Topic: SOLVED:Checking variable for while loop, updated from Interrupt (Read 703 times) previous topic - next topic
btsp
I am using a TIMER1 overflow interrupt,
I have written a quick code to test to see if i can update a variable with the interrupt as its being checked by a while statement.
Code: [Select]
   #include "TimerOne.h"
   byte FLAG = 0;
     pinMode(6, OUTPUT);
     Timer1.initialize(1000000);
     Timer1.attachInterrupt(callback);
     Timer1.stop();
   void callback()
     digitalWrite(6, HIGH);
     delay(10);
     digitalWrite(6, LOW);
     FLAG = 1;
     Timer1.stop();
     Serial.println("SEND MESSAGE");
     Timer1.start();
     Serial.println("RECEIVING");
     while(FLAG == 0);
     FLAG = 0;
     delay(10000);
It doesn't notice the interrupt change in the FLAG status with :   while(FLAG == 0);
It does notice the flag change however if i put something in the while loop to check eg:
while(FLAG ==0){
Serial.println(FLAG, DEC);
Does anyone know why this is happening?
Doesn't  " while(FLAG == 0);" continuously check the state of FLAG anyways?
anachrocomputer
Any variable that's shared between interrupt code and the main code must be declared 'volatile':
Code: [Select]
volatile byte FLAG = 0;
PaulS
Code: [Select]
      delay(10);
In an interrupt handler? I don't think so!
btsp
thanks the volatile byte worked.
yes i know putting a delay in there is bad, in my actual program there is nothing like that.
thanks again
