Topic: non-class type error (Read 663 times) previous topic - next topic
N314
(unfinished) sketch:
Quote
#include <seg.h>
Seg seg();
  digitalWrite(2, HIGH);
  seg.one();
  digitalWrite(2, LOW);
  delay(2);
  digitalWrite(3, HIGH);
  seg.two();
  digitalWrite(3, LOW);
  delay(2);
  digitalWrite(4, HIGH);
  seg.three();
  digitalWrite
Header File:
Quote
#ifndef Seg_h
#define Seg_h
#include "WProgram.h"
class Seg
  public:
  Seg();
  void one();
  void two();
  void three();
  void four();
  void five();
  void six();
  void seven();
  void eight();
  void nine();
  void zero();
  private:
#endif
Source File:
Quote
#include "Seg.h"
 Seg::Seg()
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
void Seg::one()
  digitalWrite(6, HIGH);
  digitalWrite(7, LOW);
  digitalWrite(8, LOW);
  digitalWrite(9, HIGH);
  digitalWrite(10, HIGH);
  digitalWrite(11, HIGH);
  digitalWrite(12, HIGH);
  digitalWrite(13, HIGH);
void Seg::two()
  digitalWrite(6, LOW);
  digitalWrite(8, HIGH);
  digitalWrite(9, LOW);
  digitalWrite(10, LOW);
  digitalWrite(12, LOW);
So on and so forth to 9.
This is a library to control a 4 digit, 7segment led display.
When I try to compile what i have so far it highlights "  seg.one();" and says "seg_seg:11: error: request for member 'one' in 'seg', which is of non-class type 'Seg () ()'"
Any ways to fix this?
Thanks
johnwasser
This declares a function which RETURNS a Seg:
Code: [Select]
Seg seg();
I think what you intended to do was declare "seg" as an instance of Seg:
Code: [Select]
Seg seg;
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
robtillaart
Post you r code so we can see all of it.
And please use the # button for posting code to get it proper tagged with [ code] tags, looks so much better.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
N314
It was too long so i couldnt post it, i only cout out the repetitive stuff.
N314
I did "Seg seg;" instead of "Seg seg();" and it worked. Thanks
