Loading...
Pages: 1 ... 5 6 [7] 8 9 ... 27   Go Down
Author Topic: Your latest purchase (August 20th to February 11th)  (Read 18596 times)
Seattle, WA
Offline Offline
Full Member
View Profile
WWW
Microsoft Visual Basic, Professional Edition.
Haven't even unwrapped it yet!
Kill it!  Kill it with fire!
heh.
Logged
Phoenix, Arizona USA
Online Online
Faraday Member
Where's the beer?
View Profile
WWW
I just purchase 50 used L298s for $25.00 (approx) on Ebay...
Either I got a good deal, or I got hosed - one of the two!  smiley-mr-green
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
luidr,
On the CP2102 module:
Cut the Reset trace, add a jumper over from the DTR pin. Little trick picked up from Retrolefty.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Just received the Saleae 8 channel analyzer - seriously tiny!
Nice zippered storage case to keep it in as well.
Nick G, Rob G: is there a trick to getting the probes on the leads? Mine keep falling off.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
One of mine does that all the time, I thought I must have done something silly like push it onto a pin that was too large. It's starting to get on my nerves, so I was going to try crimping it to be a bit tighter.
Logged
Berks, UK
Offline Offline
Full Member
View Profile
So, this press photo will go in my "collection" of youthful nostalgia.
Speaking of nostalgia, I was cleaning out my junk today and stumbled across Adventure Quest for the Amstrad:
This was supplied on a medium that some of you may not have used for a while: cassette tape:
The game boasts that it has "225 individually described locations".
The instruction booklet informs you of how they managed to squeeze so much gameplay into 32 Kb of memory:
I see a £ sign - Ex-Pat ??
Texy
Logged
Boston Suburbs
Offline Offline
God Member
I am above your silly so-called "Laws", Mister Ohm.
View Profile
WWW
32K.. gee that sounds familiar..
So, let's see.  It's on tape as a binary for 8080/8086... so you should be able to "read" the binary using a sampling routine for the FSK encoding.  After that, convert the opcodes into equivalent for Atmel.. and release it for Arduino.
Easy, huh?
Logged
When the testing is complete there will be... cake.
France
Offline Offline
Sr. Member
View Profile
WWW
Very nice device. I have one too and experience the same minor issues.
  • Rotate the cable when inserting it into the probe.
  • Push on the back of the rear part of the probe so the metal hook go back inside the plastic.
Logged
avenue33
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
luidr,
Thanks for the tip. I'll see if I can manage that. I have a pretty dull cutter. In case I mess up, I still have a use bub II from modern device.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Take your time doing it. There is not much trace to cut there.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
My Saleae Logic is somewhere between here and Nasua, NH. I should get it by Saturday. My Digi wifi XBee development kit will be here tomorrow. I finally got ArduinoISP/avrdude talking to the AAG weather station, so it looks like my weekend is all set! smiley
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Well spotted. I worked in London for around 6 months doing contracting. Whilst there I needed my "computer" fix so I bought an Amstrad there. Then that (and other titles) from the HMV shop.
I brought the Amstrad back to Australia with me but the monitor was too bulky and heavy so I left it behind. Unfortunately it's been thrown out since. It was a nice little gadget.
Logged
Seattle, WA
Offline Offline
Full Member
View Profile
WWW
Ooh, fun!  Check out the digi ConnectPort X2 if you're getting into XBee.  SparkFun sells them here: http://www.sparkfun.com/products/10569; you can also find them on the digi site, but their site is terrible.  The device is really nice if you have a bunch of XBees, it lets you remotely update firmware (over the air), runs Python scripts natively on the device, and can act as an internet gateway to boot.  I use mine to upload sensor data to a private Pachube feed.  Note that the Sparkfun model works with the S2 XBees.
And after typing all of that I realized that you mentioned the digi *wifi* xbee dev kit.  Sigh.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Quote
lol. I already have a bunch of the original XBees. I thought it would be fun to play with wifi for a while. I should be able to build the equivalent of the ConnectPort X2 with one of these modules.
Logged
Seattle, WA
Offline Offline
Full Member
View Profile
WWW
Hmm, mine actually fit quite snugly - you might want to check with the Saleae logic folks directly, I hear their customer support is quite good.  I wouldn't be surprised if they just sent you a new set.
Logged
Pages: 1 ... 5 6 [7] 8 9 ... 27   Go Up
Print
Jump to:
