Author Topic: A faster sin() lookup function.  (Read 2857 times)
Netherlands
Today I did some investigations in a lookup function for sin(x).  Sin(x) takes approx 120 micros and I wanted more speed, and I knew the price was precision.
As I worked only in whole degrees a lookup table was the way to go. A straightforward float[361]  (1444 bytes!) was not acceptable so folding was applied, and a mapping to bring the table back to uint8_t[91].
The code shows two tables: a 16bit and an 8bit table,
The function float isin(long x) is the core, it folds the angle, does a lookup and convert that to a float.   // isin() stands for integer_sinus()
There are straightforward implementations of icos(x) and itan(x).
The function float fsin(float x) is an interpolation function, that runs on top of isin(),
// 91 x 2 bytes ==> 182 bytes
unsigned int isinTable16[] = {
  0, 1144, 2287, 3430, 4571, 5712, 6850, 7987, 9121, 10252, 11380,
  12505, 13625, 14742, 15854, 16962, 18064, 19161, 20251, 21336, 22414,
  23486, 24550, 25607, 26655, 27696, 28729, 29752, 30767, 31772, 32768,
  33753, 34728, 35693, 36647, 37589, 38521, 39440, 40347, 41243, 42125,
  42995, 43851, 44695, 45524, 46340, 47142, 47929, 48702, 49460, 50203,
  50930, 51642, 52339, 53019, 53683, 54331, 54962, 55577, 56174, 56755,
  57318, 57864, 58392, 58902, 59395, 59869, 60325, 60763, 61182, 61583,
  61965, 62327, 62671, 62996, 63302, 63588, 63855, 64103, 64331, 64539,
  64728, 64897, 65047, 65176, 65286, 65375, 65445, 65495, 65525, 65535,
// 91 bytes
uint8_t isinTable8[] = {
  0, 4, 9, 13, 18, 22, 27, 31, 35, 40, 44,
  49, 53, 57, 62, 66, 70, 75, 79, 83, 87,
  91, 96, 100, 104, 108, 112, 116, 120, 124, 128,
  131, 135, 139, 143, 146, 150, 153, 157, 160, 164,
  167, 171, 174, 177, 180, 183, 186, 190, 192, 195,
  198, 201, 204, 206, 209, 211, 214, 216, 219, 221,
  223, 225, 227, 229, 231, 233, 235, 236, 238, 240,
  241, 243, 244, 245, 246, 247, 248, 249, 250, 251,
  252, 253, 253, 254, 254, 254, 255, 255, 255, 255,
float isin(long x)
  boolean pos = true;  // positive - keeps an eye on the sign.
  if (x < 0)
    x = -x;
    pos = !pos;
  if (x >= 360) x %= 360;
  if (x > 180)
    x -= 180;
    pos = !pos;
  if (x > 90) x = 180 - x;
//  if (pos) return isinTable8[x] * 0.003921568627; // = /255.0
//  return isinTable8[x] * -0.003921568627 ;
  if (pos) return isinTable16[x] * 0.0000152590219; // = /65535.0
  return isinTable16[x] * -0.0000152590219 ;
float icos(long x)
  return isin(x+90);
float itan(long x)
  return isin(x) / icos(x);
float fsin(float d)
  float a = isin(d);
  float b = isin(d+1);
  return a + (d-int(d)) * (b-a);
Did some first tests and isin(x) is approx 6x faster than the original sin(x) for both tables. The 16 bit table is more precise with a max error of 0.000008 compared to sin(x); The 8bit Table scores a max error of 0.0002. [whole angles only]
I think it can be done better still, so all remarks, improvements or ideas are - as allways - welcome.
Rob
« Last Edit: August 20, 2011, 10:58:43 am by robtillaart » Logged
Rob Tillaart
Bristol, UK
Exhibitor at UK Maker Faire
Did you consider putting the big arrays into program memory and reading them back with 'pgm_read_word_near()'?  I've done this sort of thing with audio samples for a MIDI synthesiser on the Arduino.
Netherlands
Yes, considered that, but I keep it as a final optimization, as the RAM is just used elsewhere.
What I'm looking for is smart tricks that use only a few statements that will fold the table again, or increases the precision with the same amount of data.
I've considered storing only the mantisse of floats and add the exponent later. That would be 3 bytes per value, but that did not work as the exponents differ.
urrently I'm thinking what can be done with
sin(2x) = 2sin(x)cos(x)
If I have a table for 0..45, I could generate 46..90 (at least the even ones directly, and the odd by interpolation) but there is a recursion in it.
Next trick to be investigated is that the the steepness around x   ==>   sin(90-x)   (use radians for this)
So the table 0-45 holds enough values for the whole range.
Rob Tillaart
Boston area, metrowest
Online Online
heck, just approximate the whole thing with a triangle wave, so y is just a linear version of x smiley-wink
Netherlands
afraid that the error margin is a bit too high, but performance will be flabbergasting smiley-wink
Rob Tillaart
Netherlands
Changed the signature of isin to accept float as param. this is basis for interpolation. With the old interface fractional angles were truncated, now they are rounded. This reduces the :
runtime increased from 18 -> 32 micros  - still 3.75 faster than sin(x) -
steps of 0.1 degree
max error: 0.00872979    (below 1/100  !!  with the truncation, this was  0.016 almost twice as much)
avg error: 0.00277813
lesson: Double the precision cost twice the performance?
float isin(float f)
  long x = f + 0.5;
  if (x < 0)
    x = -x;
    pos = !pos;
  if (x > 180)
    x -= 180;
    pos = !pos;
next step is some interpolation (again) .
« Last Edit: August 20, 2011, 11:01:53 am by robtillaart » Logged
Rob Tillaart
Netherlands
Added the interpolation
float isin(float f)
  if (f < 0)
    f = -f;
    pos = !pos;
  long x = f;
  unsigned int r = (f-x) * 256;
  if (x >= 180)
    x -= 180;
    pos = !pos;
  if (x >= 90)
    x = 180 - x;
    if (r != 0)
      r = 256-r;
      x--;
  unsigned int v = isinTable16[x];
  // interpolate if needed
  if (r > 0) v = v + ((isinTable16[x+1] - v)/8 * r) /32;
  if (pos) return v * 0.0000152590219; // = /65535.0
  return v * -0.0000152590219 ;
runtime 45 micros (49 if the interpolation is not conditional)   factor 2.6 faster than sine
steps of 0.1 degree
max error: 0.00015676   (factor 55.7 lower than without interpolation
avg error: 0.00004814    (factor 57.7 lower than without interpolation
« Last Edit: January 05, 2013, 06:18:48 am by robtillaart » Logged
Rob Tillaart
