ok, so the OS im making is 4KB in size (the answer to my last question was aproxamately 5000 lines of code,BTW.)
and although i can recieve numbers from 0-9, i have this problem with my dialog box.
the code for the box:
int entry()
Serial.println("|I|please enter |");
Serial.println("|I|a 3 digit no:|");
Serial.print("|w| ");
int felds[3];
for(int times=1;times==3;times)//3 loop, no change
if (Serial.available())//is there new data?
char ch2 = Serial.read();//picup data
if(ch2 >= '0' && ch2 <= '9') // is this an ascii digit between 0 and 9?
felds[times]=(ch2 - '0');//convert to number
Serial.print(felds[times]);//print entered number
times++;//add 1 to current number
}//loop out
Serial.println(" |");//end the line
int output=((felds[0])+(felds[1]*10)+(felds[2]*100));//compile final number
return output;
I know its something stupid, I know it. I just can't find it!
this compiler doesn't seem to give as much errors or warnings like Java does. sometimes i'm like, how can that even run?
output:
please type in:5 seconds in order to acess the OS.
|_____L-OS_(by laurens!)_____|
|the OS you wish you invented|
|M| Main menu |
|1|remote codes |
|2| settings |
|3| RUN(5 sec.) |
|I| Selected: 2 +------------+
|M|Settings menu|
|0|to main menu |
|1|wall distance|
|I| Selected: 1 +------------+
|I|please enter |
|I|a 3 digit no:|
|w| |
note the end bit. that empty space is where the number being entered is supposed to be(while you are typing) it appears it puts a space instead of the actual letter.
that last number is so i can see what the number entered was. it is 0,as you can obviously see.
