Topic: The program doesn't start after i plug arduino (Read 992 times) previous topic - next topic
opc0de
I have a small problem sometimes when i plugin the arduino board the program that was on the board does not start and i must plug the board out and in again. Any ideas why this happens ?
amacmullen14
Does the power led light?  and does the pin 13 led blink when reset?
If the power light does not always come on, I might guess it's a defective power/usb cable
retrolefty
Does the PC 'see' the new USB connection being made when you plug in the board, but it doesn't seem to run the sketch?
opc0de
Yep is detected if i upload a new sketch it works. What i must say is that when i plug the usb cable sometimes an led on the board flashes when it flashes it works when it doesn't it does not work. What could be the problem ? I read in the general problems that a cause can be if i am sending data over the com port but i am not.Is windows sending some sort of data over the com port ? I use windows 7
