Loading...
Pages: 1 [2]   Go Down
Author Topic: SerialIP library - network access without shields  (Read 4040 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Anyone have a clue on how to do this with OS X on a mac via the usb-serial driver?
Logged
Brisbane, Australia
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Apparently the slattach command is available under OS X so I guess the Linux instructions should mostly work for Macs too, apart from the module loading part of course.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I don't get how you are supposed to connect to the arduino. I have the manager connected but what do you do to connect?
Logged
Brisbane, Australia
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Have a look on the library's wiki page and read the comments at the top of the source code for the example you're compiling.  If that still doesn't answer your questions let me know why and I'll update it.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
well in the example the setup is for linux but i'm using xp.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi there,
  I hadnt seen slip since about 1992.. yes it works like a charm hooked up to debian 5.0(under vmware fusion/OSX).
hmm I am currently looking at wrappering the telnetd/shell example to arduino and replacing the shell with bitlash(www.bitlash.net) and running the result on either sanguino(644P) or arduino Mega 1280P.
Still looking at uip sources at this point and talking to the author of bitlash about possible attachment points/glue code.
     gwen
« Last Edit: July 10, 2010, 03:51:19 am by gwen » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Logged
Georgia, USA
Offline Offline
Jr. Member
Arduino rocks
View Profile
I did a google for slip and cygwin and came up with a few hits.  I suspect there might be a way to support this on MS Windows via cygwin.  Since I only boot windows once a year to do my taxes I'm not very interested in pursuing it, but I just thought I'd suggest a possible method of getting it working on MS systems.
Jim
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Going back in time, for windows machines the old DUN 1.3 (dial up networking, below) might still work. Back in the day I ran the netmeeting video conference application between two windows machines using a parallel port data cable. I think it also had the option to run over the serial port. It had an option to connect the parallel port connected computer to the internet thru the main computer somewhat similar to the MS ICS setup.
http://support.microsoft.com/kb/191494
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Update, DUN 1.3 will only load on windows 95. I did some quick looking and some of the same features appear to exist on XP. Go to start > settings > network connections > new network wizard. Start the new connection wizard and select setup advanced connection. Then select connect allow incomming connections. An "incomming" setup will appear in the network connections. Then look at setting up ICS in the advanced setup of the LAN connections.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
