Topic: Analog line meter (Read 1 time) previous topic - next topic
DirtGambit
Hi, Im trying to implement and analog line meter that takes a value from an LDR. I have drew the arc but I dont understand how I can get the line to move depending on what value comes from the LDR. a pointer in the right direction to  what i should be looking up is appreciated.
Grumpy_Mike
Quote
What line, can you be more descriptive about what hardware you have got or what you want.
DirtGambit
The arc at the bottom left is where i want my meter, it will take a value from the LDR between 0 - 1023 and the line will move from the left around the arc.
robtillaart
Do you want to convert the value (0..1023) to an angle?
assuming you do:
consider 0,0 as the midpoint of the arc, and R its radius,
float alpha = 180 - analogRead(A0) / 5.68333;
int x = R * cos(alpha):
int y = R * sin(alpha);
line 0,0, x, y;
you need to keep the XY value to clear the line before drawing the next;
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
DirtGambit
Hi, thanks for the help, Im still having problems
When I use your code i get a cant convert float to int
so I tried after converting value from LDR, float angle = 180 - (LDR / 5.68333);
Code: [Select]
float x = 90 + 65 * cos(angle);
float y = 490 + 65 * sin(angle);
line (90,490,x,y);
Now I got a perfect line from midpoint of arc to edge of arc, but the angle in the debug output: example 156.732 doesnt match where the needle in the meter is, the needle is shifting all the time even though the LDR is giving a constant value?
robtillaart
#5
Aug 13, 2011, 01:54 am Last Edit: Aug 13, 2011, 02:01 am by robtillaart Reason: 1
What is the range of the LDR ? minimum and maximum?
ok from 0-1023
My mistake sin() and cos() needs radians. OK try this:
float angle = 3.14159265 - (LDR / 325,6310);
line (90,490,x,y);
Rob Tillaart
DirtGambit
Thats worked great, the needle was going around the bottom of the arc so I just done a -325.6310 and that put the needle in the proper position, Im getting data through every 3 seconds so the needle doesn't move in a smooth fashion but the data is being collected long term so that doesn't matter, My trig is so bad I think I'll need to spend some time brushing up on it, thanks for your help.
robtillaart
You can do some smoothing like this:
Code: [Select]
  float newAngle =  3.14159265 - (LDR / 325,6310);
  #define  ALPHA = 0.2;
  static float angle = ALPHA * newAngle + (1-ALPHA ) * angle;  // changes smoothly to new value, speed depends on ALPHA
  int x = 90 + 65 * cos(angle);
  int y = 490 + 65 * sin(angle);
  line (90,490, x, y);
OR average multiple readings (takes more time)
int LDR = 0;
#define NR_LDR_READS  4
for (uint8_t i =0; i< NR_LDR_READS; i++) LDR += analogRead(LDRPIN);
LDR /= NR_LDR_READS;
etc.
Rob Tillaart
DirtGambit
Played around with the formula a bit, I got some nice smooth motion with alpha set to 0.950, would probably be better to take an average though, Im going to get the arduino system to do a bit more processing, get a background template and just have processing do the data representation.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
