Topic: GATOR : New Board (Read 7672 times) previous topic - next topic
retrolefty
The zener does have a small amount of reverse leakage current, enough to bleed off any accumulated charge.
Sounds like there could be quite a slow transition time from high to low for say a switch contact wired to +5vdc?
Lefty
RuggedCircuits
Fortunately there isn't a lot of capacitance to bleed off. Figure worst case of 100pF for the diode and 10pF for the I/O pin, charged to 5V gives a charge storage of 0.55nC. Discharging through a 1uA reverse leakage current gives a total discharge time of 550us. That's not a very long time relative to pushbutton press/release times.
EmilyJane
#32
Jul 23, 2009, 10:28 pm Last Edit: Jul 23, 2009, 11:18 pm by EmilyJane Reason: 1
Okay, I'm not as dumb as I thought, I just couldn't believe you were relying on the zener's reverse leakage to pull the pin down. How would a resistor to ground in parallel with the zener affect the zener's capability to protect the input?
Edit:
Ahh, I see the source of some of my confusion, Andy's schematic is not a representation of the way your protection circuitry is connected. That explains everything. Thanks for the link : http://www.ruggedcircuits.com/html/mb324p.html#IOPins.
ArduinoAndy
The above schematic is now corrected but I just can't fire my cousin for his drafting mistakes.  ;D ;D ;D
Circuit D, I believe, might need a 10K pulldown?
8-) 8-) 8-)
"Never trust an Internet bully who insults and makes fun of your level of intelligence."
RuggedCircuits
Nope, no pulldown required in Circuit D because of the zener diode discussion above.
ArduinoAndy
Sources of power for the Gator and Gator+
There are two sources of power for the Gator.
One is from the USB port and the other one is the external 8-15 VDC supply input.
Question #1. What happens if both supply inputs(USB & External) are connected at the same time?
Question #2. Is there any "backfeeding" of supplies if both are connected at the same time?
8-) 8-) 8-)
RuggedCircuits
External power takes precedence over USB.
Backfeeding is prevented by design. Specifically, no more than 5 microamps of current can flow from one supply to the other.
ArduinoAndy
Yes, it uses a Serial1 object in addition to the Serial object to access the second hardware serial port, just like the Mega uses Serial1, Serial2, etc.
That support is not in the 0016 release of the Gator Arduino tools but will be in 0017
What is the ETD when the release 0017 will be available?
8-) 8-) 8-)
RuggedCircuits
We're following the Arduino software releases so when 0017 comes out, our latest changes will also come out in the "GATOR version".
ArduinoAndy
Is there a way to access and use the serial port (USB/PC serial port 0) on the Gator/Gator+
without using a PC? My application calls for using two TTL serial hardware ports.
RuggedCircuits
No, PD0/PD1 are hardwired to the USB port.
I suppose you *could* solder some wires onto the board for PD0 and PD1 and bring those out for your own use :-)
ArduinoAndy
What are Arduino digital pin number(s) that are assigned to
the Gator's Serial Port 0 (default USB port)  PD0 & PD1 pins?
I know that by soldering wires to these pins voids
my warranty on the Gator?
BTW ... Soldering two wires to the surface mount 324P
is not an easy task for those attemping to try it!
8-) 8-) 8-)
RuggedCircuits
Since those are dedicated serial port pins they do not have Arduino digital pin numbers. You can always add them yourself by editing the hardware/cores/arduino/pins_arduino.c file.
Yes, those lines are not externally protected thus if you apply overvoltage or negative voltage from an outside wire then you run the risk of damaging the AVR or the FT232 device.
It is probably easier to solder some thin wire (e.g., 30AWG) into one of the vias for those lines. This image shows two accessible locations for soldering to the TXD and RXD lines:
