Topic: Problem with the card Arduino (Read 743 times) previous topic - next topic
maxou59200
Hello my name is maxence.
I from france and I problem with arduino
here is the error code
<quote>
Binary sketch size: 1018 bytes (of a 30720 byte maximum)
C:\Documents and Settings\William\Bureau\arduino-0022\arduino-0022\hardware/tools/avr/bin/avrdude -CC:\Documents and Settings\William\Bureau\arduino-0022\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM4 -b57600 -D -Uflash:w:C:\DOCUME~1\William\LOCALS~1\Temp\build7460181327798058155.tmp\Blink.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         System wide configuration file is "C:\Documents and Settings\William\Bureau\arduino-0022\arduino-0022\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM4
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 57600
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done.  Thank you.
</quote>
maxou59200
thank for the response
I precise that the RX and TX LED does not light
maxou59200
Coding Badly
Have you worked through the troubleshooting guide?
http://www.arduino.cc/en/Guide/Troubleshooting#upload
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
