I realise this post is a bit old now but i dont think it's uVGA board because mine doesn't work with Duino in SPI either, it works fine with PIC though
http://www.MicroVGA.com/arduino
This sketch is very basic test of the MicroVGA.
Before running it, please make sure the MicroVGA is connected
properly to the arduino and it is configured for SPI mode
using built-in setup tool.
The demo should SLOWLY display "U" character infinitely.
If something else is displayed, there is a problem with
noise on SCK pin. Or something else...
int pin_cs = 8;
int pin_sck = 13;
int pin_rdy = 9;
int pin_mosi = 12;
int pin_miso = 11;
// Other experimental variant:
int pin_cs = 0;
int pin_sck = 7;
int pin_rdy = 1;
int pin_mosi = 5;
int pin_miso = 6;
// The setup() method runs once, when the sketch starts
// initialize the digital pins used for the MicroVGA
pinMode(pin_cs, OUTPUT);
pinMode(pin_sck, OUTPUT);
pinMode(pin_mosi, OUTPUT);
pinMode(pin_miso, INPUT);
// the loop() method runs over and over again,
// as long as the Arduino has power
int i;
digitalWrite(pin_cs, LOW);
// wait for a second
// this is required to make sure the MicroVGA is idle
// normally there would be loop, but to keep this
// sketch simple, we have replaced it with delay
// now output 8 bits using software SPI
for (i=0;i<8;i++) {
digitalWrite(pin_mosi, i&1 ? LOW : HIGH);
delay(10); // wait for a while
digitalWrite(pin_sck, LOW);
digitalWrite(pin_sck, HIGH);
Having since tried this software SPI code, uVGA does work, but the library doesn't still
