Topic: DS1307 adrress register help ! (Read 9040 times) previous topic - next topic
CrossRoads
Please do a CTRL-T when you make the changes, will help check that the { and } are all paired up.
halejandro
#46
Aug 17, 2011, 06:07 am Last Edit: Aug 17, 2011, 06:10 am by halejandro Reason: 1
Ok, I made the changes, but I have a problem I can´t access to any function, I tested several ways but they didn´t work! the code is to big where can I send it to you?
CrossRoads
Post it here - just take out
case 1:
case 7:
for the 'E' and 'F' commands to shorten it up, paste them back in after getting just case '0' working.
halejandro
Code: [Select]
Test of RTC DS1307 via I2C.
Counts
Seconds,
Minutes,
Hours,
Date of the Month,
Month,
Day of the week, and
Year with Leap-Year
56 bytes battery backed RAM
Square Wave Output, can connect to INT2/D6 or PD7
Modified to Run thru IDE Serial port
#include <Wire.h>
//variables
byte seconds_address = 0x00;
byte seconds; // bit 7 = Clock Halt, Enabled = 0, Halt = 1
// bits 6-5-3 = tens of seconds 0-6,  bits 3-2-1-0 = units of seconds, 0-9
byte minutes_address = 0x01;
byte minutes;  // bits 6-5-4 = tens of minutes, bits 3-2-1-0 = units of minutes
byte hours_address = 0x02;
byte hours;  // 7=0. 6 = 1 for 12 hr, 0 for 24 hr.
// bit 5: 12 hr mode = AM(0)/PM(1). 24 hr mode = upper tens of hrs
// bit 4 =  lower tens of hrs, bits 3-2-1-0 = units of hours (0-9)
byte day_week_address = 0x03;
byte day_week = 0; // range 01-07
byte date_month_address = 0x04;
byte date_month = 0; // range 01-31
byte month_address = 0x05;
byte month = 0; // range 01-12
byte year_address = 0x06;
int year = 0; // upper byte 0-9, lower byte 0-9
byte square_address = 0x07;
byte sqwe = 0;  // square wave enable
// Out-0-0-Sqwe-0-0-RS1-RS0
// Out, Sqwe = 0/0 - Square wave output = 0
// Out, Sqwe = 1/0 - Square wave output = 1
// Out, Sqwe = 0/1 or 1/1 - Square wave output per RS1/RS0
// RS1/RS0 = 00 = 1 Hz
// RS1/RSo = 01 = 4 KHz
// RS1/RS0 = 10 = 8 KHz
// RS1/RS0 = 11 = 32 KHz
byte RTC_ram_address = 0x08; //range = 08-63, 0x08-0x3F
int RTC_address = 0x68; // 1101 000
byte incomingCommand = 0;
byte RTC_write_command = 0;
byte RTC_read_command = 0;
byte RTC_ram_command = 0;
// use F0xx, F1xx,F2xx, F3xx, F4xx, F5xx, F6xx, F7xx
// to send one register write commands
// use E0xx to read registers back - not coded yet
// use C0xx to read RAM back - not coded yet
byte incomingRegister = 0;
byte RTC_register = 0;
byte incomingData1 = 0;
byte incomingData2 = 0;
byte new_data = 0;
byte outgoingData = 0;
int delay_time = 100;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
unsigned long duration = 5000;
  Wire.begin(); // no address, we are master
  Serial.begin (57600);
  Serial.flush();
  currentMillis = millis();
  if (Serial.available() >3){
    incomingCommand = Serial.read();
    incomingRegister = Serial.read();
    incomingData1 = Serial.read();
    incomingData1 = incomingData1 - 0x30; // convert ASCII to HEX
    incomingData2 = Serial.read();
    incomingData2 = incomingData2 - 0x30;  // convert ASCII to HEX
    new_data = (incomingData1 << 4) + incomingData2;  // put the Upper/Lower nibbles together
    Serial.print ("command ");
    Serial.println (incomingCommand);
    Serial.print ("register ");
    Serial.println(incomingRegister);
    Serial.print ("data1 ");
    Serial.println (incomingData1, HEX);
    Serial.print ("data2 ");
    Serial.println (incomingData2, HEX);
    Serial.print ("combined data ");
    Serial.println (new_data, HEX);
  if ((incomingCommand == 'F') | (incomingCommand == 'f')){
    incomingCommand = 'F';
    if ((incomingCommand == 'E') | (incomingCommand == 'e')){
      incomingCommand = 'E';  // or whatever you decide to go with
      switch (incomingCommand) {
      case 'F':
        Serial.println (" Sending a command ");
        switch (incomingRegister){
        case '0': // write seconds
          Serial.println ("Seconds ");
          Wire.beginTransmission(RTC_address); // select device
          Wire.send(seconds_address);          // queue the register
          Wire.send(new_data);                  // queue data
          Wire.endTransmission();            // send it
          delay (delay_time);
        case '8': // write RAM
          Serial.print ("RAM ");
          Serial.println (RTC_register, HEX);
          Wire.send(RTC_ram_address);          // queue the register
          delay (delay_time);
          incomingCommand = 0;  // reset for next pass
        }  // end switch:case RTC_register for command 'F
        break;  // end command 'F'
      case 'E':
          Serial.println (" Sending Command ");
        case '0': // read seconds
          Serial.println ("Seconds: ");
          Wire.requestFrom(RTC_address,1);   // (device address, R/W) R=1, W=0
          seconds = Wire.receive();          // read the data here
          Serial.println(seconds, HEX);
          delay (delay_time);
        case '8': // read RAM
          delay (delay_time);
        }  // end switch:case RTC_register for command 'E'
        break;  // end command 'E'
  if ( (currentMillis - previousMillis) >= duration){
    // Reset the register pointer
    Wire.send(0x00);
    Wire.requestFrom(RTC_address,8 );
    minutes = Wire.receive();
    hours = Wire.receive();
    day_week = Wire.receive();
    date_month = Wire.receive();
    year = Wire.receive();
    sqwe = Wire.receive();
    // Seconds
    // Hours
    Serial.print ("Hrs " );
    Serial.print (hours, HEX);
    Serial.print (" Mins ");
    Serial.print (minutes, HEX);
    Serial.print (" Secs ");
    Serial.print (seconds, HEX);
    Serial.print (" Day ");
    Serial.print (day_week, HEX);
    Serial.print (" Date ");
    Serial.print (date_month, HEX);
    Serial.print (" Month ");
    Serial.print (month, HEX);
    Serial.print (" Year 20");
    Serial.print (year, HEX);
    Serial.print (" Square Wave ");
    Serial.println (sqwe, HEX);
CrossRoads
Try this. I think the problem was not quite correct usage of { & }.
Code: [Select]
Counts
Seconds,
Minutes,
Hours,
Date of the Month,
Month,
Year with Leap-Year
#include <Wire.h>
//variables
byte new_data = 0;
  Serial.flush();
  case 'F':
      delay (delay_time);
      delay (delay_time);
  case 'E':
      delay (delay_time);
      delay (delay_time);
    Wire.send(0x00);
    // Seconds
    // Hours
halejandro
What are the conditions to read and write in RAM?
CrossRoads
Read & write to 0x08 up to 0x3F.
Or decimal 08 to 63.
Follow the same steps as the others to access 1 byte, 8 bytes, etc. up to 56 bytes.
