Topic: Converting char to upper case (Read 12760 times) previous topic - next topic
Atalanttore
Hi
I need to convert a char to upper case.
I was trying char.toUpperCase(), but this function doesn't work for chars.
Is there an UpperCase function for chars?
Regards,
Atalanttore
Senso
Yes, using this std c function:
int toupper    (    int     __c )
http://www.nongnu.org/avr-libc/user-manual/group__ctype.html#ga924ed052807e23cfa160d5f171cf5e2a
liuzengqiang
char one_char='f';
one_char=one_char-'a'-'A';
This is when you are sure the one_char is in lower case. Otherwise, do if statement.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
bperrybap
char one_char='f';
But if you want to get down and dirty and assume ASCII and that the values are always
letters vs any possible character, and not use the ctype functions, then simply mask off
bit 5.
i.e.
Code: [Select]
upper_charvalue = charvalue & ~(0x20);
It won't matter if the charvalue is upper or lower case. But it will trash characters
that are not letters.
If you use the toupper() function, it will only convert lower case characters to upper case
and leave other characters alone.
--- bill
robtillaart
Quote
must be a +
one_char = one_char - 'a' + 'A';
Include <ctype.h>   -->  - http://www.nongnu.org/avr-libc/user-manual/group__ctype.html -
Then you have "all" char manipulators
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
liuzengqiang
robtillaart
Quote
parentheses
Recently I read a product description of a calculator that used different colors for matching parentheses. Quite functional!
Rob Tillaart
Atalanttore
Good idea. I would like an editor/IDE, which uses different colors for matching parentheses.
liuzengqiang
They at least indicate the parentheses when you have cursor on one of them.
