Topic: Strange problem with DIY arduino (Read 1 time) previous topic - next topic
max891
I have two arduinos, one Uno and one made by myself using Atmega8 and http://itp.nyu.edu/physcomp/Tutorials/ArduinoBreadboard scheme.
I turn Uno to ISP programmer using proper sketch and disabling auto reset using a cap between reset and gnd pins.
And problems begins... I burn bootloader on second board without problems, next I used blink to see some effects :) After that I use sketch that  give HIGH to all digital ports (to test solders and connections)... but all circuit is dead. I burn bootloader once more, use Blink and it works... till next upload.. It seems that cotroller wipe bootloader from memory.
Some advices ?
spycatcher2k
Hi MAX - the fault you are discribing is normaly caused by wrong lock bits being set.
How are you burning the boot loader?
here is my setup :
atmega8.name=ATmega8
atmega8.upload.protocol=stk500
atmega8.upload.maximum_size=7168
atmega8.upload.speed=19200
atmega8.bootloader.low_fuses=0xdf
atmega8.bootloader.high_fuses=0xca
atmega8.bootloader.path=atmega8
atmega8.bootloader.file=ATmegaBOOT.hex
atmega8.bootloader.unlock_bits=0x3F  <---- open for programming bootloader
atmega8.bootloader.lock_bits=0x0F     <---- Lock the area used by the bootloader
atmega8.build.mcu=atmega8
atmega8.build.f_cpu=16000000L
atmega8.build.core=arduino
Hope this helps
Drew.
http://www.uk-pcb.co.uk - UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details. Arduino & C# PC programming.
max891
I use settings from arduino 0022 software. I did not change anything in bootloader settings
johnwasser
The Breadboard Arduino doesn't have an auto-reset circuit.  Are you holding the Reset button until you see the "Binary sketch size:" message?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
max891
#4
Aug 11, 2011, 07:45 am Last Edit: Aug 11, 2011, 11:34 pm by Max89 Reason: 1
Hmm...nope...
I only use slave reset from ISP-arduino (lead from 10-th pin to first leg of IC )
Burn bootloader dump :
http://dl.dropbox.com/u/35963789/Bootloader.txt
First blink-scheme uploaded without problems... second (on 12-th pin) faill hard...
Data from uploadnig blink sketch without reset button tricks
http://dl.dropbox.com/u/35963789/blink.rtf
spycatcher2k
Try updating your boards.txt
atmega8.bootloader.high_fuses=0xc8
It updated the bootloader protected area size.
max891
#6
Aug 13, 2011, 10:35 am Last Edit: Aug 13, 2011, 10:43 am by Max89 Reason: 1
Still same....
Bootloader is burned properly , first upload ok, second fail.
Maybe I try avoid bootloader using hex files ?
Or simply I can't use this arduino as ISP.... http://arduino.cc/en/Tutorial/ArduinoISP "Currently, you cannot use an Arduino Uno as an ISP programmer because the optiboot bootloader does not support this sketch. A revision for this is in progress"
