine with numbers but I don´t see the letters, to put together two nibbles, I´m doing the same you explained to me but when I introduce '1','0' the serial monitor shows 1,0 instead 10, what am I doing wrong ?
CrossRoads
halejandro
#36
Aug 13, 2011, 03:41 am Last Edit: Aug 13, 2011, 06:39 am by halejandro Reason: 1
Code: [Select]
byte incomingCommand = 0;
byte incomingData = 0;
byte receivedByte = 0;
byte Option_to_write = 0;
void setup(){
 Serial.flush();
void loop(){
 if (Serial.available()>2){
   incomingCommand = Serial.read();
   incomingData = Serial.read();
   receivedByte = incomingCommand%16;
   incomingData = receivedByte%16;
   Option_to_write = (incomingCommand << 4) + incomingData;
   Serial.print("Command:");
   Serial.print(receivedByte, HEX);
   Serial.print(" Data:");
   Serial.print(incomingData, HEX);
   Serial.print(" Option to write:");
   Serial.println(Option_to_write, HEX);
CrossRoads
halejandro,
This code works with the Arduino's IDE Serial Monitor at 57,600
Please review & understand the change  I made, I mostly left the old commands there so you can see the changes.
Commands are given as
F004, sets seconds to 04
F110, sets minutes to 10
F209, sets hours to 09
etc for F3, F4, F5, F6,F7
Code: [Select]
Test of RTC DS1307 via I2C.
Counts
Seconds,
Minutes,
Hours,
Date of the Month,
Month,
Day of the week, and
Year with Leap-Year
56 bytes battery backed RAM
Square Wave Output, can connect to INT2/D6 or PD7
Modified to Run thru IDE Serial port
#include <Wire.h>
//variables
byte seconds_address = 0x00;
byte seconds; // bit 7 = Clock Halt, Enabled = 0, Halt = 1
// bits 6-5-3 = tens of seconds 0-6,  bits 3-2-1-0 = units of seconds, 0-9
byte minutes_address = 0x01;
byte minutes;  // bits 6-5-4 = tens of minutes, bits 3-2-1-0 = units of minutes
byte hours_address = 0x02;
byte hours;  // 7=0. 6 = 1 for 12 hr, 0 for 24 hr.
// bit 5: 12 hr mode = AM(0)/PM(1). 24 hr mode = upper tens of hrs
// bit 4 =  lower tens of hrs, bits 3-2-1-0 = units of hours (0-9)
byte day_week_address = 0x03;
byte day_week = 0; // range 01-07
byte date_month_address = 0x04;
byte date_month = 0; // range 01-31
byte month_address = 0x05;
byte month = 0; // range 01-12
byte year_address = 0x06;
int year = 0; // upper byte 0-9, lower byte 0-9
byte square_address = 0x07;
byte sqwe = 0;  // square wave enable
// Out-0-0-Sqwe-0-0-RS1-RS0
// Out, Sqwe = 0/0 - Square wave output = 0
// Out, Sqwe = 1/0 - Square wave output = 1
// Out, Sqwe = 0/1 or 1/1 - Square wave output per RS1/RS0
// RS1/RS0 = 00 = 1 Hz
// RS1/RSo = 01 = 4 KHz
// RS1/RS0 = 10 = 8 KHz
// RS1/RS0 = 11 = 32 KHz
byte RTC_ram_address = 0x08; //range = 08-63, 0x08-0x3F
int RTC_address = 0x68; // 1101 000
byte RTC_write_command = 0;
byte RTC_read_command = 0;
byte RTC_ram_command = 0;
// use F0xx, F1xx,F2xx, F3xx, F4xx, F5xx, F6xx, F7xx
// to send one register write commands
// use E0xx to read registers back - not coded yet
// use C0xx to read RAM back - not coded yet
byte incomingRegister = 0;
byte RTC_register = 0;
byte incomingData1 = 0;
byte incomingData2 = 0;
byte new_data = 0;
byte outgoingData = 0;
int delay_time = 100;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
unsigned long duration = 5000;
  Wire.begin(); // no address, we are master
  Serial.begin (57600);
  Serial.flush();
  currentMillis = millis();
  if (Serial.available() >3){
    incomingRegister = Serial.read();
    incomingData1 = Serial.read();
    incomingData1 = incomingData1 - 0x30; // convert ASCII to HEX
    incomingData2 = Serial.read();
    incomingData2 = incomingData2 - 0x30;  // convert ASCII to HEX
    new_data = (incomingData1 << 4) + incomingData2;  // put the Upper/Lower nibbles together
