Loading...
Pages: [1]   Go Down
Author Topic: DFRobot Rover: Drive without USB cable?  (Read 1160 times)
Offline Offline
Newbie
View Profile
Hello!
I have bought the blank DFRobot Rover to introduce myself to robotics and arduino.
My problem is that i cannot power the motors without USB connection although 4 full AA Batteries are inserted. The D2 LED and L LED blinks, it seems to me the board is waiting for input instead just to power both motors trying the "full speed code".
Is there a way to let the bare DFRobot rover power the motors without USB or other shields?
I tried the following example found in http://www.robotshop.com/content/PDF/dfrobotshop-rover-user-guide.pdf (however the motors first starts after connecting USB):
Code:
/* Copy and paste the code below into the Arduino software */
int E1 = 6; //M1 Speed Control
int E2 = 5; //M2 Speed Control
int M1 = 8; //M1 Direction Control
int M2 = 7; //M2 Direction Control
int i;
for(i=5;i<=8;i++)
pinMode(i, OUTPUT);
int leftspeed = 255; //255 is maximum speed
int rightspeed = 255;
analogWrite (E1,255);
digitalWrite(M1,HIGH);
analogWrite (E2,255);
digitalWrite(M2,HIGH);
delay(100);
Logged
Netherlands
Offline Offline
Sr. Member
A naughty mind is a joy forever.
View Profile
I'm not sure since I have no rover to test.
By looking at the schematics, http://www.robotshop.com/content/PDF/dfrobotshop-rover-schematic.pdf, the rover apparently has a switch called S1.
It switches off all power, except... when connected to USB.
Set wrong it might explain the problem.
Logged
Offline Offline
Newbie
View Profile
Thank you for your answer. My goal is to run the code without the USB connected to the rover.
The S1-Switch i already noticed. I have 4x 1.5VAA Batteries in the rover. When i disconnect the usb connections, the motors aren't driving using the code above. (L LED near to PWR,RX,TX blinks 1 time the second and there is a tick sound).
When i take out the batteries, the rover isn't moving (no motor drive only from usb power). When the S1 switch is off, the board has power when there is a USB connection.
But having only the code flashed on it without USB Connection, it seems the rover is waiting for input although i don't need input that it only moves forwards when i switch it on. When i connect the USB, the batteries are in and S1 Switch is on, the robot moves.
How can i run the code without the USB connected in the Rover?
USB Connected?Batteries IN?S1 Switch enabled?Basic Code for max. speed works??
NONONONO
YESNONONO
NOYESNONO
YESYESNONO
NONOYESNO
YESNOYESNO
NOYESYESNO But i want this smiley-sad
YESYESYESYES - I even can send commands via USB/COM
The LEDs on the board are on, when S1 is switched on or the USB connection is in
« Last Edit: August 11, 2011, 04:52:53 am by Schludi » Logged
Offline Offline
Newbie
View Profile
Hey if found it out - one battery was low smiley-lol.... WTF.... smiley-sad . Thx
Funny: Now it's driving in the other direction smiley-lol
Logged
Pages: [1]   Go Up
Print
Jump to:
