Topic: Declaring digital signal (Read 12566 times) previous topic - next topic
Nick Gammon
After a lot of study on arrays, this is what I have come up with.
Code: [Select]
void receiveEvent(int howMany)
 char incoming[4]; // don't really know what the size of a g-code would be, so work on this number :P
       if(i > 4){                       //prevent data corruption in case you accidentally receive more than the array can hold
           incoming[4] = '\0';  //put a null char at the end of the array
Is this any good or should I start studying again  :~
Back to your studies. An array declared of length 4 like this:
Code: [Select]
char incoming[4];
... has 4 bytes:
Code: [Select]
incoming[0]
incoming[1]
incoming[2]
incoming[3]
So your write to incoming [4] will corrupt memory.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Nick Gammon
#76
Aug 28, 2011, 02:49 am Last Edit: Aug 28, 2011, 02:51 am by Nick Gammon Reason: 1
All right. Let me post the new code that I corrected with a lot of help from the posters here. This is in Reprap.
Code: [Select]
void loop
 Wire.beginTransmission (5);
 Wire.send ("G1");
 Wire.send ("G28");
Even if you had the Wire.endTransmission, like this:
Code: [Select]
void loop
 Wire.send ("G1");
 Wire.send ("G28");
 Wire.endTransmission ();
You are now sending 5 bytes ("G1G28"). But your code you recently posted expected 4 (plus a 0x00 at the end). So when you say "don't really know what the size of a g-code would be" you know you have sent 5 bytes, right?
More info:
Nick Gammon
Code: [Select]
  int length;
  while(0 < Wire.available()) // loop through all
     delay(100);
    length = Wire.available();
    for (int i = 0; i < length; i++) {
        incoming[i] = Wire.receive();
Let's work through what would happen if you got 5 bytes (which in fact you are sending from your test program).
You store the first 4 in "incoming" and then notice that you have more than 4 in the inner loop. But the outer loop still has Wire.available() == 1. So the outer loop keeps looping, and the inner loops keeps doing a "break". So this code will go into an infinite loop.
Why use two loops?
More info:
Javaid
To be very honest, that 4 was just a test number.
Let me make it 128. Problem solved  :)
Code: [Select]
char incoming[128];
char length;
This should do.
All right, the next issue.
Code: [Select]
  Wire.send ("G1");
  Wire.send ("G28");
  Wire.endTransmission();
Before we go any further, I am sensing that I might have done it wrong too (no surprises there  :P)
I don't want to send G1 and G28 at the same time or after a fixed interval. I want Arduino to know when G1 come (led ON) and when G28 come (led OFF), which will not happen according to what I have done here. So what should I do  :~
Nick Gammon
Code: [Select]
  Wire.send ("G1");
  Wire.send ("G28");
Did you understand what I wrote above?
Quote
The Wire library only buffers up data and does the actual sending on the Wire.endTransmission ().
In light of that, what effect do you think delay(1000) will have?
More info:
Javaid
Can I say something, I am having a feeling that I am back in school  :)
All in good humor though  :)
It should go like this
Code: [Select]
  Wire.send ("G1");
  Wire.send ("G28");
Is this correct ?
PaulS
Quote
Is this correct ?
No.
Wire.beginTransmission() and Wire.endTransmission() calls are used in pairs. One start, one end.
Javaid
#82
Aug 28, 2011, 04:04 am Last Edit: Aug 28, 2011, 05:02 pm by Javaid Reason: 1
Code: [Select]
 Wire.send ("G1");
 Wire.send ("G28");
Then I guess, like this, right !
Javaid
The LED is still OFF, like it is not receiving anything  =(
What should I do  :smiley-yell:
PaulS
Quote
What should I do
Gee, let me think for a minute.
Ooh, I know. POST YOUR CODE!!!
Javaid
#85
Aug 28, 2011, 09:10 pm Last Edit: Aug 29, 2011, 12:44 am by Javaid Reason: 1
Good idea. Why didn't I think of that  :P
This is in Reprap
Code: [Select]
#include <Wire.h>
//i2c address of the gen 6
int REP_RAP_ADDR = 4;
//my address
int CP_ADDR = 5;
 Wire.begin(4);
 Wire.send ("G1");
 Wire.send ("G28");
And this is in Arduino
Code: [Select]
#include <Wire.h>
//my address
int CP_ADDR = 5;
int ledPin = 2;
 Wire.begin(CP_ADDR);
 Wire.onReceive(receiveEvent); // register event so that anything received on i2c is sent to the serial
 pinMode(ledPin, OUTPUT);
 char incoming[128];
 while(Wire.available() < howMany); // do nothing
   for (int i = 0; i < howMany; i++) {
       if(i < 128){
           incoming[i+1] = '\0';
           Serial.print(incoming);}
   char str1[] = "G1";
char str2[] = "G28";
 if (strcmp(str1, incoming) == 0){
     //turn dispenser on
     digitalWrite(2, HIGH); }
   if (strcmp(str2, incoming) == 0) {
     //turn dispenser off
     digitalWrite(2, LOW);}
PaulS
Code: [Select]
        if(i > 128){                       //prevent data corruption in case you accidentally receive more than the array can hold
            incoming[128] = '\0';  //put a null char at the end of the array
So, if the array is full, write beyond the end of it. How's that working for you?
You are using strcmp () to compare what is in incoming to some fixed strings. The strcmp function is one of a family of string functions. Do you know what a string is?
I'll tell you. It's a NULL terminated array of characters. Look through your code. Where do you NULL terminate your array of characters?
If you don't NULL terminate the array, IT IS NOT A STRING (string), so you can't expect proper behavior of the strcmp function.
One of the arguments for the receiveEvent function is the number of characters to expect. They may not all have arrived by the time the function is called. Why are you not reading that number of characters?
Code: [Select]
Then, read the characters that Wire sent:
Code: [Select]
        if(i < 128)
            incoming[i+1] = '\0';  //put a null char at the end of the array
Then, print what you got, and use it.
Javaid
#87
Aug 28, 2011, 09:44 pm Last Edit: Aug 28, 2011, 10:32 pm by Javaid Reason: 1
So it should go like this, right !
I should edit the main code too.
Code: [Select]
 char incoming[128];
       if(i < 128){
Before I write the strcmp(), I have a question to ask. G1 and G28 are g-codes that the Reprap will be sending to Arduino and they are in this form:
G28 X0 Y0
G1 X10 Y10
What do you suggest a proper way of comparing the incoming data would be ?
AWOL
Code: [Select]
if(i < 128){
Yous still don't have a "incoming [128]".
Can we ease-up on the "20 questions" style now please?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Javaid
To be very honest, I never follow what you say. And I am pretty sure that the problem is on my end.
Will you please tell me where the problem is and where I went wrong (again  :~)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
