Topic: Burining Bootloader via AVRISP-MKII onto ATMEGA328-AU (Read 19461 times) previous topic - next topic
zenwebb
Yes, the Arduino I am using has the ArduinoISP sketch loaded onto it. I am not using the Uno - I am using a Duemilanove clone from NKC Electronics (product page). Do I still need an auto-reset capacitor?
I have been attempting to follow the official instructions here: http://arduino.cc/en/Tutorial/ArduinoToBreadboard
Creative technologist + OSHW engineer + lover of learning interested in bio+art+tech, form and digital fabrication
32teeth
hmm,
haven't tried via the arduino itself as an isp for this edit.
only AVR ISP mkII and the Pocket Programmer from Spark Fun
i will try when i get home this evening
zenwebb
Any luck? I need to program these chips within the next couple of days :S
32teeth
@h4t
yes, i was able to use the Arduino itself as an ISP.
here is the complete entry in my boards file
sparky.name=Sparky
sparky.upload.protocol=stk500
sparky.upload.maximum_size=32256
sparky.upload.speed=115200
sparky.bootloader.low_fuses=0xff
sparky.bootloader.high_fuses=0xde
sparky.bootloader.extended_fuses=0x05
sparky.bootloader.path=optiboot
sparky.bootloader.file=optiboot_atmega328.hex
sparky.bootloader.unlock_bits=0x3F
sparky.bootloader.lock_bits=0x0F
sparky.build.mcu=m328au
sparky.build.f_cpu=16000000L
sparky.build.core=arduino
notes
1. using an Arduino Uno with the Opti Boot bootloader.
2. successfully able to bootload the ATMEGA328-AU selecting the board above from the boards list
3. after the success of the bootloader, when i attempt to upload a sketch i get 'm328au' is not a recognized device
4. knowing the bootloader was successful but upload sketch failed i was able to upload a sketch by changing the board to simply Arduino UNO (go figure)
5. this was the same on OSX Lion, Windows 7, Vista 64
hope that helps
retrolefty
#19
Aug 16, 2011, 04:31 pm Last Edit: Aug 16, 2011, 04:34 pm by retrolefty Reason: 1
That makes sense to me. Once the bootloader is installed on the chip, it will report itself as a 328p chip to the IDE as the chip signature is coming from the code in the bootloader, not being read from the chip itself. Therefore the IDE must be told to use a Uno board, not the board you added stating it's a 328 chip, that was required just to allow the burn bootloader step, where the signature is being read directly from the chip. The bootloader is effectively lying to the IDE, but because the 328 and 328p are identical from a software aspect it is a innocent 'white lie'.  ;)
Lefty
32teeth
this is the most accurate and clear explanation i have heard. never thought about it as being a false positive!
gregio
hi i was try evrithing but when i try upload bootloader  in arduino 1.0 it give me syntax error at C:\arduino\hardware/tools/avr/etc/avrdude.conf:9610 this eroor what im doing  wrong?
Quwat
Hello I have also followed this whole thread (and checked my work twice). But when trying to upload the boot-loader, i get the following error;
error at \Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf:9235 unrecognized character: " "
Have i left a space in the avrdude file wrongly? Or is it quotation marks placed wrongly; from what i copied ? And yes I checked there weren't quotation's around what I copied.
vladnl
Thanks, this saved my day too :)
@h4t
sparky.name=Sparky
notes
hope that helps
