Topic: Processing Front-End for the PID Library (Read 31113 times) previous topic - next topic
pwillard
Please consider keeping PID Library an active project.  I personally love it.
anusri
in all honesty I threw that in there to do what you are doing, but it's been a while since I've used it.  since then there's been a new version of processing, a new windows OS, and a few tweaks to the code.
the not-closing-cleanly thing is something I just plain missed.
Brett
laxman
PatrickM
Hey Everyone,
I'm desperately trying to get this front-end to work, but I keep getting the following error when I try to run it in the Processing program:
Note that release 1.0, libraries must be installed in a folder named 'libraries' inside the 'sketchbook' folder.
My "sketchbook" is defined as being in "My Documents/Processing" per the Preferences in Processing.  I created a "libraries" folder there and placed the "controlP5" folder in it.  I've also made "libraries" folders all over the place trying to get this to work.  Any idea what I could be doing wrong?
Thanks,
Patrick
novice
Hi Brett,
thanks for developing this Processing interface.  I hope to trial some PID ideas soon & I'm sure I'll use your interface.
+1
pwillard
juliandasilva
Hi, we started looking for the PID library for our robots. Did not adopted it yet, but we worked a little bit on it. We used the v06, not the FixedPoint version, which we saw later, :(.
I don't know if this may be useful, but here is the code with the small changes. Basically, added the "const" when we think it's needed, converted the getters to inlines, and with a default param in the constructor, eliminated the second constructor and the ConstructorCommon().  The only change in the interface is that the Bias is now the last param in the constructor, due to the C++ requirement that the default arguments must be the last ones).
So we compiled the three examples, and them are a bit reduced now, and the inline members must be a little faster:
- PIDSample:       5790 bytes ->  5708 bytes
- PIDSample2:       5730 bytes ->  5648 bytes
- PIDSample3:       5948 bytes -> 5826 bytes
I know it's not a lot of less bytes, but it's not only smaller, but also a little more robust (due to the const).
Here is the .h, and the cpp will be in the next post, to make this shorter:
class PID
 public:
 #define AUTO      1
 #define MANUAL      0
 #define LIBRARY_VERSION      0.6
 //commonly used functions **************************************************************************
   PID(double*, double*, double*,        // * constructor.  links the PID to the Input, Output, and
       const double, const double, const double,
       //This is truly NULL in C++ (see http://www2.research.att.com/~bs/bs_faq2.html#null):
       double *FFBias = 0);          //   Setpoint.  Initial tuning parameters are also set here
   void SetMode(const int Mode);               // * sets PID to either Manual (0) or Auto (non-0)
   void Compute();                       // * performs the PID calculation.  it should be
                                         //   called every time loop() cycles. ON/OFF and
                                         //   calculation frequency can be set using SetMode
                                         //   SetSampleTime respectively
   void SetInputLimits(const double, const double);  //Tells the PID what 0-100% are for the Input
   void SetOutputLimits(const double, const double); //Tells the PID what 0-100% are for the Output
 //available but not commonly used functions ********************************************************
   void SetTunings(const double, const double,       // * While most users will set the tunings once in the
                   const double);              //   constructor, this function gives the user the option
                                         //   of changing tunings during runtime for Adaptive control
   void SetSampleTime(const int);           // * sets the frequency, in Milliseconds, with which
                                         //   the PID calculation is performed.  default is 1000
   void Reset();                         // * reinitializes controller internals.  automatically
                                         //   called on a manual to auto transition
    * STATUS SECTION
    * These functions allow the outside world to query the status of the PID
   bool JustCalculated()
       return justCalced;
   int GetMode() const
       if(inAuto)
           return 1;
           return 0;
   inline double GetINMin() const
       return inMin;
   inline double GetINMax() const
       return inMin + inSpan;
   inline double GetOUTMin() const
       return outMin;
   inline double GetOUTMax() const
       return outMin+outSpan;
   inline int GetSampleTime() const
       return tSample;
   inline double GetP_Param() const
       return P_Param;
   inline double GetI_Param() const
       return I_Param;
   inline double GetD_Param() const
       return D_Param;
 private:
  //scaled, tweaked parameters we'll actually be using
   double kc;                    // * (P)roportional Tuning Parameter
   double taur;                  // * (I)ntegral Tuning Parameter
   double taud;                  // * (D)erivative Tuning Parameter
  //nice, pretty parameters we'll give back to the user if they ask what the tunings are
   double P_Param;
   double I_Param;
   double D_Param;
   double *myInput;              // * Pointers to the Input, Output, and Setpoint variables
   double *myOutput;             //   This creates a hard link between the variables and the
   double *mySetpoint;           //   PID, freeing the user from having to constantly tell us
                                 //   what these values are.  with pointers we'll just know.
