Loading...
Pages: 1 [2]   Go Down
Author Topic: How to control a video  (Read 817 times)
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
What's with the lockLow stuff? Verify that you can read the PIR status correctly, all the time, every time, before trying to take any action based on that status.
Logged
Offline Offline
Newbie
View Profile
I put
Code:
void loop(){
  //digitalWrite(ledPin, HIGH);
  //Serial.println(digitalRead(pirPin), DEC);
  Serial.println(lockLow, DEC);
SERIAL MONITOR output
Code:
calibrating sensor .. done
SENSOR ACTIVE
1
motion detected at 2 sec
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Code:
Why? Do you care what value lockLow has? It seems to me that you want to print the value of digitalRead(pirPin).
Logged
Offline Offline
Newbie
View Profile
Oh, I'm sorry, i wrote:
Code:
void loop(){
  if(digitalRead(pirPin) == HIGH){
SERIAL MONITOR OUTPUT
Code:
calibrating sensor ... done
SENSOR ACTIVE
1
motion detected at 3 sec
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
...a lot  of 1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1      HERE, THERE IS ONE MOVEMENT AND LED BLINKS
0
0
0
0
0
0
0
0
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
0
0
0
0
0
0
0
1
1
1
1
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Try this code:
Code:
int currPirState = LOW;
int prevPirState = LOW;
   currPirState = digitalRead(pirPin);
   if(currPirState != prevPirState)
      // A change occurred
      if(currPirState == LOW)
         Serial.println("PIR just went LOW");
         Serial.println("PIR just went HIGH");
   prevPirState = currPirState;
Does it print the messages at the right time, and only the right time?
Logged
Offline Offline
Newbie
View Profile
Code:
SENSOR ACTIVE
PIR just went HIGH  ---- static without motions
PIR just went LOW   ---- 1 motion
PIR just went LOW  -----
PIR just went HIGH ----- static
I think it doesn't print right messages, if there is only one movement, it should print:
Code:
Right?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
<snip>
Right?
I think that I agree with you. So, the next question is how far apart are the messages, with respect to the motion. Make some changes to the code.
Code:
         Serial.print("PIR just went LOW at ");
         Serial.println(millis());
         Serial.print("PIR just went HIGH at ");
Let's see whether the PIR switch needs debouncing. I wouldn't think so, but maybe it does.
Logged
Offline Offline
Newbie
View Profile
Output:
Code:
SENSOR ACTIVE
PIR just went HIGH at 3109
PIR just went LOW at 6784
PIR just went HIGH at 6816
PIR just went LOW at 6863
PIR just went HIGH at 7110
PIR just went LOW at 7181
PIR just went HIGH at 7698
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
