Topic: Why the Arduino Uno is not an AVR ISP programmer? (Read 9620 times) previous topic - next topic
cborges13
With the same components of the Arduino UNO is it possible to make an AVR ISP programmer?
In this case it would be unnecessary to use ATmega328 bootloader. To make this change it would be need to use de SPI of the ATmega. By the way, it would be possible use one ATtiny instade of the ATmega8U to make an USBtiny programmer cheaper and very usable, and the ISP header could be let to program any AVR.
  Am I wrong?
JChristensen
Sure, in fact an Arduino can act as an ISP programmer, in conjunction with an example sketch that comes with the Arduino IDE, see this page.
Adafruit Industries makes an ISP programmer based on the ATtiny2313 that has worked very well for me.
spycatcher2k
You could do it that way - but a programmer can be purchased from China for a few £6 / $4 / €5 - it's just not economical to build one - The uno can be used is an isp with the use of a capacitor (covered elsewhere in the forum), so expense is down to FREE if you use the capacitor elsewhere.
I build almost all my projects with the 6 pin header for reflashing the atmega, So I have 3 programmers (usbtinyisp clones), 1 in my toolbox, 1 in my home 'workshop', and one on my home-brew development board.
I also use the cheap USB to Serial converters (the dongle type) to add usb functionality to the projects that need them. (Using 2 transistor inverters or IC based inverters).
Hope this info helps some one out there in internet land.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
cborges13
The idea is not use another ISP programmer, but just the Arduino Hardware itself. All the components are there, it is just the question of connect the the USB interface (ATmega8U) to the ATmega328 and let the ISP header free to any other AVR. Some changes in the squematic will be necessary and some firmware update. The main point is save the bootloader and make the Arduino plataform more flexible. I would like to see the Arduino with the same behavior of a generic AVR ISP programmer and not need to buy one. To me, It is not nice to burn the bootloader one a virgin ATmega and have limitation of what kind of ATmega I can Burn.
With the Arduino squematic the RX and Tx of the ATmega328 are used, and the bootloader is needed. With the ATmega8U connected to the SPI and the reset pin of the ATmega328, it can be programmed as ISP. No bootloader needed and ease uploading to virgin ATmegas.
  The only reason that I see to it not to be made is commercial questions.
  If I had time I would try make this changes by myself.
  I hope you got my point.
madworm
#4
Aug 21, 2011, 01:58 am Last Edit: Aug 21, 2011, 02:00 am by madworm Reason: 1
I've had that idea some time ago as well. I think I've read somewhere that the usb2serial firmware barely fits into the currently used usb chip. To still have the use of a 5V serial port, the firmware would either have to be switchable (jumper/switch) between ISP and serial mode OR implement something like the pololu programmer, which provides 2 serial ports over just one usb cable. One fakes an ISP programmer, the other one goes directly to the main chip. That would require a bigger chip (more flash). I think the additional cost would be insignificant, but would maybe eat up the price difference to the previously used FTDI chip.
The HUGE advantage of having in internal ISP is getting rid of the auto-reset problems. Quite frankly I'm sick and tired of reading posts like "upload doesn't work" and nobody deserves to suffer from that EVIL.
However, years ago I was complaining about the lack of a jumper/switch to disable auto-reset. Only a solder-bridge was added to the newer boards back then, supposedly a jumper would have 'confused' users. So I'm skeptical if we'll see this change happen in the official boards. Maybe the folks at SeeedStudio will make it happen.