   double *myBias;               // * Pointer to the External FeedForward bias, only used
                                 //   if the advanced constructor is used
   unsigned long nextCompTime;    // * Helps us figure out when the PID Calculation needs to
                                 //   be performed next
                                 //   to determine when to compute next
   unsigned long tSample;       // * the frequency, in milliseconds, with which we want the
                                 //   the PID calculation to occur.
   bool inAuto;                  // * Flag letting us know if we are in Automatic or not
   double lastOutput;            // * remembering the last output is used to prevent
                                 //   reset windup.
   double lastInput;             // * we need to remember the last Input Value so we can compute
                                 //   the derivative required for the D term
   double accError;              // * the (I)ntegral term is based on the sum of error over
                                 //   time.  this variable keeps track of that
   double bias;                  // * the base output from which the PID operates
   double inMin, inSpan;         // * input and output limits, and spans.  used convert
   double outMin, outSpan;       //   real world numbers into percent span, with which
                                 //   the PID algorithm is more comfortable.
   bool justCalced;              // * flag gets set for one cycle after the pid calculates
Regards,
Julián
http://robotgroup.com.ar
juliandasilva
and here is the .cpp (we deleted he function description headers because we could not paste the complete cpp here otherwise -is there an text size limite?-):
PID::PID(double *Input, double *Output, double *Setpoint,
        const double Kc, const double TauI, const double TauD,
        double *FFBias)
   SetInputLimits(0, 1023);            //default the limits to the
   SetOutputLimits(0, 255);            //full ranges of the I/O
   tSample = 1000;                  //default Controller Sample Time is 1 second
   SetTunings(Kc, TauI, TauD);
   nextCompTime = millis();
   inAuto = false;
   myOutput = Output;
   myInput = Input;
   mySetpoint = Setpoint;
   myBias = FFBias;
   Reset();
void PID::SetInputLimits(const double INMin, const double INMax)
     //after verifying that mins are smaller than maxes, set the values
     if(INMin >= INMax) return;
     //rescale the working variables to reflect the changes
     lastInput = (lastInput) * (INMax - INMin) / (inSpan);
     accError *= (INMax - INMin) / (inSpan);
     //make sure the working variables are
     //within the new limits
     if (lastInput > 1) lastInput = 1;
     else if (lastInput < 0) lastInput = 0;
   inMin = INMin;
     inSpan = INMax - INMin;
void PID::SetOutputLimits(const double OUTMin, const double OUTMax)
     if(OUTMin >= OUTMax) return;
     lastOutput = (lastOutput) * (OUTMax - OUTMin) / (outSpan);
     if (lastOutput > 1) lastOutput = 1;
     else if (lastOutput < 0) lastOutput = 0;
     outMin = OUTMin;
     outSpan = OUTMax - OUTMin;
void PID::SetTunings(const double Kc, const double TauI, const double TauD)
     //verify that the tunings make sense
     if (Kc == 0.0 || TauI < 0.0 || TauD < 0.0) return;
     //we're going to do some funky things to the input numbers so all
     //our math works out, but we want to store the numbers intact
     //so we can return them to the user when asked.
