Topic: * MP3 Shield * - Rogue Robotics rMP3 (Read 85456 times) previous topic - next topic
bhagman
Nov 30, 2009, 07:05 am Last Edit: Jan 26, 2011, 04:05 pm by bhagman Reason: 1
We're proud to announce our rMP3 Playback Module - An MP3 Shield.
Rogue Robotics rMP3 Playback Module
Here are some specs:
  • Arduino board compatible
  • Supports MMC/SD/SDHC
  • FAT12, FAT16 and FAT32 compatible - 8MB -> 32GB
  • Plays MP3, PCM WAV, and IMA ADPCM WAV files
  • 32 -> 320 kbps bitrates supported
  • 32 -> 48 kHz sample rates supported
  • Simultaneous playback and data access
  • Serial 2400 bps to 460800 bps
  • SPI control option (soon)
  • 5 volt operating voltage
  • RoHS Compliant
  • Read and write data files as well as audio playback
MSRP: CAD$59.99 (~USD$60 - 11/01/25)
(headers are additional CAD$5.00, unsoldered)
Info available here:
http://www.roguerobotics.com/
Check our distributors for availability.
Libraries/Projects/Examples available at:
http://www.roguerobotics.com/wikidocs/code/
b
http://wiring.org.co/ - Wiring - Where Arduino came from. (Wiring begat Arduino)
http://loftypremises.com/ - Everything you wanted to know about me.... and less
http://roguerobotics.com/ - #1 Canadian Arduino distributor
bhagman
Here's an example.  Playing a song and reading lyrics from another file at the same time.
[media]http://www.youtube.com/watch?v=NY__jMV5GRE[/media]
Code and more here:
http://www.roguerobotics.com/wikidocs/code/rmp3lyrics
b
mowcius
Apart from the most annoying song example (showed the lyrics example well though), that example is good. I like the quaility of this, that is why I am drawn to it.
Yes, I can have someone's vioce on a project with the wave shield but with this I can have their voice in 320kbs!
Are the lyrics done with reading a time on the song? That is rather cool!
Mowcius
bhagman
Heh... Daft Punk can have that sort of affect on some people.
The lyrics are read off of the SD card from a standard LRC file (which has times for each lyric).
b
mowcius
Oh yes, I obviously didn't read that bit very well
:D
Mowcius
mowcius
Oh, btw. Your link is broken on the rMP3 page:
Quote
Arduino? is a trademark of Arduino Team
should link to arduino.cc presumably rather than:
http://www.roguerobotics.com/store/arduino.cc
Mowcius
bhagman
ooops... thanks mowcius.  Fixed.  (I was wondering why there was a http:// lying on the floor next to my desk).
b
bhagman
#7
Dec 18, 2009, 07:27 am Last Edit: Dec 18, 2009, 10:44 pm by bhagman Reason: 1
XMAS time...
This sketch randomly plays all the songs in a folder.  You can control the volume, play/pause/stop/next, and ff/rew using serial input (from the IDE).
Throw a bunch of your favorite holiday songs in a folder named "XMAS" on your SD card, stick it in the rMP3, and run the sketch.
I haven't got around to building a tree light sequencer to run at the same time as the songs are playing.  Maybe Grumpy_Mike will lend me his Tree-Sink.  ;D
Happy Holidays everyone!
b
Code: [Select]
#include <RogueSD.h>
#include <RogueMP3.h>
#include <NewSoftSerial.h>
NewSoftSerial rmp3_serial(6, 7);
RogueMP3 rmp3(rmp3_serial);
RogueSD filecommands(rmp3_serial);
int numberOfSongs;
int lastSong;
char path[96];
const char *directory = "/XMAS";
 Serial.println("Merry Xmas!");
 rmp3_serial.begin(9600);
 rmp3.sync();
 rmp3.stop();
 filecommands.sync();
 // mix up our random number generator
 randomSeed(analogRead(0));
 // get the number of songs available
 strcpy(path, directory);
 strcat(path, "/");
 strcat(path, "*.mp3");  // we have to do this because the IDE thinks that "/*" needs to be terminated everywhere
 numberOfSongs = filecommands.filecount(path);
 lastSong = -1;
void playNextSong()
 uint8_t i;
 char filename[80];
 char path[96];
 int nextSong = 0;
 if (numberOfSongs > 0)
   // Select our next song randomly
   if (numberOfSongs > 2)
     do
       nextSong = random(numberOfSongs);
     while (nextSong == lastSong);
   else if (numberOfSongs == 2)
     // we only have two songs
     if (lastSong == 0)
       nextSong = 1;
       nextSong = 0;
   // now, get our file name from file list
   filecommands.opendir(directory);
   for (i = 0; i <= nextSong; i++)
     filecommands.readdir(filename, "*.mp3");
   strcat(path, "/");
   strcat(path, filename);
   rmp3.playfile(path);
   Serial.print("Playing: ");
   Serial.println(path);
   lastSong = nextSong;
   Serial.println("No files to play.");
 char c;
 uint8_t i;
 int16_t newtime;
 playbackinfo playinfo;
 char status = 'S';
 uint8_t playing = 1;
 uint8_t volume = 20;
 uint8_t boostOn = false;
 volume = rmp3.getvolume();  // this only gets the left volume
 playNextSong();
 while(1)
   while(!Serial.available())
     // we should do fancy stuff like flash lights on our Xmas tree here!
