Loading...
Pages: [1]   Go Down
Author Topic: Help me to setup the PWM frequency to 10khz  (Read 508 times)
PT
Offline Offline
Newbie
View Profile
I am working on a project of a converter for Photovoltaic modules and
I am using an Arduino Uno board to generate a PWM to controll a IGBT.
I need at least 10khz frequency pwm and using analogWrite i get 490 hz.
Can you help me configuring the timers to have a 10khz frequency??? smiley-mr-green
here is the code:
 * Two Stage Single Phase Inverter control
 * JN. Barbosa - MERCEUS - DEE - FCT-UNL
 int Vpv0 = 0; // inicials conditions
 int Ipv0 = 0;
 int P0 = 0;
 int Vpv1 = 0;
 int Ipv1 = 0;
 int P1 = 0;
 int D = 0.500; // duty-cycle
 int dD = 0.001; // perturbation
   pinMode(3, OUTPUT);  // sets the pin as output
   Vpv0 = analogRead(A1); // read the pv voltage
   Ipv0 = analogRead(A2); // read the pv current
   P0 = Vpv0*Ipv0;                // calculate instant power
  delay(1);
  Vpv1 = analogRead(A1);
  Ipv1 = analogRead(A2);
  P1 = Vpv1*Ipv1;
  int dV = Vpv1-Vpv0;
  int dP = P1-P0;
 if (dP > 0){
   if (dV > 0){
     D = D+dD;
   }else{
     D = D-dD;
 }else {
   if (dV > 0){
     D = D-dD;
   }else{
     D = D+dD;
 analogWrite(pwmPin,D*255);
 Thank you a lot!!!
Logged
Portugal
Offline Offline
God Member
View Profile
Read this:
http://hekilledmywire.wordpress.com/2011/08/03/introduction-to-pwm-part-7/
Logged
PT
Offline Offline
Newbie
View Profile
thank you for the reply Senso!!
the text is long but i will read it all.
thanks smiley-mr-green
Logged
Bristol, UK
Offline Offline
Edison Member
Exhibitor at UK Maker Faire
View Profile
WWW
Code:
This isn't going to work. An integer is a whole number, without a fractional or decimal part.  Maybe you meant:
Code:
float D = 0.500; // duty-cycle
 float dD = 0.001; // perturbation
But, remember that 'float' variables and calculations are much slower than 'int's. Could you scale all your calculations to use integers, say in the range of 0..1023 or 0..255?
Logged
Humboldt, CA
Offline Offline
Full Member
Arduino BBB
View Profile
Check this out, too:  http://www.arduino.cc/playground/Code/PwmFrequency
Tops out at 65kHz before you get deeper into the various timer registers.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
Think of your calculations like this:
Code:
int D = 0; // duty-cycle
 int dD = 0; // perturbation
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
PT
Offline Offline
Newbie
View Profile
hello guys!!
Anachrocomputer, you are right. I shall use float numbers for dutycycle and perturbation.
AWOL, the perturbation must be greater than zero.
Thank you!! smiley-mr-green
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
So don't assign a sub-unity value to an integer - it will be truncated to zero.
Logged
Pages: [1]   Go Up
Print
Jump to:
