Topic: Linear Stepper motor slider mechanism or ?? (Read 4730 times) previous topic - next topic
JimiH
Hello
I've had an idea for a project which would utilize a slider that I could control its position along a x axis.
I've done some research and found out its a stepper motor with a screw feed slider mechanism.
I thought I could get one cheap but they are proving difficult to find or very expensive?
I want one with 60mm max movement from end to end.
Is this the right approach or are there alternatives?
Thanks
Geoff
mjbmikeb
How much precision is required?
Is it for a CNC milling machine or a garden watering system?
JimiH
Hi, sorry,  about +/-0.1 mm would be fine.
Cheers
Geoff
mjbmikeb
Look at the second hand machinery market. You may find something that you can pull apart and re-use.
JimiH
Thanks
I was thinking of taking an old CD/DVD rom drive apart.
Geoff
Erni
Hi
just an idea:
You coul use a standard servo with a 30mm arm, that would give you the 60 mm movement from side to side.
And the precision theoretical 60mm/1023 = 0,06 mm
JimiH
Hey thanks Erni.
That's rotary motion though isn't it? I'm after linear motion, left to right etc.
Cant believe I cant find anything out there for this.
The CD mech seems ideal but I dont think I'll get the 60mm, also trying to figure
out how to dismantle it and use it with the Arduino seems like a headache.
Maybe there is a guide out there?
Cheers
Geoff
Grumpy_Mike
Quote
I recently took apart 30 CD drives and only 8 had stepping motors in them, the rest had DC motors.
A threaded rod and a nut along with a bracket is all you need.
Erni
#8
Aug 22, 2011, 08:50 pm Last Edit: Aug 22, 2011, 09:07 pm by Erni Reason: 1
It is easy to convert the rotary motion to a linear, I tried to make a drawing. In the RC model hobby we do it all the time to move rudders etc.
You can bye kits that do the same fx.
http://www.e-clec-tech.com/lisekits.html
There are also instructions on how to make a normal servo to a linear actuator:
http://www.societyofrobots.com/robotforum/index.php?topic=10044.0
JimiH
Ahhhhh i see, looks good. might be a bit more complicated having more components in the assembly. The screw
and bracket seem like a good idea though.
I'm after the mechanism to move backward & forward about 120 times per minute. So depending on the pitch
of the screw thread this would determine the amount of rotation of the motor. I have an old CD drive lying round
somewhere so I'll dig that out and measure the pitch. I have enough to go on at the moment.
Thanks for all your help
Geoff
Grumpy_Mike
Quote
That is quite a fast thrashing about for a 60mm stroke, it think you will struggle to get this.
mjbmikeb
Find a scrap motorcycle engine with a 60mm cylinder stroke.
Remove the cylinder head and drive the crank shaft with a stepper motor.
JimiH
ok looking for a driver circuit now, what would be the best shield with two driver circuit?
Thanks
Geoff
JimiH
Thanks Mike after much research I decided on this
http://www.ladyada.net/make/mshield/
There seems to be a lot of support for this on the web and I think I'll need it.
Thanks
Geoff
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
