Author Topic: Arduino + Garmin Nuvi  (Read 725 times)
Hi, I would really like to interface my arduino directly to my Garmin Nuvi and read GPS data from it into my arduino.
Does anybody know if this feasible?  Maybe with a USB host shield from sparkfun?
Seattle, WA USA
Online Online
Seattle, WA USA
How are you at writing device drivers?
Uh not to great.  Is the garmin really that proprietary?  So basically there is no way to do this?
Cairns - Green Island for Winter
I have not seen a post that says you can't do this ?
Why assume there is no way to do this
I don't know how to do it but I would like to see if it can be done
What on earth does your post mean PaulS- if you are insinuating it can't be done then please explain why not
I have an old garmin carcass with a gps module attached and I can certainly solder wires to it so I can at least explore it !
Governments should do what they were designed to do only.
Manage the larger issues best done by Government.
My Family and my Property are not Government issues.
To stop corruption give them 3 times the normal penalty.
Have them agree on first appointment.
Seattle, WA USA
Online Online
Seattle, WA USA
I'm not saying that it can't be done. In fact, it is possible that it CAN be done.
The problem is that the Arduino is a USB slave, and the Garmin is also a USB slave. A slave can't make another slave do anything. Only a USB master (host) can make a slave do anything.
So, in order to even think about making the Arduino communicate with the Garmin, the Arduino needs a USB Host shield. Fortunately, Sparkfun sells one. Unfortunately, the shield only handles the hardware part. The software needed to make the hardware do something is called a device driver.
Writing device drivers is not the easiest thing to do. Fitting the required code in the Arduino's limited space, while still leaving room for a sketch to do something is another challenge.
But don't let my lack of accomplishments discourage you. Get a shield, and start writing a driver. Post it here when you get done. Lots of people will appreciate it.
Thats good stuff PaulS .
So the Sparkfun USB Host board is the master and it is telling the slave devices what to do. I don't profess to understand that but I can start to research it from there . The Arduino though has the program which runs everything so I don't see how the host board is controlling things , its only converting the info coming in to a form the arduino can read onto  a serial connection isn't it ?
So are you not  referring to the bootloader?
The sketch handles telling the slave device attached to the shield what to do and I think you mean the the instructions for the host shield take up a lot of program room is that so ?
« Last Edit: October 15, 2011, 04:24:12 pm by tytower » Logged
Seattle, WA USA
Online Online
Seattle, WA USA
There are hardware and software issues involved with talking to a USB device. The USB Host shield manages the hardware side of things. The Arduino handles the software side. Serial is not involved.
No.
Yes. Sometimes. It depends, of course, on what you are talking to. Talking to a specific model from specific manufacturer, of GPS, for instance, is going to require less code than trying to determine what GPS is connected, what that GPS understands, and controlling ANY GPS.
Garmin might be helpful in supplying information about how to communicate with their GPS's. Magellan refuses to even disclose what time it is.
« Last Edit: October 15, 2011, 05:22:18 pm by PaulS » Logged
If you're not living on the Edge, you're taking up too much space!
This works with many different GPS's.
http://www.circuitsathome.com/mcu/communicating-to-gps-receiver-using-usb-host-shield
If you fall... I'll be there for you!
-Floor
Skype Brighteyes3333
(262) 696-9619
Hmm thinking thinking
How to run usb-modeswitch from inside arduino IDE.
Saw this
mode switching tool for controlling "flip flop" USB devices
 Several new USB devices have their proprietary Windows drivers onboard,
 especially WAN dongles. When plugged in for the first time, they act
 like a flash storage and start installing the driver from there. If
 the driver is already installed, the storage device vanishes and
 a new device, such as an USB modem, shows up. This is called the
 "ZeroCD" feature.
 On Debian, this is not needed, since the driver is included as a
 Linux kernel module, such as "usbserial". However, the device still
 shows up as "usb-storage" by default. usb-modeswitch solves that
 issue by sending the command which actually performs the switching
 of the device from "usb-storage" to "usbserial".
I'm using Puppy 5.28 as an Op System atm and usb-modeswitch is installed and loaded . Now I just have to use it properly
