Topic: Newbie code check, RF transmit (Read 994 times) previous topic - next topic
arduinokov
Hello,
Could someone knowledgeable check over my code? I am using an RF pair from Sparkfun.
The transmitter is this one: RF Link Transmitter - 434MHz
Here is the code I am using to transmit to another Arduino with the receiver on board.
Code: [Select]
//pins
const int tripBeam=6;//input from an IR trip beam
const int LED=13;//output - LED that conveys status to humans
//constants
const byte GO=210;//Send this through serial, which will go wirelessly to another Arduino. Picked pretty much at random.
//durations
unsigned long deadTime=5000;//don't bother listening to the trip beam for 5 seconds after it's tripped
void setup(){
Serial.begin(2400);//2400 baud for the 434 chip
pinMode(tripBeam, INPUT);
pinMode(LED, OUTPUT);
digitalWrite(tripBeam, HIGH);//turn on internal 20k pullup resistor so the open input state is HIGH.
digitalWrite(LED, LOW);
void loop(){
//See if the trip beam has been tripped
if(digitalRead(tripBeam)==LOW){
Serial.print(GO);
digitalWrite(LED, HIGH);
delay(deadTime);
When I trigger the switch (tripBeam=6), the LED blinks and the serial monitor shows "Ò".
The input is from a separate IR receiver. It has a dip relay, N/O to pin 6, COM to ground.
Any help would be very much appreciated.
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
arduinokov
Receiver is not receiving. I thought I'd ask to see if there are any glaring errors in the transmitting code first.
Is the "Ò" in the serial monitor what would be expected with successful transmission?
Thanks
AWOL
#3
Aug 19, 2011, 09:42 pm Last Edit: Aug 19, 2011, 09:44 pm by AWOL Reason: 1
Quote
I don't know; values above 127 are not ASCII, so you'd have to look for the character  code 210.
If you're on a PC, you could run "charmap" - yes, 0xd2 is capital O grave.
arduinokov
The problem has been solved. Thanks to those who helped  :)
