Pages: [1] 2 3 ... 8   Go Down
Author Topic: Arduino AC Power Shield!  (Read 9064 times)
Hi All,
After some work I did with triacs and dimming, I have made a AC power shield!  It has 4 triac driven outputs, my current prototype can only handle about 1A per channel, but The final version I am hoping for 2.5A or more (300W).  It also includes a zero-cross detection circuit to be able to use an interrupt and dim AC devices. I have 2 or 3 prototypes for sale (will work fine for testing and simple use) for $25.  Please let me know if you are interested an have the time in the next week to test this and let me know if I should make any changes before I order a first production batch.  I am hoping to keep the price around $30.
The only problem I had with the prototype batch is the routing of the pins...  I am not sure if I should do a separate female header row (like the prototype shield) or find some long tail female headers to go through.
Please let me know if you are interested in testing one of the prototypes (only charging to recoup some of my cost - I will make sure you get a big discount on the final version!).
http://picasaweb.google.com/lh/photo/7iQ0pX2SD8FITkhaYWesrg?authkey=Gv1sRgCKmvsNPa09u83AE&feat=directlink
http://picasaweb.google.com/lh/photo/Ftbgdp2FY0f2EkxjATcp6g?authkey=Gv1sRgCKmvsNPa09u83AE&feat=directlink
http://picasaweb.google.com/lh/photo/7JUzjbmLYT0cptQ-YmwgmA?authkey=Gv1sRgCKmvsNPa09u83AE&feat=directlink
http://picasaweb.google.com/lh/photo/SRG1O1kYR1qw0RmrRe2YXQ?authkey=Gv1sRgCKmvsNPa09u83AE&feat=directlink
http://picasaweb.google.com/lh/photo/I3srijjnzyYpC4Ix3vn8nQ?authkey=Gv1sRgCKmvsNPa09u83AE&feat=directlink
USA
Freeduino rocks
Hmmmm, this shield looks more dangerous than the DANGER shield.  With such number of electronics newbies out there, you need to add a HUGE disclaimer in the board, and start counting the number of casualties.
Yes this is true!  There is a warning, although I may need to increase the text size!  All the HV contacts on the bottom are going to be covered...  liquid electrical tape, hot glue, something like that...  I will try to post some vids of it in action tonight.
"The old Europe"
Bootloaders suck!
I don't think that will be good enough.
Looking at all the traces, there is really no separation between 5V and the possibly fatal 120V part. And there's always the odd user that fiddles with the circuit and forgets to unplug the power. I know because I've done that when I thought I was 'in control' and was lucky a few times.
With all the opto couplers it should be possible to move the HV part to a different PCB, box it, and only have safe voltages on the shield. This lacks the coolness factor, but you surely don't want arduino users to end up on the 'darwin awards' list ?
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
USA
Freeduino rocks
Yes, something like the RELAY SQUID http://www.liquidware.com/shop/show/RS/RelaySquid
Actually there is a good amount of spacing between the HV and 5V.  I have a few products that have the traces of voltage much closer!  Everyone I work with in electronics is very careful and I am used to up to 480V power, so HV doesn't bother me at all, I just know to be careful.
I understand what you mean about doing a seperate box, however then there is no point of a shield at all, the only actual logic on the board is the arduino pins to drive the opto-couplers.  Everything else is HV, so those traces are very small and only 5 of them and a few grounds.  Maybe I will play around with the idea of a seperate board, I am already building one for a different project.
I personally like the idea of having everything on one circuit.  I can put this shield on a arduino and put it in an enclosure and I have 4 circuit control in a very compact package with dimming too.
I like the relay squid, but for simple things it is just too darn expensive for me!
"The old Europe"
Bootloaders suck!
I wasn't talking about trace spacing !
More like:
left side of PCB: safe
right side: hands off
Of course this is hard to do on such a small area.
Ahhh, yes.  I am looking into encasing that end in epoxy for that reason.  I will let you know how it goes.
Anyone interested in one can buy here http://ryanjmclaughlin.com/arduino/ also post, PM, or email if you have interest in a final version so I know how many to make.
I'm working up a spot-welder of the microwave transformer variety.
It was a 1500 W unit, and I wound on  3 turns of #1 flex welding cable, so the current capability should be useful at 3.1 V off load..
 I thought I'd do a cycle counter with a DueMilanove, using one d/o to drive an SSR I had on hand. The SSR uses an optoisolator, so its a safe approach.    Still thinking about the way to set a pulse between 0.5 and 3 seconds repeatably.
A 2 line LCD and push button inputs seem a little over the top though....
Brian W
Ryan,
 Nice idea, but I agree with the others about mixing the AC with the lower voltage stuff. Many do not know the dangers of AC voltage, and the Arduino is all about experimentation, and making this stuff easy for people just starting out.
 Just a suggestion. Build the AC stuff with the opto's on on a 2nd board, then use a small data cable to connect the two. Then the HV section could be put in a external box and protected.
Dale
Makes sense...  I am working on a separate board as well.  With a remote connection.  The shield is working good though, I tested it with some light bulbs last night.
Any thoughts on the AC breakout?  Molex connectors? Solder your own?  Standard Outlets?
I would use screw terminals, or maybe you could build it into a power strip that uses standard outlets, then the end user does not have to use anything. They are cheaper than any box you could buy.
Dale
Bristol, UK
Exhibitor at UK Maker Faire
Standard Outlets?
Standard sockets for which country?  And will the shield work properly on 240V, 50Hz power?
120v 60hz. The board needs to be setup differently for 240v.
Pages: [1] 2 3 ... 8   Go Up
