Loading...
Pages: [1]   Go Down
Author Topic: Using salvaged relays for 110vac controls  (Read 521 times)
Offline Offline
Newbie
View Profile
I have a few relays that I've salvaged from appliance control boards.  The electrical specs look good (12vdc coil, switch supports up to 20A@230vac), but the legs on the bottom are TINY.  I want to control an air compressor (owner's manual calls for a 15A branch circuit, so my relay should work, right?) but the wires on the compressor itself are much larger than these little pins on my relays.
1. Am I missing something?  Why are the pins so small?
2. How do I attach the tiny pin to giant stranded wire? (12ga, I think.  I'll check on that.)  The pins are flat, so I don't think they'll fit into a perfboard.
Tim
Logged
Offline Offline
Newbie
View Profile
OK, forget the air compressor then.  I have lots of other small 110vac motors I'd like to control (in the 2-3A range).  So in the case that the relay is sufficient for the load- how would I attach the wires?
If I can't find a way to mount the relay by its legs, I'm OK with just soldering wires onto the pins.  I have just never seen a writeup on how to do this properly.
Thanks for reading.  I think I have a 24vac transformer and contactor out of an HVAC unit, I can rig it up to run the compressor if need be.
Logged
Offline Offline
Newbie
View Profile
That's perfect, thanks!  I'll post a writeup on my project when it's reasonably ready.
Tim
Logged
Pages: [1]   Go Up
Print
Jump to:
