Topic: SD card won't initialize, Voltage increases after card is connected (Read 2294 times) previous topic - next topic
nkaati
I can't seem to figure out why my SD card won't initialize.  I checking the voltage and after the SD card is connected the voltage rises from 3.3 to 3.6V and then 500ms later jumps to 3.9V.
I'm using the 3.3V pin from the Arduino Duemilanove.  Is this normal that the voltage would increase after plugging in the SD card.  I don't think the pins I'm using for the SPI connection are incorrect.
Thanks,
Nathan
CrossRoads
The 3.3V pin only puts out 50mA from the FTDI USB chip; you are overstressing it, and may notice it getting hot. You will need another source that can supply more current.
My card here has a regulator just to provide current to the SD card.
http://www.crossroadsfencing.com/BobuinoRev17
nkaati
Even using an alternative source I'm still getting an increase in voltage after plugging in the sd card.
it jumps from 3.3V to 3.5V and the supply is 100mA.
Still doesn't recognize the sd card
PaulS
Time to post a schematic showing how the SD card is wired.
nkaati
Here is a picture of the pin connections, I only changed the CS pin from 4 to 10 compared to the examples. All the jumpers are on DIS(abled).
nkaati
Are these connections correct, I'm still not sure why there would be an increase in voltage.
CrossRoads
Are you driving it from Arduino pins directly? Or do you have a 3.3V level shifter for SCK, SS, and MOSI?
nkaati
There are voltage dividing resistors to drop the output voltage from the pins down to 3.3V on the pcb.
Grumpy_Mike
So what are the values? It sounds like these signals are back powering your card. This is not good.
Using resistors is a poor way of driving a card and some cards won't work with this method.
CrossRoads
I see some jumpers there - would seem to need them set on the  SS, MISO, MOSI, SCK side to work with SPI.
Is there a schematic for that card?
nkaati
Well when I originally had it on a breadboard I had the SD card running for 12 hour periods at a time from the Arduino Duemilanove and I've done that multiple times about 20 times. Never had a problem until I took it off the breadboard.  Yes there is a pdf of the schematic of the board and uses for SD and SPI modes.  I've had the jumpers on DIS, because of there connection to 3.3V.
I've had a closer look at the pdf and I think I take back what I said.
I'd like to know how I had it working in the first place :|
The voltages on the breadboard were fine when first using the SD card slot and interface with the arduino.
CrossRoads
Just lucky I guess? Page 3 shows a level shifting chip when connected to a 5V uC.
You haven't fried your SPI pins? They still drive hi/lo okay?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
