Topic: (Arduino Compatible) Microcontroller with multuple A/D converters (Read 3225 times) previous topic - next topic
fkeel
EDIT: The Maple Leaf has two ADCs which can be simultaniously used. As far as I can tell this is the closest thing to an Arduino board with multiple ADCs.
OLD MESSAGE:
Hi Everyone
Can anyone recomend a arduino-clone or other microcontroller which has several A/D converters? I have seen that some of the netduinos have multiple AD converters, but I would love to use a board which I can program using the regular Arduino Language.
Any recomandations?
Thanks
P.
edit: the netduinos have a "One 8-channel 10-bit Analog-to-Digital Converter, Four Channels Multiplexed with Digital I/Os" I misinterpreted that. It actually simply multiplexes one a/d converter as well... http://www.atmel.com/dyn/resources/prod_documents/doc6120.pdf
edit2: The chip used in the Maple by LeafLab (STM32 F103RB) has 2 Analog to Digital Converters. I am not sure if both are brought out to the board though.
http://embodimentlabs.tumblr.com/
http://paulstrohmeier.info/
Coding Badly
Have you considered using an external SPI or I2C converter?  I believe that's what most Arduino folks do to add additional converters.
fkeel
#2
Aug 09, 2011, 12:17 am Last Edit: Aug 09, 2011, 12:22 am by fkeel Reason: 1
yes. I will probably either use several of these:
http://www.sparkfun.com/products/8636
or this here:
http://www.analog.com/static/imported-files/data_sheets/AD7656_7657_7658.pdf
as suggested in this thread here:http://arduino.cc/forum/index.php/topic,66536.0.html
I was hover wondering, if I could save myself some extra work by simply using a different board. But I have been reading up on data-sheets and I guess that is unlikely...
edit: @coding badly. Is there any external converter you can recommend? I need at least 4 channels
fkeel
Could I use this as an A/D converter?
http://www.sparkfun.com/products/9365
Coding Badly
Unfortunately, my only experience is vicarious.  I can say that the forum discussions about external converters seem to be primarily positive (easy to get working; good results) but that does not help you very much.
I vaguely recall that CrossRoads has posted links to Analog Devices training sessions.  I believe Anachrocomputer has posted often about digital-to-analog conversion (wrong direction but he seems to have an interest in the general topic).  You may have luck focusing a search on those two.
Oh wait...
Quote
as suggested in this thread here: http://arduino.cc/forum/index.php/topic,66536.0.html
...looks like you already have the attention of CrossRoads.  Never mind.
Quote
Wow.  There's a big difference between those two.
Enough of the sidebar.  The best I can do is recommend processors to avoid...
ATtiny2313 - no analog-to-digital converter
ATtiny84 - one
ATtiny85 - one
ATmega328 - one
Unfortunately, the parametric search does not include converter count...
http://www.atmel.com/dyn/products/param_table.asp?category_id=163&family_id=607&subfamily_id=760
retrolefty
#5
Aug 09, 2011, 02:48 am Last Edit: Aug 09, 2011, 03:05 am by retrolefty Reason: 1
Here is an external pretty nice I2C 16 bit A/D converter, it's based on the TI ADS1115 chip. It can be run as either two differential channels or four single ended analog input. Can be run at 5vdc and is breadboard friendly. So far my check out of the device is very favorable, I can detect a 1 microvolt change at the highest gain setting of +/- .256 vdc full range, but can still read 0-5vdc at it's lowest gain setting, but still getting .000187 volts per step resolution. Seems very stable and the large number of programmable range options can save needing to use external op-amps for interfacing things like strain gages and other Wheatstone bridge type sensors.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230619695873&ssPageName=STRK:MEWAX:IT
Datasheet: http://www.ti.com/lit/ds/sbas444b/sbas444b.pdf
Here is a sketch I wrote this weekend to check out the device:
Code: [Select]
/* Basic testing and check out sketch for a TI ADS1115 4 channel,16 bit, I2C, analog to digital converter chip
  Leftyretro 08/06/11
#include <Wire.h>
int topofScale;   // made global to use adc range value to display millivolt reading conversion
   Wire.begin();  // join I2C bus
   Serial.begin(38400); // initialize serial communication
   setConfiguration();  // configure ADS1115 chip for range and channel desired
   int   rawValue; // holds 16 bit result read from A/D device
   int scaledValue; // to convert to millivolts
   byte userKeys;
   Serial.print("Analog input #1 counts =  ");
   rawValue = getadcReading();  // read current A/D value
   Serial.print(rawValue);
   Serial.print("  Millvolts =  ");
   scaledValue = map(rawValue, 0, 32767, 0, topofScale);
   Serial.print(scaledValue);
   Serial.println("     Hit any key to continue");
   while(Serial.available() < 1) {}   // wait for user keystroke
   while(Serial.available() > 0) {userKeys = Serial.read();} //read keystrokes then back to loop
int getadcReading()
     int data;
     int deviceAdd = 0x48;   //ADS1115 address with address pin grounded
     Wire.beginTransmission(deviceAdd); // transmit to I2c device address
     Wire.send(0x00);                   // point to device register 0
     Wire.endTransmission();            // stop transmitting
     Wire.requestFrom(deviceAdd, 2);    // request 2 bytes from slave device #2
     while(Wire.available())    // need two bytes, MSB and LSB of converstion value
         data = Wire.receive();  //get MSB of reading
         data = data << 8;       // shift it to high byte of data
         data = data + Wire.receive(); // add LSB to data
     return data;
void setConfiguration()
           //uncomment desired voltage input range
     int confWord= 0x0000; topofScale = 6144;  // 0- 0-6.144 vdc range
     //int confWord= 0x0200; topofScale = 4096;  // 1= 0-4.096 vdc range
     //int confWord= 0x0400; topofScale = 2048;  // 2= 0-2.048 vdc range
     //int confWord= 0x0600; topofScale = 1024;  // 3= 0-1.024 vdc range
     //int confWord= 0x0800; topofScale =  512;  // 4= 0-.512 vdc range
     //int confWord= 0x0A00; topofScale =  256;  // 5= 0-.256 vdc range
          //uncomment desired channel input
              // Also this sets sample rate to 860 SPS, disables comparitor,
              // and turns on continous conversion mode.
