Topic: need help with AttachInterrupt and EEPROM (Read 6156 times) previous topic - next topic
nyg78
My code is in Reply #10.  Do you (or anybody else) have any suggestions on what to change so it will remember what the last pattern displayed was when it is turned off then back on again?  This is harder than I thought it would be.
PaulS
Quote
And there have been many posts since then pointing out problems. Have you corrected them? If so, post the new code. If not, fix them.
Quote
Only because you are making it hard. It really isn't. Read the value in setup(). Write the value ONLY WHEN IT ACTUALLY CHANGES in loop().
nyg78
Tried a few things, still getting nowhere.  Here's my current code:
Code: [Select]
*  bike light with pattern reverse button and pot
#include <EEPROM.h>
int addr = 0;
byte pattern;
int potPin = 0;                 // input pin for the pot
int timer = 50;                 // you can adjust the numbers below to set the max and min for the speed adjustment
int x = 10;                    // sets the max speed (0 = fast) the lower the number the faster it can go
int y = 300;                   // sets the min speed (100 = slow) the higher the number the slower it can go
int switchPin = 2;              // switch is connected to pin 2
int switchPin2 = 3;             // switch to reverse pattern is connected to pin 3
int led1Pin = 11;
int led2Pin = 10;
int led3Pin = 9;
int led4Pin = 8;
int led5Pin = 7;
int led6Pin = 6;
int led7Pin = 5;
int led8Pin = 4;
int val;                        // variable for reading the pin status
int val2;                       // variable for reading the delayed status
int buttonState;                // variable to hold the button state
int val_rev;                        // variable for reading the pin status
int val2_rev;                       // variable for reading the delayed status
int buttonState_rev;
int lightMode = 0;              // What mode is the light in?
  pinMode(switchPin, INPUT);    // Set the switch pin as input
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(led3Pin, OUTPUT);
  pinMode(led4Pin, OUTPUT);
  pinMode(led5Pin, OUTPUT);
  pinMode(led6Pin, OUTPUT);
  pinMode(led7Pin, OUTPUT);
  pinMode(led8Pin, OUTPUT);
  pattern = EEPROM.read(0);
  Serial.begin(9600);           // Set up serial communication at 9600bps
  buttonState = digitalRead(switchPin);   // read the initial state
void loop(){
  val = digitalRead(switchPin);      // read input value and store it in val
  delay(10);
    timer = 0;
for ( int i = 0; i < 10; i++ ) {
    timer += analogRead(0);               // reads the pot and sets the timer to the value
    timer = timer / 10;
    timer = map(timer, 0, 1023, x, y);   // maps the timer value to the max and min values set above with x and y
  val2 = digitalRead(switchPin);     // read the input again to check for bounces
  val_rev = digitalRead(switchPin2);      //REVERSE read input value and store it in val
  delay(10);
  val2_rev = digitalRead(switchPin2);     // read the input again to check for bounces
if (!val_rev) {                 // make sure we got 2 consistant readings!
    buttonState_rev = !buttonState_rev ;  // save the new state in our variable
  if (val == val2) {                 // make sure we got 2 consistant readings!
    if (val != buttonState) {          // the button state has changed!
      if (val == LOW) {                // check if the button is pressed
      EEPROM.write(0, pattern);
        if (lightMode == 0) {          // if its single chase
          lightMode = 1;               // single chase then back
          if (lightMode == 1) {        // if its single chase then back
            lightMode = 2;             // off
            if (lightMode == 2) {      // off
                  lightMode = 0;
    buttonState = val;                 // save the new state in our variable
  // Now do whatever the lightMode indicates
  if (lightMode == 0)  { // single chase
    if ( buttonState_rev == LOW ) {
    digitalWrite(led1Pin, HIGH);
    delay(timer);
    digitalWrite(led1Pin, LOW);
    digitalWrite(led2Pin, HIGH);
    delay(timer);
    digitalWrite(led2Pin, LOW);
    digitalWrite(led3Pin, HIGH);
    delay(timer);
    digitalWrite(led3Pin, LOW);
    digitalWrite(led4Pin, HIGH);
    delay(timer);
    digitalWrite(led4Pin, LOW);
    digitalWrite(led5Pin, HIGH);
    delay(timer);
    digitalWrite(led5Pin, LOW);
    digitalWrite(led6Pin, HIGH);
    delay(timer);
    digitalWrite(led6Pin, LOW);
    digitalWrite(led7Pin, HIGH);
    delay(timer);
    digitalWrite(led7Pin, LOW);
    digitalWrite(led8Pin, HIGH);
    delay(timer);
    digitalWrite(led8Pin, LOW);
  else  { // reverse chase
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
if (lightMode == 1)  { // single chase then back
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
  else  {  // reverse single chase then back
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
  if (lightMode == 2) { // all off
Since I have a pattern called "0" would I need to change that in order for EEPROM to read and write to "0" or is that something different?
nickgammon
Quote
Code: [Select]
byte pattern;
They are the only references to pattern in your code. What makes you think pattern will ever change?
You don't alter the value anywhere. You don't use the value you read from EEPROM, and you don't save the value from the button.
Also you don't check if pattern has changed before you write it.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
CrossRoads
How's the hardware going for that project?
nyg78
As soon as I get this part figured out, it's a go.
nyg78
Quote
Code: [Select]
byte pattern;
I get what you are saying Nick.  I have looked at the examples in my Arduino 0022 program and at Playground, but I don't see how to do it from those examples.  I'm completely lost.  Never used EEPROM before.
nickgammon
The EEPROM is just another form of memory. You have 1024 bytes of it on the Atmega328 numbered from 0 to 1023.
Once written to, it remembers what you put there, even after a power-off.
You simply choose a byte number where you want to store something. eg.
Code: [Select]
EEPROM.write (55, 123);
That would save the number 123 into position 55 in the EEPROM.
Then when you power off the Arduino, and start it up again, you can get that back ...
Code: [Select]
byte mysecretnumber = EEPROM.read(55);
Now you would get back 123 into the variable mysecretnumber.
That's it basically. So you need to save something important, when it changes, and then you can get it back next time. Bear in mind that after 100,000 writes that memory location might become "worn out" so you don't keep writing the same thing to it, especially not every time around the main loop.
nyg78
Ok, so this:
Code: [Select]
EEPROM.write (0, pattern);
would save "pattern" to position 0 then?  Then use this:
Code: [Select]
byte pattern = EEPROM.read(0);
to recall that pattern?  Now, because I have a pattern called 0, will I need to change the EEPROM position number, or won't that matter?
nickgammon
What do you mean, "a pattern called 0"?
nickgammon
I think you are getting confused here. Variables contain numbers. They aren't "called" numbers.
Let me give you an example. Say you live at 5 High Street. That is your address. Now if I want to send you $5 I send it to 5 High Street. But the $5 and the street number (although both 5) are different things. If I want to send you $10 I don't mail it to 10 High Street, do I? Because you don't live there.
retrolefty
Quote
No, you have a byte of data written into memory address zero of the EEPROM memory area. The value of that memory location came from the value of the variable you named pattern in your sketch. If you loaded a different sketch into your board, there may very well no longer be a variable called pattern, but the contents of address 0 of EEPROM memory would still contain a byte of data of a value that is was in the pattern variable when you last wrote it to EEPROM memory. The EEPROM has 1024 memory locations each able to store a single byte of data, the valid address values are 0-1023 and the contents of the data you can store at any given address can be 0-255.
That help?
Lefty
retrolefty
Well I live at 175 Brighton St., when can I expect our check for $175?  :D
nickgammon
In short, no you don't change it. Think of my example of the street numbers. The pattern, whether it is zero or something else, is stored and recalled from EEPROM location zero (in this example).
nickgammon
Ah yes, Lefty. But what is the house *called*?