    Serial.print ("command ");
    Serial.println (incomingCommand);
    Serial.print ("register ");
    Serial.println(incomingRegister);
    Serial.print ("data1 ");
    Serial.println (incomingData1, HEX);
    Serial.print ("data2 ");
    Serial.println (incomingData2, HEX);
    Serial.print ("combined data ");
    Serial.println (new_data, HEX);
//  RTC_write_command = incomingCommand & 0xF0;  // mask off high byte
//  if (RTC_write_command == 0xF0){  // check for Write command
if ((incomingCommand == 'F') | (incomingCommand == 'f')){
  incomingCommand = 0;  // reset for next pass
//    RTC_register = incomingCommand & 0x0F;  // mask off low btye
//    incomingCommand = 0;
//    new_data = incomingData;
    Serial.println (" Sending a command ");
//    switch (RTC_register){
switch (incomingRegister){
  case '0': // write seconds
        Serial.println ("Seconds ");
      Wire.beginTransmission(RTC_address); // select device
      Wire.send(seconds_address);          // queue the register
      Wire.send(new_data);                  // queue data
      Wire.endTransmission();            // send it
      delay (delay_time);
    case '1': // write minutes
    Serial.println ("Minutes ");
      Wire.send(minutes_address);          // queue the register
      delay (delay_time);
    case '2': // write hours
        Serial.println ("Hours ");
      Wire.send(hours_address);          // queue the register
     delay (delay_time);
    case '3': // write day
        Serial.println ("Day ");
      Wire.send(day_week_address);          // queue the register
     delay (delay_time);
    case '4': // write date of month
        Serial.println ("Day of Month ");
      Wire.send(date_month_address);          // queue the register
     delay (delay_time);
    case '5': // write month
        Serial.println ("Month ");
      Wire.send(month_address);          // queue the register
     delay (delay_time);
    case '6': // write year
        Serial.println ("Year ");
      Wire.send(year_address);          // queue the register
     delay (delay_time);
    case '7': // write square wave
        Serial.println ("Square Wave ");
    Serial.println (RTC_register, HEX);
      Wire.send(square_address);          // queue the register
     delay (delay_time);
    case '8': // write RAM
        Serial.print ("RAM ");
      Wire.send(RTC_ram_address);          // queue the register
     delay (delay_time);
      // all others,do nothing
      Serial.println ("Invalid command ");
    }  // end Switch
  } // end if command == 'F'
  if ( (currentMillis - previousMillis) >= duration){
    // Reset the register pointer
    Wire.send(0x00);
    Wire.requestFrom(RTC_address,8 );
    seconds = Wire.receive();
    minutes = Wire.receive();
    hours = Wire.receive();
    day_week = Wire.receive();
    date_month = Wire.receive();
    year = Wire.receive();
    sqwe = Wire.receive();
    // Seconds
    // Hours
    Serial.print ("Hrs " );
    Serial.print (hours, HEX);
    Serial.print (" Mins ");
    Serial.print (minutes, HEX);
    Serial.print (" Secs ");
    Serial.print (seconds, HEX);
    Serial.print (" Day ");
    Serial.print (day_week, HEX);
    Serial.print (" Date ");
    Serial.print (date_month, HEX);
    Serial.print (" Month ");
    Serial.print (month, HEX);
    Serial.print (" Year 20");
    Serial.print (year, HEX);
    Serial.print (" Square Wave ");
    Serial.println (sqwe, HEX);
halejandro
#38
Aug 13, 2011, 06:26 am Last Edit: Aug 13, 2011, 06:28 am by halejandro Reason: 1
Oh man I'm so sorry, I wanted to do it by myself, but I´m pretty slow to build codes!
CrossRoads
Well, I needed it myself also so I could test from both serial ports on my board.
