Topic: arduino wi-fi shield (Read 14981 times) previous topic - next topic
gustavobk
I've seen this other day:
Arduino BlackWidow from asynclabs. An arduino duemilanove with wifi baked directly on board. I'm looking forward to buy one. :)
http://asynclabs.com/store?page=shop.product_details&flypage=flypage.tpl&product_id=23&category_id=11
aequitas
novice
BlackWidow is also available at http://www.seeedstudio.com/depot/blackwidow-10-p-613.html?cPath=79_82
UltraMagnus
what module does it use?  the schematics are available, but don't name the module, which is... helpful.
dannyboyw
Do $15-20 wifi shields exist?  I like the wifi capability, but would like to incorporate a cheap barebones board and add wifi.  I like the Async Blackwidow and the new 2.0 shield, but why can't it be cheaper?  I can buy a wireless router for less!  I like how the Async products are ready to go, slick and smart, but can't we get these shields down around $20.  I have a bunch of wifi devices I want to make and play around with, but $$$!  If it was $15-20 for a shield, I would not mind doing some leg work.
What are my options?  I am surprised others are not pressing this matter.  I guess I just don't understand what is making them so expensive?
GordonEndersby
Just this afternoon I was looking up the wifi module Async use.
Its the Microchip zg2100mmc
Its available in the UK for £18.38 +vat.
http://uk.farnell.com/jsp/displayProduct.jsp?sku=1791037&CMP=KNC-GUK-FUK-GEN-SKU-DGA&s_kwcid=TC|13123|zg2100mc||S|p|6441938709
The external antenna version is available as well for the same price
I think RS components have them listed as well.
It needs 3.3v and a breakout board unless you created your own board.
Does the schematic show level shifers as well?
But Im sure you could use the Wishield libraries once you have it hooked up.
Gordon
jbeale
Looks like just a Wifi module by itself sells for about $50:
http://www.sparkfun.com/commerce/product_info.php?products_id=10004
Obviously Wifi could be cheaper, since you can get a USB WiFi adaptor under $20:
http://www.amazon.com/TRENDnet-54Mbps-Wireless-Adapter-TEW-424UB/dp/B000636JD8/ref=pd_cp_e_3
but that may depend on PC host processing for doing the protocol... The trick is how to hack that into an Arduino compatible system.  If you figure it out, let us know!
dannyboyw
Gordon - good info on the chip!
I want to figure this out.  I am not necessarily trying to manufacture/proto anything, just tech toys.  Think of the possibilities...
Yes, the drivers for the USB wifi adapter do the heavy lifting.  Don't get me wrong, Async has created the 85-90% solution, the rest is getting the price down.
GordonEndersby
Its all horses for courses.
The unit that Async use requires the tcp/ip stack to be on the microcontroller and is relatively cheap at £18.00 or so. and the stack is already built in to available libraries that you can copy from async.
The sparkfun unit has all of the TCP/IP stack onboard and you communicate via serial so all singing and dancing solution requiring very little on the microcontroller. And costs a little bit more.
again you should be able to use the sparkfun libraries for the wifly shield.
A USB based wifi solution may cost very little but a microcontroller could not implement the neccesary drivers.
Also the drivers will be proprietry and probably only available for windows. I doubt that they could be reverse engineered for the Arduino in any form.
Another solution would be an ethernet shield stacked on the arduino plugged into a cheap wifi router.
Ethernet shields are fairly cheap.
Thats going to cost more than the ZG2100 solution and more bulky hardware.
So as far as Ive worked out the cheapest solution for the Arduino would be the ZG2100 built on a prototype shield or custom Arduino board. At £18.00 plus a little bit for the other compnents I think that its a very cheap solution.
No PC in the middle or wifi router plugged in to the Arduino.
I think Ill have a go sometime to expand on my Arduino compatible board.
http://scratchpad.thisandthose.org/scratchpad/article.php?story=20100715160140327
I think it would work out cheaper than the blackwidow to build for myself.
Gordon
dannyboyw
The pics are great!  Your rig is awesome!  The detail you have investigated thus far is inspiring.  I am going to try on my uno, but ultimately I want to implement on the ModernDevice BBB (if possible).  Custom proto board for sure.  Thanks for your input!  I will feedback my findings when I finally get a chance to play.  First I need to order a ZG2100.  If they gouge on shipping, that could sink the ship.
tdufva
induino
Recently I am playing with the Asynclabs WiShield 2.0, everything works great. I need a raw TCP client socket code (just like the one with Ethernet shield) to send and receive data unlike the HTTP GET/POST which comes by default with the shield. I really appreciate if some one can point me in right direction.
GordonEndersby
@jvincent
Have a read through the examples with the library.
And the Async labs forum.
There are examples you can follow.
Gordon
