Topic: [SOLVED] Inheritance doesn't work with main class functions in cpp file (Read 836 times) previous topic - next topic
Fredouille_91
Aug 18, 2011, 10:14 am Last Edit: Aug 18, 2011, 11:45 am by Fredouille_91 Reason: 1
Hello,
I have a problem with a inherited class wich can't access functions of the main class when they are defined in a cpp file. It works fine however when they are defined in the .h file as inline functions.
Then message I get when compiling is undefined reference to `MainClass::myFunction()'
Here is a sample code :
I defined a class called Analog containing default functions for all analog sensors (getValue, getVoltage,...).
I also defined a class IR inherited from Analog for specific IR sensor (adding GetDistance, for example)
First, my arduino sketch :
Code: [Select]
#include <IR.h>
IR irsensor = IR(2);
// Setup
void setup(){
// Loop
void loop(){
 Serial.println(irsensor.getValue());
 Serial.println(irsensor.getDistance());
Then, my IR class code (inherited from Analog class) :
IR.h
Code: [Select]
#ifndef IR_h
#define IR_h
#include "WProgram.h"
#include "../Analog/Analog.h"
class IR : public Analog
public:
IR(int irPin);
float getDistance();
private:
#endif
IR.cpp
Code: [Select]
#include "IR.h"
IR::IR(int irPin){
_pin = irPin;
float IR::getDistance(){
int reading = analogRead(_pin);
return 12343.85 * pow(reading,-1.15);
And here is the code I'm using for the Analog class (this one work, using only a .h file) :
Analog.h
Code: [Select]
#ifndef Analog_h
#define Analog_h
class Analog
public:
inline int getValue(){
return reading;
protected:
int _pin;
#endif
Here is the code for the Analog class which is not working (using .cpp file):
Analog.h
Code: [Select]
#ifndef Analog_h
#define Analog_h
class Analog
public:
int getValue();
protected:
int _pin;
#endif
Analog.cpp
Code: [Select]
#include "Analog.h"
int Analog::getValue(){
return reading;
Do you have any idea of how I can use cpp file for my main classes ?
Thank you very much or your help,
Regards,
Fred
Nadir
Do you get any error while compiling? or it compiles right but not working properly.
PaulS
I copied and pasted all the code into separate tabs, so that all the files are in the same folder.
I had to change the include statement in the main sketch to use "" instead of <>.
I had to add #include "WProgram.h" to Analog.cpp.
Other than that, the program compiled just fine.
Fredouille_91
Thnak you very much, it's working now, my sketch is compiling without errors.
I just put all files in one folder (called sensors) and add "WProgram.h" to Analog.h.
Fred
