Topic: RGB LED Shield kit now available (Read 22013 times) previous topic - next topic
Ben Combee
See http://www.youtube.com/watch?v=KDZSN7B3SsA and http://www.youtube.com/watch?v=lj_V7uFtUAA for some samples.
Patgadget
WOW thanks, as i am with DMX this look nice
Thanks
Patgadget
Montreal
seekic
mowcius
Hmphh. After finally getting round to looking at doing a laser cut cover for this (thanks easty) I realised there are no mounting holes! Arghh.
Please will everyone stick mounting holes on boards. Preferably so they line up with the ones on the arduino but for some things this is not possible/necessary.
I will be cutting a kinda bezel for it but mounting holes in any future versions would be nice :)
Mowcius
Ben Combee
I never thought about mounting holes.  Sorry!  I'm probably not going to do a revision to this one, and my next kit is designed to directly plugin to a USB port.  I'll see if holes make sense there.
mowcius
Ok ;)
Mowcius
defsdoor
I've an order placed now for 4 weeks for some TLC5940's - seems they are hard to come by in the UK :(
Ben Combee
I think they're hard to find anywhere... TI doesn't seem to be making a lot of the DIP-packaged version.  For my next kit, I'm going to use a single TLC5947 in surface mount format to drive just 8 LEDs, but it will be directly powered and controlled from a USB port and setup to stick out the back of a desktop, laptop, or Chumby to do dynamic ambient lighting.
Ill Mill
#23
Feb 25, 2010, 08:32 pm Last Edit: Feb 25, 2010, 08:33 pm by cverink Reason: 1
Yeah I looked for the TLC5940's also, seeedstudio has 13 in stock $7.90 a each. If you don't need 120mA sink, you could go with the TLC5941. Only big difference is it can only sink 80mA. They are just over $4 at Mouser.
Seeedstudio Link:
http://www.seeedstudio.com/depot/tlc5940-16channel-led-driver-weeprom-dot-correct-grayscale-p-215.html
Ben Combee
Only problem with the 5941 is that it's not available in DIP form, so it's harder for breadboard with.
Ben Combee
That's great news... when I checked TI's site I didn't see the NT one listed.
Ill Mill
Yeah I was pretty pumped when I found them. The lead times on the 40's were like 8 weeks from a lot of places. All i need them for is to control the gates on some MOSFET's so I don't need a lot of current, but I wanted the high number of channels and a dip package.
thomasthomas
Gavzzorz
