Loading...
Pages: [1] 2 3 4   Go Down
Author Topic: Dual Core 168 Arduino  (Read 1827 times)
Offline Offline
Newbie
View Profile
http://www.modxhost.com/dCore-Final.pdf
http://www.modxhost.com/dCore-IOBrd-Final.pdf
These links are not working any more ,can any one provide me the schematic and a layout of this board design by John_Ryan
check the link :http://arduino.cc/forum/index.php/topic,7894.45.html
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Looking for something like this?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
nr Bundaberg, Australia
Online Online
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Interesting, not sure about sharing the crystal but if it works...
What do you need this for?
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
In this pic from the original thread they seem to be sharing the oscillator.
http://www.modxhost.com/ass2.jpg
Maybe the solution is one is connected normally, and the other just get its input driven.
Paragraph 8.4 seems to suggest that would be viable:
"Full Swing Crystal Oscillator
Pins XTAL1 and XTAL2 are input and output, respectively, of an inverting amplifier which can be
configured for use as an On-chip Oscillator, as shown in Figure 8-2 on page 29. Either a quartz
crystal or a ceramic resonator may be used.
This Crystal Oscillator is a full swing oscillator, with rail-to-rail swing on the XTAL2 output. This is
useful for driving other clock inputs and in noisy environments. The current consumption is
higher than the ”Low Power Crystal Oscillator” on page 28. Note that the Full Swing Crystal
Oscillator will only operate for VCC = 2.7 - 5.5 volts."
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Going thru the old thread, looks only Cr0sh is still around from the posters than.
The Dual design overcome by the Mega1280 apparently.
Logged
Online Online
Tesla Member
View Profile
WWW
Quote
Yeah, that's where I was heading, just use a larger processor.
______
Rob
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Maybe a dual 1284 would be better - 2 user replaceable DIPs, "dual thread" action, 4 UARTs, 256K total memory, 64 IO.
 Cost for 2 /1284's  ($8.13) is less than a non-user replaceable 2560. ($17.97, both digikey & mouser pricing, newark $7.38/16.27).
Hmm, maybe a 1284 shield for an Arduino ...
Logged
Online Online
Tesla Member
View Profile
WWW
Yep you could easily make a shield to give "dual core" functionality, one problem IMO is that there's no really good mechanism for the two to talk. SPI is close but the crap implementation on AVRs limits that as well I think.
Anyone for dual-port RAM?
Still, as long as the tasks were not tightly coupled that wouldn't matter.
______
Rob
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
How's this one look?
http://www.cypress.com/?docID=24398
Somewhat affordable, $7.45 each.
Need to set up a preloadable, autoadvancing, 10 bit address counter on each side to allow fast burst of parallel access reads & writes.
Or tie up 23 pins on each side.
Logged
Online Online
Tesla Member
View Profile
WWW
Yeah Cypress make some really nice (and expensive) gear in this area, I'm always loved this sort of setup and used to work with a Z8000/bit-slice processor dual board, but the truth is I can see absolutely no reason to do this sort of thing these days at most levels when you can buy a 50MHz LPC 32-bit processor for $1.50. Lash out and spend $2.50 and you get 100MHz and every peripheral known to modern man smiley
______
Rob
« Last Edit: August 22, 2011, 12:14:57 am by Graynomad » Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Where's the design integration challenge in that? Now you're stuck learning some new programming language and dealing with terminating signals at RF frequencies. Might as well buy a netbook or ipad.
Logged
Online Online
Tesla Member
View Profile
WWW
I admit there's no design integration challenge, but you still use C/C++ and the high speed stuff is all internal.
I've been studying the LPCs for a project, a huge amount of grunt for a chip that's just as easy (even easier in some respects) than the typical AVR we talk about here. Frankly as far as I can see it's just the Arduino/AVRfreaks communities that make it worth using 8-bit AVRs at all.
______
Rob
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
The AVRs make it all about physical interfacing.  Writing some code is fine, but I don't want to get bogged down into a huge software project. Its bad enoough maintaining a website!
Logged
Offline Offline
Newbie
View Profile
Thanks CrossRoads ,could you also provide me the layout of this schematic.i wanna print it and make it at home  smiley
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I didn't lay it out, was reading in the old thread about how the original developers gave up on the concept after the Mega's came out.
Was thinking I'd replace the '328s with '644s. Altho looking at the parts & connecters there, not sure two 40 pins DIPs would fit.
Looks like the '328s would fit on a 80x100mm board, looks like I could replace the resistors with smaller parts, and changing the IO pins to dual-row parts instead of 2 single row parts will tighten things up too.
You serious about making this?  I normally design with 10 mil lines so I can snake 2 traces between holes if need and use 0.012" holes for vias. That gonna be a problem for home etching?
Logged
Pages: [1] 2 3 4   Go Up
Print
Jump to:
