Topic: Help reducing code size (Read 845 times) previous topic - next topic
Joy
I have written a code whose size is 7292 bytes..
as I am new to coding I may have done some things in a long way.
Friends please help and guide me in places where the code can be made shorter to reduce the size, as I am planning to write this code to an Atmega 88..
Code: [Select]
#include <IRremote.h>
#include <EEPROM.h>
#include "Seg7.h"
int pin1 = 8;
int pin3 = 9;
int RECV_PIN = 11;
int fadered = 25;
int pin1State = LOW;
int pin2State = LOW;
int val;
int state;
int state1;
int btn1_Cnt = LOW;
int btn2_Cnt;
Seg7 s7;
int digit;
IRrecv irrecv(RECV_PIN);
decode_results results;
   s7.attach(0, 1, 2, 3, 4, 5, 6, 7);
  s7.write(digit);
  irrecv.enableIRIn();
  pinMode(pin1, OUTPUT);
  pinMode(pin3, OUTPUT);
  fadered = EEPROM.read(8);
  /********** THIS IS TO READ WHAT WAS THE STATE OF PIN3 SAVED LAST TIME ***********/
  btn2_Cnt = EEPROM.read(4);
  if(btn2_Cnt % 2 == 0){
    analogWrite(pin3, 0);
  else{
    analogWrite(pin3, fadered);
   s7.write(digit);
  /********** THIS IS TO READ WHAT WAS THE STATE OF PIN1 SAVED LAST TIME ***********/
  btn1_Cnt = EEPROM.read(0);
  if(btn1_Cnt % 2 == 0){
    digitalWrite(pin1, LOW);
  else{
    digitalWrite(pin1, HIGH);
      digit = map(fadered,24, 249, 0, 9);
    s7.write(digit);
  if (irrecv.decode(&results)) {
    /********** THIS PART IS FOR PIN1 ************/
    if(results.value == 0xffb24d){
      btn1_Cnt++;
    /********** THIS PART IS FOR PIN3 ************/
    if(results.value == 0xff7887 && fadered <= 230){
      fadered = fadered + 25;
    if(results.value == 0xff50af && fadered >= 25){
      fadered = fadered - 25;
        if(results.value == 0xff38c7){
      btn2_Cnt++;
    s7.write(digit);
    /********** THIS IS FOR SAVING THE BRIGHTNESS VALUE IN EEPROM ************/
    val = fadered;
    if(val != EEPROM.read (8)){
      EEPROM.write(8, val);
    /********** THIS IS TO SAVE THE LAST STATE OF THE PIN3 ************/
    state = btn2_Cnt;
    if(state != EEPROM.read (4)){
      EEPROM.write(4, state);
    /********** THIS IS TO SAVE THE LAST STATE OF THE PIN1 ************/
    state1 = btn1_Cnt;
    if(state1 != EEPROM.read (0)){
      EEPROM.write(0, state1);
    irrecv.resume();
AWOL
#1
Aug 18, 2011, 04:02 pm Last Edit: Aug 18, 2011, 04:16 pm by AWOL Reason: 1
Can you see how this:
Code: [Select]
   state = btn2_Cnt;
looks a lot like this:
Code: [Select]
   state1 = btn1_Cnt;
Quite often that says "time for a function".
Won't always make your code smaller, but it'll make it easier to debug.
(it is also worth pointing out that "btn1_Cnt" is an "int", and doesn't fit in an EEPROM byte)
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
wildbill
There are a number of small changes you can make - variables like state that aren't necessary, AWOL's function, transforming the if statements that digitalwrite HIGH or LOW to a single digitalwrite that uses the ifs condition directly. These aren't going to get you much though - the libraries you are using are likely the cause of the size of your code.
I see that the 88 has 8K available - how much does the bootloader occupy and so how much do you need to reduce it?
Graynomad
Overall I think it's pretty good, just a few comments
Code: [Select]
   val = fadered;
val isn't used anywhere else, no point assigning fadered to it just for this piece of code.
Code: [Select]
    if(fadered != EEPROM.read (8)){
      EEPROM.write(8, fadered);
Likewise with "state1" and "state".
This
Code: [Select]
could be
Code: [Select]
fadered += 25;
fadered -= 25;
No smaller but slight simpler source code.
Code: [Select]
int RECV_PIN = 11;
This is a constant, either use "const" or "#define".
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
AWOL
Code: [Select]
int fadered = 25;
Two bytes could be saved by not initialising "fadered" when declared!
Make the pin constants constant.
rbtying
Hmm... you could also try changing the if/else chain to a switch/case, which may reduce size ( I believe switch/case compiles to a jump table, whereas if/else compiles to a bunch of jump-if-compare or jump-if-not-compare statements ).
Since you're storing an on/off value for pin1 and pin3, you can also use a single byte for both of them. You also set pin1 and pin3 multiple times without changing the values, which is a waste - just set it once at the end. Moreover, there is repeated code between setup and loop - encapsulate that into a function to save space.
Code: [Select]
#include <EEPROM.h>
#include "Seg7.h"
const int pin1 = 8;
const int pin3 = 9;
const int RECV_PIN = 11;
uint8_t fadered = 25;
Seg7 s7;
int digit;
uint8_t stateReg;
const int PIN1_MSK = ( 1 << 0 );
const int PIN3_MSK = ( 1 << 1 );
const int FADE_REG = 8;
const int STATE_REG = 4;
  s7.write(digit);
  fadered = EEPROM.read( FADE_REG );
  stateReg = EEPROM.read( STATE_REG );
  setStates();
  digit = map(fadered, 24, 249, 0, 9);
  s7.write(digit);
void setStates() {
// set pin3
if ( stateReg & PIN3_MSK ) {
analogWrite( pin3, 0 );
analogWrite( pin3, fadered );
// set pin1
digitalWrite( pin1, ( stateReg & PIN1_MSK ) );
switch ( results.value ) {
case 0xffb24d: // pin1
stateReg ^= PIN1_MSK;
case 0xff38c7: // pin3
stateReg ^= PIN3_MSK;
case 0xff7887:
if ( fadered <= 230 ) {
fadered += 25;
case 0xff50af:
if ( fadered >= 25 ) {
fadered -= 25;
    s7.write(digit);
setStates(); // set the state of pin1 and pin3
    if ( fadered != EEPROM.read ( FADE_REG ) ) {
      EEPROM.write( FADE_REG, fadered );
if ( stateReg != EEPROM.read( STATE_REG ) ) {
  EEPROM.write( STATE_REG, stateReg );
    irrecv.resume();
Note: I have no clue if this code compiles, since I don't have Seg7.h. But it should work, and the concepts are all thee.
Joy
Code: [Select]
#include <EEPROM.h>
#include "Seg7.h"
const int pin1 = 8;
const int pin3 = 9;
Seg7 s7;
int digit;
uint8_t stateReg;
  s7.write(digit);
  setStates();
  s7.write(digit);
void setStates() {
// set pin3
// set pin1
case 0xff7887:
fadered += 25;
case 0xff50af:
fadered -= 25;
    s7.write(digit);
    irrecv.resume();
Thank you Aeturnalus.. :)
Your code just worked fine... :)
it was really written in a clean way and in short..
I am actually learning a lot for ur code pattern..
I am still going through the code and trying to understand how it is actually working...:)
