Topic: Timing pressure using a stopwatch (Read 953 times) previous topic - next topic
Seán
Hello,
I hope someone can help me with a little bit of code here.
I am trying to time how long a pressure is applied to a FSR. So, I will start a stopwatch running when the pressure is applied (above a value of 200 and the analogRead), noting that time, and I want to note the time the stopwatch is finished, and I want it to finish when the pressure drops below a specific value (i.e. below 100 on the analogRead).
Code: [Select]
#include <StopWatch.h>
StopWatch MypressureSW;
int analogPin = 0;
int fsrReading, fsrVoltage;
float val1 = 0;
float val2 = 0;
float totalTime;
  pinMode(analogPin, INPUT);
  if(analogRead(analogPin) < 100)
  if(analogRead(analogPin) > 200)
    pressureTime();
void pressureTime()
  MypressureSW.start();
  val1 = MypressureSW.value();
  Serial.print("Pressure Applied At: ");
  Serial.println(val1);
  delay(10);
  if(analogRead(analogPin)<100)
    MypressureSW.stop();
    val2 = MypressureSW.value();
    Serial.print("Pressure removed at: ");
    Serial.println(val2);
    totalTime = val2 - val1;
    Serial.print("The total time of pressure applied is: ");
    Serial.println(totalTime);
    MypressureSW.reset();
However, all I get on the Serial Monitor, when I apply a constant pressure is
Quote
Pressure Applied At: 0.00
Pressure Applied At: 2037.00
Pressure Applied At: 3076.00
Pressure Applied At: 4115.00
And when I let go, it just sits with that information. So, it seems it isn't reading the time when I let the pressure go.
I imagine I am doing something obvious and silly, but I can't see it.
Thanks in advance.
Seán
Ná bac le mac an bhacaigh is ní bhacfaidh mac an bhacaigh leat.
PaulS
Get rid of the separate function, until the timing works.
Start the stopwatch if the pressure is above 200 AND the stopwatch is not running.
Stop the stopwatch if the pressure is below 200 AND the stopwatch is running. When you stop the stopwatch, print the time.
In order to do this, you need to know if the stopwatch is running. You can define a flag (bool) to keep track of that, if the stopwatch class doesn't have a method to tell you.
Seán
Hey,
Thanks for the reply.
I get what you are say, but I am not too sure how to use flags etc, so I will do some reading and try to figure that out.
Thanks!
Seán
AWOL
Don't think of a flag, think of a pencil tick in the box:
Action: I've started the stopwatch, put a pencil tick in the box.
Action: I've stopped the stopwatch, rub-out the tick.
Question: Is the stopwatch running? - look in the box.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
PaulS
Something like this, maybe:
Code: [Select]
bool watchRunning = false; // This is a flag
   int pressure = analogRead(pin);
   if(pressure > 200)
      if(!watchRunning)
         // Start it running
         watchRunning = true;
      if(watchRunning)
         // Stop it
         // Print time
Seán
Hey,
Thanks.
I can't find anything explaining what 'bool' does (I am assuming it is connected with Boolean?), do you know anywhere were I can read up on this? I'd like to understand the code rather than take someones else.
Again, thanks :)
Seán
wildbill
bool and boolean are synonyms. Boolean reference on the main site (not much there though): http://arduino.cc/en/Reference/BooleanVariables
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