     P_Param = Kc;
     I_Param = TauI;
     D_Param = TauD;
     //convert Reset Time into Reset Rate, and compensate for Calculation frequency
     double tSampleInSec = ((double)tSample / 1000.0);
     double tempTauR;
     if (TauI == 0.0)
           tempTauR = 0.0;
           tempTauR = (1.0 / TauI) * tSampleInSec;
     if (inAuto)
     {      //if we're in auto, and we just change the tunings, the integral term
           //will become very, very, confused (trust me.) to achieve "bumpless
           // transfer" we need to rescale the accumulated error.
           if(tempTauR != 0.0) //(avoid divide by 0)
                 accError *= (kc * taur)/(Kc * tempTauR);
                 accError = 0.0;
     kc = Kc;
     taur = tempTauR;
     taud = TauD / tSampleInSec;
void PID::Reset()
   //Is myBias a NULL pointer?
     if(myBias != 0) //you can ask only if (myBias), but that's more error prone and less clear.
       bias = (*myBias - outMin) / outSpan;
       bias = (*myOutput - outMin) / outSpan;
   lastOutput = bias;
     lastInput = (*myInput - inMin) / inSpan;
     // - clear any error in the integral
     accError = 0;
void PID::SetMode(const int Mode)
     if (Mode!=0 && !inAuto)
     {      //we were in manual, and we just got set to auto.
           //reset the controller internals
           Reset();
     inAuto = (Mode!=0);
void PID::SetSampleTime(const int NewSampleTime)
     if (NewSampleTime > 0)
           //convert the time-based tunings to reflect this change
           taur *= ((double)NewSampleTime)/((double) tSample);
           accError *= ((double) tSample)/((double)NewSampleTime);
           taud *= ((double)NewSampleTime)/((double) tSample);
           tSample = (unsigned long)NewSampleTime;
void PID::Compute()
     justCalced=false;
     if (!inAuto) return; //if we're in manual just leave;
     unsigned long now = millis();
     //millis() wraps around to 0 at some point.  depending on the version of the
     //Arduino Program you are using, it could be in 9 hours or 50 days.
     //this is not currently addressed by this algorithm.
     //...Perform PID Computations if it's time...
     if (now>=nextCompTime)
           //pull in the input and setpoint, and scale them into percent span
           double scaledInput = (*myInput - inMin) / inSpan;
           if (scaledInput>1.0) scaledInput = 1.0;
           else if (scaledInput<0.0) scaledInput = 0.0;
           double scaledSP = (*mySetpoint - inMin) / inSpan;
           if (scaledSP>1.0) scaledSP = 1;
           else if (scaledSP<0.0) scaledSP = 0;
           //compute the error
           double err = scaledSP - scaledInput;
           // check and see if the output is pegged at a limit and only
           // integrate if it is not. (this is to prevent reset-windup)
           if (!(lastOutput >= 1 && err>0) && !(lastOutput <= 0 && err<0))
                 accError = accError + err;
           // compute the current slope of the input signal
           double dMeas = (scaledInput - lastInput);  // we'll assume that dTime (the denominator) is 1 second.
                                            // if it isn't, the taud term will have been adjusted
                                            // in "SetTunings" to compensate
           //if we're using an external bias (i.e. the user used the
           //overloaded constructor,) then pull that in now
           if (myBias != 0) //Is myBias a NULL pointer?
           // perform the PID calculation.
           double output = bias + kc * (err + taur * accError - taud * dMeas);
           //make sure the computed output is within output constraints
           if (output < 0.0) output = 0.0;
           else if (output > 1.0) output = 1.0;
           lastOutput = output;            // remember this output for the windup
                                   // check next time
           lastInput = scaledInput;      // remember the Input for the derivative
                                   // calculation next time
           //scale the output from percent span back out to a real world number
               *myOutput = ((output * outSpan) + outMin);
           nextCompTime += tSample;                        // determine the next time the computation
           if(nextCompTime < now) nextCompTime = now + tSample;      // should be performed
           justCalced=true;  //set the flag that will tell the outside world that the output was just computed
This should use a little less RAM too (but very very little)
Regards,
Julián
juliandasilva
Sorry, I should post the previous two posts to the http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1226431507 , is there any way to move them?
tomi__