You weren't giving me very good confidence that the changes I was suggesting were actually correct, so I had to see.
Am helping 2 others with the same.
Apparantly my use of Serial1 vs Serial, and then a different program with more features than Arduino Serial Monitor has lent itself to much confusion all around.
Your task can be to add the extra 'C' and 'E' commands I didn't write to read back indivual registers and the 56 bytes of battery backed RAM.
halejandro
#40
Aug 13, 2011, 07:04 am Last Edit: Aug 13, 2011, 07:18 am by halejandro Reason: 1
Ok I'll try it, THANKS A LOT !
halejandro
Excuse me, What are the conditions for read back a register?
CrossRoads
I am not 100% sure.  That sketch was my first time getting back over I2C, I got parts of it from the playground.
So, I think this might work:
Code: [Select]
    Wire.send(0x00);     <<< put in the address you want, 0x00 to 0x07
    Wire.requestFrom(RTC_address,1);
    register_contents = Wire.receive();
altho one would think the two could be combined somehow, the way writing a single register is done:
Code: [Select]
    Wire.requestFrom(RTC_address);  // send I2C address
>> send the register to read from - not sure what would be used here tho
    register_contents = Wire.receive();   // read the data here
halejandro
Hi, sorry but this is ok? I'm not sure if the square wave register reads that way! Normally we can access the F register, but if do we want to access to E register? I tried using else after the if (Serial.available() >3) with only the command and register data, but it didn´t work !
Code: [Select]
if ((incomingCommand == 'E') | (incomingCommand == 'e')){
    Serial.println (" Sending Command ");
  case '0': // read seconds
      Serial.println ("Seconds: ");
      Wire.requestFrom(RTC_address,1);   // (device address, R/W) R=1, W=0
      seconds = Wire.receive();          // read the data here
      Serial.println(seconds, HEX);
      delay (delay_time);
    case '1': // read minutes
      Serial.println ("Minutes: ");
      Wire.requestFrom(RTC_address,1);    //  read the data here
      Serial.println(minutes, HEX);
      delay (delay_time);
   case '2': // read hours
      Serial.println ("Hours: ");
      Serial.println(hours, HEX);
     delay (delay_time);
  case '3': // read day
      Serial.println ("Day: ");
      day_week = Wire.receive();         // read the data here
      Serial.println(day_week, HEX);
      delay (delay_time);
  case '4': // read date of month
        Serial.println ("Day of Month: ");
      date_month = Wire.receive();       // read the data here
      Serial.println(date_month, HEX);
      delay (delay_time);
  case '5': // read month
      Serial.println ("Month: ");
      Serial.println(month, HEX);
      delay (delay_time);
  case '6': // read year
      Serial.println ("Year: ");
      year = Wire.receive();             // read the data here
      Serial.println(year, HEX);
      delay (delay_time);
  case '7': // read square wave
      Serial.println ("Square Wave: ");
      sqwe = Wire.receive();             // read the data here
      Serial.println(sqwe, HEX);
     delay (delay_time);
  case '8': // read RAM
      delay (delay_time);
     }  // end Switch
  } // end if command == 'E'
CrossRoads
Looks good halejandro! I would suggest changes at the start of void loop like this:
(and I took out some of old stuff)
Code: [Select]
if ((incomingCommand == 'F') | (incomingCommand == 'f')){incomingCommand = 'F');
if ((incomingCommand == 'E') | (incomingCommand == 'e')){incomingCommand = 'E');
if ((incomingCommand == 'C') | (incomingCommand == 'c')){incomingCommand = 'C'); // or whatever you decide to go with
switch (incomingCommand) {
case 'F':
  case '0':   /// and all the stuff from the original
case '8':
// move this here now:
}  // end switch:case RTC_register for command 'F
break;  // end command 'F'
// Now add the next command
case 'E':
  case '0':   /// and all the stuff you just wrote
case '8':
}  // end switch:case RTC_register for command 'E'
break;  // end command 'E'
//repeat for 'C'
Case 'C':
// etc.
break; //end command 'C'
} // end switch:case incomingCommand
So now you'll have a switch:case within a switch:case!
