Topic: How do I detect if I'm receiving serial data. (Read 2726 times) previous topic - next topic
bvli
Hi there.
I've googled and googled and haven't found any solution for my problem. I hope someone in here knows how to do it the right way.
The problem is, that I need to know if somebody is sending me data, before I send data back. In other words, a simple kind of collision detection.
In psudo code:
Code: [Select]
#define LINE_CLEAR_SPAN 500
void sendData() {
  long timeSinceLastByteReceived = SomeMethodToGetTheTimeSinceLastByteReceived();
  while (timeSinceLastByteReceived < LINE_CLEAR_SPAN)
     delay(TIME_OUT);
  // ok clear to send!
  Serial.write("yeah!");
But how do I get the information from Serial? How do I implement the "SomeMethodToGetTheTimeSinceLatByteReceived()"?
I thought about some kind of interrupt that resets a counter each time the Serial receives a byte. But how do I attach an interrupt handler to the serial device?
If nobody guessed it by now, I need to say, that i'm a totally newbie in embedded programming. So please be gentle!
Thanks!
AWOL
Why an interrupt?
Could you use "Serial.available"?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
bvli
He - well yeah.. I suppose I could. But then I can not know how long I need to wait before sending.
It's okay that something is in the buffer as long as it's received longer ago than "time between messages". But then again - maybe it's my design that sucks then. I'm used to use threads, mutex'es and managed garbage collection.
AWOL
Quote
Why not?
bvli
As it is now - the logic in my program looks like this.
Code: [Select]
  while (Serial.available() > 0)
    //handle the incoming data.
  //do some plumbing
  sendMessage();
If I understand correctly - the uart will/could still receive data while I'm doing other stuff in my loop. When I send my message I need to be sure that I send the message at least let's say 30 ms after the last byte has been received/buffered by the uart. In the time span between "Serial.Available == 0" and I call "SendMessage()" data could have been received and if I send my message without waiting, contention occurs.
PaulS
Quote
Why?
Data arrives on the serial port when it wants to. You have no way of knowing when the interrupt that processed the serial data occurred.
At best, you could periodically check the amount of data in the buffer. Store the time you do that. At some future time, if the amount of data is still the same, and your desired interval has elapsed, send the message.
bvli
Quote
Why?
Because my serial port is connected to a bus.  On the bus datagrams between 4-8 bytes is sent. If somebody else is sending a datagram on the bus, I'd ruin it by starting sending my datagram when the other part has sent f.x. two bytes out of four. Thus I'll have to wait until the other part has finished sending his datagram to minimize the risk on contention.
I just started all this electronics stuff so please forgive me. But isn't it somehow possible to connect the rx-line both to the rx-pin and to another pin (through some resister) on the arduino and detect when it goes low? Then I could attach an interrupt routine and reset some kind of timer each time the rx-line goes low.
Code: [Select]
volatile long lastByteReceived;
//called when the interrupt occurs.
void onRxGoesLow()
  lastByteReceived = millis();
//called by my send routine.
byte timeSinceLastByteReceived()
  return millis() - lastByteReceived;
Okay.. Do you know where I can read about accessing the serial buffer? (I don't know what I should search for).
wildbill
Could you give a view of the bigger picture - what are you trying to do?
AWOL
Quote
Serial.read will return the next character available, if there is one, or return -1 if there isn't.
Serial.available will tell you how many characters are in the serial buffer (including zero if there aren't any)
What more access do you need?
bvli
Quote
Not much more I guess. I'll check tonight if the following works. I'm not sure if I like the solution, but if it works it's okay for now. Thanks.
Code: [Select]
#define CONTENTION_TIMEOUT 30
void WaitForBusClear()
  if (Serial.available() > 0)
    int count = Serial.available();
    delay(CONTENTION_TIMEOUT);
    while (Serial.available() > count)
      count = serial.available();
graynomad
#10
Aug 18, 2011, 02:03 pm Last Edit: Aug 18, 2011, 02:20 pm by Graynomad Reason: 1
It sounds like you want to detect an idle bus. For my money the best way to do this is start a timer and reset it every time there is an edge on the RX pin. If the timer ever reaches 0 nobody has transmitted for N time and you can go.
BUT
If you have more than one node doing this (and you will or there's not point in the first place) you will have a race condition.
How will you know that another node hasn't done exactly the same thing? You have to detect bus clashes and try again after a random period.
This is a multiple access protocol and it needs a lot of deep thought.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
PaulS
Quote
I know I don't like it. Something like this maybe:
Code: [Select]
int oldCount = 0;
int newCount = 0;
unsigned long lastSerial = 0;
   newCount = Serial.available();
   if(newCount != oldCount)
      oldCount = newCount;
      lastSerial = millis();
   // Rest of loop
Then a function to send data
Code: [Select]
void sendFunc(/*whatever args are needed*/)
   unsigned long currTime = millis();
   // Diddle until enough time has elapsed
   // since last serial data received
   while(currTime - lastSerial < CONTENTION_TIMEOUT)
      // Check for new serial data
   // When we get to here, no serial data was
   // received in the last CONTENTION_TIMEOUT
   // milliseconds
   // Send the data...
bvli
Well that's exactly what I've tried to explain you all that I needed! :) If then somebody could tell me HOW I could detect an edge on the RX pin (how would I wire it up) and how to attach an interrupt handler method. (please)
BUT
I'm aware of the risks. Garbage packages will be discarded (and is expected). The timeout value will be arbitrary, and I think this would solve most clashes.
bvli
Quote
Thanks!  If I can't get the idle detection working, I'll try to work something out based on both mine and your code examples.
bvli
After a second thought.. Would you mind explain to me why you prefer your own solution and don't like mine?