     confWord = confWord | 0x00E3;  // 0= input wired to + AIN0 - AIN1, diff
     //confWord = confWord | 0x30E3;  // 3= input wired to + AIN2 - AIN3, diff
     //confWord = confWord | 0x40E3;  // 4= input wired to + AIN0 - gnd, single ended
     //confWord = confWord | 0x50E3;  // 5= input wired to + AIN1 - gnd, single ended
     //confWord = confWord | 0x60E3;  // 6= input wired to + AIN2 - gnd, single ended
     //confWord = confWord | 0x70E3 ; // 7= input wired to + AIN3 - gnd, single ended
     Wire.beginTransmission(deviceAdd); // transmit to ADS1115 device
     Wire.send(0x01);                   // point to configuration register
     Wire.send(highByte(confWord));      // sends MSB of configuration word
     Wire.send(lowByte(confWord));       // sends LSB of configuration word
Lefty
putyn
or you can try this http://focus.ti.com/docs/prod/folders/print/tlv1543.html its has 11 channels with 10bit resolution
hope this helps
retrolefty
#7
Aug 11, 2011, 10:36 pm Last Edit: Aug 11, 2011, 10:46 pm by retrolefty Reason: 1
Good luck with your research.
I updated my check sketch for the device to include enabling and testing the comparitor function. This lets you set a high limit and low limit and if the voltage is between them it sets a output pin low in one comparitor mode, or will go low if the voltage exceeds the high set limit or falls below the low limit, in the other comparitor mode.
Code: [Select]
/* Basic testing and check out sketch for a TI ADS1115 4 channel 16 bit I2C analog to digital converter chip.
  Reads voltage at desired range on desired channel and displays it on serial monitor. Also allows comparitor
  to output a active low signal pin if enabled.
  Leftyretro 08/10/11
#include <Wire.h>
int topofScale;          // global to use adc range value to display millivolt reading conversion
int hiCompair = 17000;   // high setting for comparitor threshold value, must be higher then loCompair 32767
int loCompair = 11000;   // low  setting for comparitor threshold value, must be lower then hiCompair -32768
   setadcConfiguration();  // configure ADS1115 chip for range, channel input, and comparitor options desired
   scaledValue = map(rawValue, 0, 32767, 0, topofScale);  //convert raw adc counts to millivolts
   while(Serial.available() > 0) {byte userKeys = Serial.read();} //read keystrokes
int getadcReading()   // read 16 bit analog voltage reading
     int data;
     int deviceAdd = 0x48;              // ADS1115 address with address pin grounded
         data = Wire.receive();         // get MSB of reading
     return data;
void setadcConfiguration()
           /* uncomment one desired voltage input range */
     int confWord= 0x0000; topofScale = 6144;  // +/-6.144 vdc range
     //int confWord= 0x0200; topofScale = 4096;  // +/-4.096 vdc range
     //int confWord= 0x0400; topofScale = 2048;  // +/-2.048 vdc range
     //int confWord= 0x0600; topofScale = 1024;  // +/-1.024 vdc range
     //int confWord= 0x0800; topofScale =  512;  // +/-.512 vdc range
     //int confWord= 0x0A00; topofScale =  256;  // +/-.256 vdc range
     /*  uncomment one desired channel input
         This also sets sample rate to 860 SPS and turns on continous conversion mode. */
     confWord = confWord | 0x00E0;  //input wired to + AIN0 - AIN1, diff +/- max range
     //confWord = confWord | 0x30E0;  //input wired to + AIN2 - AIN3, diff +/- max range
     //confWord = confWord | 0x40E0;  //input wired to + AIN0 - gnd, single ended, 0 to +max range
     //confWord = confWord | 0x50E0;  //input wired to + AIN1 - gnd, single ended, 0 to +max range
     //confWord = confWord | 0x60E0;  //input wired to + AIN2 - gnd, single ended, 0 to +max range
     //confWord = confWord | 0x70E0;  //input wired to + AIN3 - gnd, single ended, 0 to +max range
     /* uncomment one desired comparator options
        active low ready pin, window mode = input voltage is inside window values
        active low ready pin, traditional = voltage raised above or fell below set values */
     //confWord = confWord | 0x0003;   //disable comparitor
     //confWord = confWord | 0x0008;    //enable comparitor in traditional comparator mode
     confWord = confWord | 0x0018;   //enable comparitor in window comparator mode
     //send configuration word to device
     //send low threshold value word to device
     Wire.send(0x02);                    // point to low threshold register
     Wire.send(highByte(loCompair));     // sends MSB of low threshold word
     Wire.send(lowByte(loCompair));      // sends LSB of low threshold word
     //send high threshold value word to device
     Wire.send(0x03);                    // point to high threshold register
     Wire.send(highByte(hiCompair));     // sends MSB of high threshold word
     Wire.send(lowByte(hiCompair));      // sends LSB of high threshold word
Lefty
fkeel
retrolefty, you are legendary.
seriously... I am a psych guy who randomly got thrown into HCI and hardware development ... and people like you (and many others in this forum) are teaching me so much ...
Thank you.