     // got lots of time!
     delay(200);
     status = rmp3.getplaybackstatus();
     playinfo = rmp3.getplaybackinfo();
     if (status == 'S' && playing)
       playNextSong();
   // OOH!! got a character!
   c = Serial.read();
   switch(c)
     case 'p':
       // pause
       if(status == 'D')
         // fade in
         rmp3.playpause();
         rmp3.fade(volume, 400);
       else if(status == 'P')
         // fade out
         rmp3.fade(100, 400);
         rmp3.playpause();
         // start playing
         playNextSong();
         playing = 1;
     case 's':
       rmp3.stop();
       playing = 0;
     case 'n':
       playNextSong();
       playing = 1;
     case 'e':
       if(boostOn)
         rmp3.setboost(0);
         boostOn = false;
         rmp3.setboost(8, 6, 7, 3);
         boostOn = true;
     case 'a':
       // jump back 5 seconds
       newtime = playinfo.position - 5;
       if (newtime < 0) newtime = 0;
       rmp3.jump(newtime);
     case 'd':
       // jump forward 5 seconds
       rmp3.jump(playinfo.position + 5);
     case 'k':
       if(volume < 254) volume++;
       if(status != 'D') rmp3.setvolume(volume);
     case 'i':
       if(volume > 0) volume--;
mowcius
Quote
Now it's getting interesting. (to be honest I probably should have read through the page in more detail)
This is definitely on my list and I may be able to get one soon if I get my other stuff free for sparkfun free day or I have to buy it...
Mowcius
Lazarus404
#9
Apr 07, 2010, 10:01 pm Last Edit: Apr 07, 2010, 10:02 pm by Lazarus404 Reason: 1
Hey Brett,
I'm currently trying to use the rMP3 shield with the DFRduino LCD Keypad shield. The problem is, while rMP3 uses digital pins 6, 7, 8, 11, 12 & 13, the LCD shield uses 5, 6, 7, 8 & 9. Therefore, I'd like to reroute pins 6, 7 & 8 to use pins 3, 4 & 10 by cutting the jumpers and wiring them up. So far, so good. The problem I have, though, is that I can't seem to work out how I'd let the C compiler know of the change. There aren't any obvious locations in the C file or associated header and I can't see any mention of this in the documentation. Could you please give me a clue as to how I would do this?
Thanks,
Lee
mowcius
Does it really use all those pins?
I have not really delved into how it does what it does but I presumed that it just could use those other pins.
Isn't the communication via serial? In which case it would require 2 pins?
Also another question, I know that the LED on board (activity LED) flashes when music is playing and seems to brighten at corresponding points in the music. Is there any easy way to get audio values sent to the arduino so a visualiser could be done from it?
A bit more documentation would also be very nice :p
Mowcius
Lazarus404
I think the documentation is actually pretty good. I wish there was a support forum, tho ;-)
bhagman
Lee - The rMP3 only uses 2 serial pins to communicate.  The SPI port is there as an optional way to control the rMP3, but the current version of firmware (100.01) hasn't got that implemented (expect it in the next version).
You figured out how to do the serial change though.  Just cut the jumper at pins 6 (rMP3 TX) and 7 (rMP3 RX), and reroute the pads to the new pins you want to use.  (make sure you connect wires to the pads FURTHEST of the two from the Arduino header).
The change in the code should be really simple.  Wherever you see:
Code: [Select]
change it to (in your case):
Code: [Select]
NewSoftSerial rmp3_serial(3, 4);
(I'm assuming that you changed pin 6 on the rMP3 to pin 3, and pin 7 to pin 4).
If that doesn't work, post your code and we can see what's going on.
mowcius - sounds like either you're listening to a VBR mp3 file (wide range one too!  32 kbps -> 320 kbps) and the music has really quiet and really loud spots, or your eyes are fooling you!  The data goes directly from the card to the decoder.   So, the only effect you'd see is if the MP3 frames had different bitrates.
RE: documentation, our wikidocs have always been public, unfortunately you had to register.  I've changed it now so that you don't have to register.  Just add any comments/questions you have on any page that has a discussion.
b
Lazarus404
Thank you, Brett, that's awesome news. Having only two pins to worry about makes my life easier ;-)
Best,
Lee
mowcius
Quote
I was indeed! I hadn't noticed that it didn't change with non VBR files. It was only on the loud bits that I got brighter flashes...
Any chance you could do the Input/Output Interface page on the wiki? :)
The rest of the documentation does indeed look good, it has been a while since I have looked and I suppose I did not have a great look through.
I have just gone through and had a thorough read! Interesting stuff!
Now back to my previous question :)
Quote
It is not a problem if not, it would just be interesting to do it without all the extra circuitry it usually requires.
Mowcius
