Here is a nice one that use the I2C bus
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230619695873&ssPageName=STRK:MEWAX:ITHere is a sketch I wrote last weekend to check out it's performance. Works great
/* Basic testing and check out sketch for a TI ADS1115 4 channel 16 bit I2C analog to digital converter chip.
Reads voltage at desired range on desired channel and displays it on serial monitor. Also allows comparitor
to output a active low signal pin if enabled.
Leftyretro 08/10/11
#include <Wire.h>
int topofScale; // global to use adc range value to display millivolt reading conversion
int hiCompair = 17000; // high setting for comparitor threshold value, must be higher then loCompair 32767
int loCompair = 11000; // low setting for comparitor threshold value, must be lower then hiCompair -32768
Wire.begin(); // join I2C bus
Serial.begin(38400); // initialize serial communication
setadcConfiguration(); // configure ADS1115 chip for range, channel input, and comparitor options desired
int rawValue; // holds 16 bit result read from A/D device
int scaledValue; // to convert to millivolts
Serial.print("Analog input #1 counts = ");
rawValue = getadcReading(); // read current A/D value
Serial.print(rawValue);
Serial.print(" Millvolts = ");
scaledValue = map(rawValue, 0, 32767, 0, topofScale); //convert raw adc counts to millivolts
Serial.print(scaledValue);
Serial.println(" Hit any key to continue");
while(Serial.available() < 1) {} // wait for user keystroke
while(Serial.available() > 0) {byte userKeys = Serial.read();} //read keystrokes
int getadcReading() // read 16 bit analog voltage reading
int data;
int deviceAdd = 0x48; // ADS1115 address with address pin grounded
Wire.beginTransmission(deviceAdd); // transmit to I2c device address
Wire.send(0x00); // point to device register 0
Wire.endTransmission(); // stop transmitting
Wire.requestFrom(deviceAdd, 2); // request 2 bytes from slave device
while(Wire.available()) // need two bytes, MSB and LSB of converstion value
data = Wire.receive(); // get MSB of reading
data = data << 8; // shift it to high byte of data
data = data + Wire.receive(); // add LSB to data
return data;
void setadcConfiguration()
/* uncomment one desired voltage input range */
int confWord= 0x0000; topofScale = 6144; // +/-6.144 vdc range, electrical limit = Vcc
//int confWord= 0x0200; topofScale = 4096; // +/-4.096 vdc range
//int confWord= 0x0400; topofScale = 2048; // +/-2.048 vdc range
//int confWord= 0x0600; topofScale = 1024; // +/-1.024 vdc range
//int confWord= 0x0800; topofScale = 512; // +/-.512 vdc range
//int confWord= 0x0A00; topofScale = 256; // +/-.256 vdc range
/* uncomment one desired channel input
This also sets sample rate to 860 SPS and turns on continous conversion mode. */
confWord = confWord | 0x00E0; //input wired to + AIN0 - AIN1, diff +/- max range
//confWord = confWord | 0x30E0; //input wired to + AIN2 - AIN3, diff +/- max range
//confWord = confWord | 0x40E0; //input wired to + AIN0 - gnd, single ended, 0 to +max range
//confWord = confWord | 0x50E0; //input wired to + AIN1 - gnd, single ended, 0 to +max range
//confWord = confWord | 0x60E0; //input wired to + AIN2 - gnd, single ended, 0 to +max range
//confWord = confWord | 0x70E0; //input wired to + AIN3 - gnd, single ended, 0 to +max range
/* uncomment one desired comparator options
active low ready pin, window mode = input voltage is inside window values
active low ready pin, traditional = voltage raised above or fell below set values */
//confWord = confWord | 0x0003; //disable comparitor
//confWord = confWord | 0x0008; //enable comparitor in traditional comparator mode
confWord = confWord | 0x0018; //enable comparitor in window comparator mode
//send configuration word to device
Wire.beginTransmission(deviceAdd); // transmit to ADS1115 device
Wire.send(0x01); // point to configuration register
Wire.send(highByte(confWord)); // sends MSB of configuration word
Wire.send(lowByte(confWord)); // sends LSB of configuration word
//send low threshold value word to device
Wire.send(0x02); // point to low threshold register
Wire.send(highByte(loCompair)); // sends MSB of low threshold word
Wire.send(lowByte(loCompair)); // sends LSB of low threshold word
//send high threshold value word to device
Wire.send(0x03); // point to high threshold register
Wire.send(highByte(hiCompair)); // sends MSB of high threshold word
Wire.send(lowByte(hiCompair)); // sends LSB of high threshold word
Lefty
