Topic: Change SPI ports (Read 625 times) previous topic - next topic
ollig
I wounder if it's enough changing the port declarations in pins_arduino.h to get an interchange of pin 13 and 10 (SlaveSelect <-> Clock) when using the SPI library, especially for the clock pin?
TIA
Nick Gammon
No. The pins functions are set in the hardware. Changing the .h file will only make the library malfunction (or possibly have no effect at all).
You can assign any pins you like as slave select (at the master end) however pin 10 must be configured as an output.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Nick Gammon
Some people have done software SPI implementations, you might need that if you are desperate to change pin functions.
More info:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
