Topic: Your latest purchase (August 20th to February 11th) (Read 71571 times) previous topic - next topic
retrolefty
Created thread for GPS and positioning discussion:
http://arduino.cc/forum/index.php/topic,91051.0.html
Finally, good riddance.
Just kidding.  ;)
KirAsh4
Just kidding.  ;)
Bad Lefty.  Don't make me take my Righty and slap you silly.  *smirk*
Nick Gammon
500 x zero-ohm resistors for $4.
I love this concept! A resistor with no resistance! It's like buying a box of chocolates with no chocolates in it, or a wine bottle with no wine in it.
I'm not sure what their tolerance is, but I suppose 5% of zero is still zero, so that's not a huge issue. :)
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
KirAsh4
This begs the question Nick, what on earth would you use those for?  Build a sculpture? :)
Nick Gammon
I thought someone would ask that. ;)
They must be useful, right, or they wouldn't make them?
One use is to make something look fancier than it really is. :O
They are also described as "link" so I suppose in practice you might put them onto a circuit board as a wire link so that an automatic device could install them the same way as a resistor. Might be easier for the mechanics to handle than plain wire.
More info:
retrolefty
#380
Feb 10, 2012, 12:43 am Last Edit: Feb 10, 2012, 12:46 am by retrolefty Reason: 1
Correct.
You do of course realize that it is not truly a 0 ohm resistor, such a component doesn't exist at room temperature.  ;)
Jack Christensen
But then why do they make ... Oh, I won't go there  ;)
Quote
I think that's it, these were maybe more popular back in the day when single-sided PC boards were more common, and needed jumpers.
focalist
And here I was thinking you can get a room temperature superconductor for short cash.  Ah well, back to mining zero point energy and building my Phlogiston flywheel..
When the testing is complete there will be... cake.
Osgeld
Quote
they still make and use them in their SMD form for the same reasons, if you need to have some configurable option at the time of manufacture but dont want to make different boards add pads and use a "0 ohm resistor" to jump them since pick n place machines can grab them
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
KirAsh4
So essentially, it's a piece of wire with some plastic molded over it and a single stripe painted over it.  Ah the good ol' days.
Nick Gammon
Rats! I haven't bought a superconductor? I thought they were a bit cheap ...
More info:
Jack Christensen
False advertising! Call 1-800-LAWSUIT
Nick Gammon
Hey, I see what you mean! ...
I've been gypped! It's an outrage!
More info:
KirAsh4
Either that, or your meter is a fluke. :)  (sorry, I had to say it.)
retrolefty
Nice meter, I have a couple of older mode 87s.  A hint, when measuring low value resistances, first short your meter leads together, turn to the resistance mode and then press the 'REL' button. That will then factor out ('zero out') your meter lead resistance and the display will say 'rel' to remind you that the reading is the resistance value above the meter leads resistance.
Lefty
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
