Topic: Using Atmega328 on it's own doesn't work (no arduino board) (Read 4518 times) previous topic - next topic
dc42
#15
Aug 19, 2011, 12:16 am Last Edit: Aug 19, 2011, 12:19 am by dc42 Reason: 1
If you look at the Arduino Uno schematic http://arduino.cc/en/uploads/Main/arduino-uno-schematic.pdf you can see the connections between the 6-pin header (labelled ICSP) and the atmega328 (labelled ZIC1). Use the same connections on your own hardware. Yes, RST goes to the Reset pin, and you also need a 10K pullup resistor between Reset and Vcc. VTG goes to +5v.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
