Topic: What kind of board/shield do you guys want? (Read 11076 times) previous topic - next topic
liuzengqiang
Just a thought, the matrix holes may be perfect for male headers ready for some wire wrapping.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
robtillaart
As 12 august is the 30th anniversery of the PC -
I would like a coprocessor shield for floating point operations with a 8087 or another one. It should be faster than the internal floats routines of Arduino of course.
Some pseudocode
// y = sin(3.45);
Coprocessor.setX(3.45 );
Coprocessor.sinX();
y = Coprocessor.getX();
// y = ln(10);
Coprocessor.setX( 10);
Coprocessor.lnX();
// y = ln(x) * sin(x);
Coprocessor.setX( x);
Coprocessor.lnX();
Coprocessor.YisX();
Coprocessor.setX(x);
Coprocessor.sinX();
Coprocessor.mul();
A small test shows that 10000  y = sin(x)  takes 1159 millis.  => 1 sin() call including assigning 116 micros.
So the setX()  the getX() and the sinX() should not take more than 116 micros.
assuming bytes can clocked in/out at 1 Mhz:
A float == 32bit  so  at least 64 micros are needed for set/get,
leaves 52 micros, at least 8 micros to send the command code (assume 256 command codes)
leaves 44 micros to calc the sinX()
Q: what is the maximum speed of the SPI bus?
Googled this while writing the above ..
- http://www.hvwtech.com/products_view.asp?ProductID=570 -
- http://www.arduino.cc/playground/Code/Fpu -
- http://www.micromegacorp.com/downloads/documentation/uMFPU-V3_1%20Arduino.pdf -
  * I like the serial debug option !!
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
retrolefty
Quote
I always thought the below coprocessor would be a very cool thing to have on a shield. It does a lot of other things along with floating point, GPS numa parsing, 2 12 bit A/D pins, serial port, and a lot more. Can interface with a arduino via SPI (fastest method), I2C, or serial. They even have a arduino software library download avalible. What I've never seen is a bench mark on it's floating point ops Vs the AVR software floating point results.
http://www.micromegacorp.com/umfpu-v3.html#features
http://www.sparkfun.com/products/8129
Lefty
bubulindo
* landLine telephone Switch shield
Can switch on/off landlines, optionally with a RTC
Here's a brilliant idea.
One other nice Idea would be to hack into the caller ID when receiving a phone call and automatically disconnect the call if the number didn't match the stored numbers in memory. This would make my day, shutting down the line to those **#¤&%#%&"#¤% automated telemarketers.
This... is a hobby.
robtillaart
@Lefty,
What is the max speed of SPI (in practice) ? 2Mb/sec?
scanned through the documentation a bit but found no comparison/performance chart. Some examples I saw keep the calculations as much in the FPU as possible, mind you 128 floating point registers is quite a bit (especially compared to the 2K RAM of Arduino).
And a 12 bit ADC. (4096 steps)
Unfortunately they are not in stock yet. Think a MathShield is a winner.
Rob Tillaart
robtillaart
@bubulindo
Quote
My main purpose was to switch the incoming line off during the meals. (and during the match of the day and ...)
Rob Tillaart
liuzengqiang
I thought telezapper does that. I saw their ad like 10 years ago. I might still have one in a box but I don't have a land line anymore. If you are in US, look in dollar stores they could still have them. I don't know if it works.
retrolefty
@Lefty,
That is determined by the arduino SPI clock setting, as it would be the master in this case. I think 4mhz is the max clock speed arduino uses?
And lots of other features. The GPS numa sentence parsing would sure off load the arduino in applications using a GPS.
Other places sell this chip.  http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/fpu/List/1/Default.aspx?SortField=ProductName,ProductName
Lefty
Chagrin
Don't forget about the I2C GPS Shield.
retrolefty
Didn't forget, it's on my wish list.
Lefty
skywalk
Having an UPS like (?Energy Harvesting?) power supply would allow Arduino going into real world business!
I found only one (real world/professional/semiprofessional) usable Arduino based part wich is also
usable inside small housings without unpractical Power connectors
the -> mosquino (use Search inside Forum) would be a good reference to start with, for further Development!
Greetz
Mark Bramwell
I would like to cast my vote for a telephone interface shield.
It should have:
(a) ring detect circuit,
(b) the ability to connect disconnect from the line,
(c) encode and decode DTMF.
The arduino is perfect for remote control but lacks any sort telephone interfacing with remote access.
robtillaart
Quote
(d) able to play prerecorded mp3's  after some keypress  (to build an automated telemarketer ;)
Rob Tillaart
bubulindo
Quote
Hmmm,
Quote
Or ANTI-telemarketer!    I really like the idea of sending the intercept three-tone whenever the phone rings. Your friends will know better, but telemarketers will think you line is disconnected.
http://en.wikipedia.org/wiki/Special_information_tones#SIT_example_recordings_and_encoding_scheme_.5B1.5D
See (hear):  "Intercept"
Something like this -> http://www.youtube.com/watch?v=hllDWSbuDsQ LOL Epic.
This... is a hobby.
justjed
Hey, how about a random number shield.
How hard is it to come up with some cesium atoms? :)
Maybe something resembling LavaRnd?
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
