Topic: Arduino 0016 now available. (Read 3012 times) previous topic - next topic
mellis
From the software page: http://arduino.cc/en/Main/Software
Changes include:
[documentation / examples]
* New communication examples (w/ corresponding Processing and Max/MSP code) by Tom Igoe.
[core / libraries]
* Adding support for the Arduino Pro and Pro Mini 3.3V / 8 MHz w/ ATmega328.
* Adding support for the LilyPad Arduino w/ ATmega328.
* Adding write(str) and write(buf, size) methods to Print, Serial, and the Ethernet library Client and Server classes.  This allows for more efficient (fewer packet) Ethernet communication.  (Thanks to mikalhart.)
* Improvements to the way the Ethernet library Client class connects and disconnects.  Should reduce or eliminate failed connections and long timeouts.  (Thanks to Bruce Luckcuck.)
* Optimizing the timer0 overflow interrupt handler (used for millis() and micros()).  Thanks to westfw and mikalhart.
* Fixing bug that limited the bit() macro to 15 bits.  Thanks to Paul Badger.
* Adding ARDUINO version constant (thanks to prodding from mikalhart).
[environment]
* Ordering the items in the Tools > Board menu.
* Adding "Copy as HTML" command to the Tools menu.
* Eliminating (maybe) the occasional "Couldn't determine program size" errors.  Thanks to the Clever Monkey.
* Moving selection of Linux look-and-feel into the arduino script so it can be changed by users.  Thanks to Eberhard Fahle.
[tools]
* Adding automatic dependency generation to the Makefile.  (Lars Immisch)
interlol
Congratulation!
For an alternative to "Copy as HTML", you can try Pygments, it's a Python-library with a command line program rather easy to use.
(and I go back to reading "Foundations of Analog and Digital Electric Circuits"...)
Ron C
Exactly what is the "ARDUINO version constant" mentioned in the new features?
follower
As I recall it's a feature to enable people to develop libraries that need to act differently depending on the Arduino version. e.g. they might need to work around a bug in a particular version, be optimised in a particular way or use a feature that is only in a particular version.
--Phil.
jafoca
As a relative noobie....  what would be the proper way to go about upgrading my Arduino software in Mac OSX leopard?
I have arduino 15 in a folder in my documents area now...  should I overwrite that with the newer files?
follower
Multiple versions of the IDE can co-exist happily on OS X as far as I can tell.
You could just drag the 0016 folder into the location you normally put your applications.
--Phil.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
