Author Topic: Interrupts and include headers  (Read 301 times)
I have arduino 022 and I'm using some interrupt function
when I disable //#include <avr/interrupt.h > in my sketch
It still compiles fine.
Is it automatically loading or did they change stuff in 022 ?
Seattle, WA USA
Seattle, WA USA
Change stuff from what version?
Actually the question should be why does it work without the header file?
Seattle, WA USA
Seattle, WA USA
Without seeing the sketch, any answer would just be guesswork.
Here ya go smiley
// Blink Led using Timer2 Overflow interrupt
//#include <avr/io.h >
#define PS1024 0x07 // Prescaler 1024
volatile int Iscaler = 0;
int ledpin= 7 ;                                         // Change this for your led default=13
volatile int state = 0;
// 16 Mhz / 1024 / 256 is Iscaler=61 for about 1 sec
ISR(TIMER2_OVF_vect)                                    // Timer2 Overflow interrupt
  Iscaler += 1;
  if (Iscaler == 61)
    Iscaler = 0;                                        // Reset the counter
    state^=1;                                           // Change state for Led
    digitalWrite(ledpin,state);                         // and update the Led
  pinMode(ledpin, OUTPUT);
  TCCR2A = 0;                                           // Normal mode
  TCCR2B =PS1024;                                // Timer2 Prescaler /1024
  TIMSK2 |= (1 << TOIE2);                               // Timer2 Overflow Interrupt Enable
  TCNT2 = 0;                                            // Tmr overflow 256
  sei();                                                // Enable interrupts
void loop()                                             // Here we can do other stuff
{                                                       // while the led keeps blinking
« Last Edit: August 17, 2011, 02:08:15 pm by tubos » Logged
Seattle, WA USA
Seattle, WA USA
Hold down the shift key when clicking the verify button. You will get lots more output, including the path where the temporary files are created during the compile process. One of the files will be a cpp file created from your sketch. You will be able to see what the IDE does to your sketch, including what header files it adds. Some of them include other stuff, so you may have to dig to see where interrupts.h gets included, if indeed it does.
Thx for the useful tip.
