Topic: how to Find Change in Current? (Read 717 times) previous topic - next topic
xohaibalam
Hi!
there are some sensors, whose outputs variation is 4-20 mA. My question is how to find this variation through Arduino  ?
Plz Help me...ASAP :(
Thanx
Dan_68
Hey,
Try this link
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1205745528
You can set up a resistor and measure the voltage drop across the resistor then use simple V=IR to find current.
Grumpy_Mike
This sounds like a current loop output. Is it a passive one or active one. That is does it actually generate a voltage and will produce a voltage if a resistor is connected across it. Or is it just a load that when you put a voltage into it will draw the current.
http://en.wikipedia.org/wiki/Current_loop
