Loading...
Pages: 1 ... 10 11 [12] 13   Go Down
Author Topic: DuinOS: small and simple rtos  (Read 16867 times)
0 Members and 2 Guests are viewing this topic.
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks.
Saw you were working on v0.3.  Any ETA on that?  Need help testing?
Logged
Argentina
Offline Offline
Full Member
Sé feliz
View Profile
WWW
mmm, sorry, not ETA yet, but working.
With kind regards,
Julián
http://robotgroup.com.ar
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello,
Where can I find more examples of DuinOS? All that I could find is MoreComplexBlinking and MoreComplexBlinkingAndSound.
Thanks!
Logged
0
Offline Offline
Newbie
Querer es poder!!!
View Profile
Hello!
I am trying to develop a Clock for Arduino using DuinOS. The idea is to use a task in order to manage the system time while others task are running.
To set the clock, it is used an UNIX format, for example: T1291036511. Where "T" is a special char to identify the UNIX time. We give the unix time to the system using the serial connection.
When I put the unix time in the serial port, the system goes very slow... and it freezes.
Here is my code (based on MoreComplexBlinking):
Code:
#include <Time.h>
#define TIME_MSG_LEN  11   // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER  'T'   // Header tag for serial time sync message
#define TIME_REQUEST  7    // ASCII bell character requests a time sync message
#define INITIAL_GREEN_DELAY  200
#define NEW_GREEN_DELAY  20
int ledPinRed =  8;
int ledPinGreen =  9;
unsigned int greenDelay = INITIAL_GREEN_DELAY;
boolean redLED_isOn = false;
boolean greenLED_isOn = false;
//Forward declaration, to let redLED call to resumeTask(greenLED). It's not necessary if we put the greenLED
//itself here, but declareLoopTask may be usefull in more complex situations:
declareTaskLoop(greenLED);
declareTaskLoop(clock);
taskLoop(redLED)
  static unsigned char counter = 0;
  if (!greenLED_isOn)
     if (counter >2)
       resumeTask(greenLED);
     counter++;
  redLED_isOn = true;
taskLoop(greenLED)
  static unsigned char counter = 1;
  digitalWrite(ledPinGreen, HIGH);  // set the LED on
  delay(greenDelay);
  digitalWrite(ledPinGreen, LOW);  // set the LED off
  delay(greenDelay);
  if ( (counter >= 9) && (greenDelay != NEW_GREEN_DELAY) )
    greenDelay = NEW_GREEN_DELAY; //now, after 10 blinks, accelerates
  if (counter >= 99)
    //Reset vars, so next time, if the task is resumed, it executes all again:
    counter = 0;
    suspend();      //After a while, the tasks suspends itself (forever)
  counter++;
taskLoop(clock)
  if(Serial.available() )
    processSyncMessage();
  if(timeStatus()!= timeNotSet)
    digitalWrite(13,timeStatus() == timeSet); // on if synced, off if needs refresh
    digitalClockDisplay();
// The setup() method runs once, when the sketch starts
  // Initialize the digital pins as outputs:
  pinMode(ledPinRed, OUTPUT);
  pinMode(ledPinGreen, OUTPUT);
  setSyncProvider( requestSync);  //set function to call when sync required
  Serial.println("Waiting for sync message...");
  createTaskLoop(clock, HIGH_PRIORITY);
  createTaskLoop(redLED, NORMAL_PRIORITY);
  createTaskLoop(greenLED, LOW_PRIORITY);
  //This initializes the main loop's with a different priority (default is LOW_PRIORITY):
  //initMainLoopPriority(NORMAL_PRIORITY);
  //Try this and see what happends:
  //suspendTask(redLED);
// This is the main loop() method, wich runs over and over again,
// as long as the Arduino has power. Is a LOW_PRIORITY taskLoop:
  if (redLED_isOn)
    digitalWrite(ledPinRed, LOW);  // set the LED off
    delay(25);                      // The OS can be tested reducing these delays, and seeing how both LEDs work together...
    digitalWrite(ledPinRed, HIGH);   // set the LED on
    delay(25);
    digitalWrite(ledPinRed, LOW);  //  LED is off
    //If nextTask is not called, the application will not hang, because the OS is preemptive. BUT, the current task
    //will consume a lot of computational resources (due to it's lack of a delay() in this branch), the application will
    //turn slower, and the other tasks may be affected by this, loossing precision in their timing:
    nextTask();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
void processSyncMessage() {
   // if time sync available from serial port, update time and return true
  while(Serial.available() >=  TIME_MSG_LEN ){  // time message consists of a header and ten ascii digits
      Serial.println("Serial.available");
    char c = Serial.read() ;
    Serial.print(c);
    if( c == TIME_HEADER ) {
      time_t pctime = 0;
      for(int i=0; i < TIME_MSG_LEN -1; i++){
        c = Serial.read();
        if( c >= '0' && c <= '9'){
          pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
      Serial.println(pctime);
      setTime(pctime);   // Sync Arduino clock to the time received on the serial port
time_t requestSync()
  Serial.print(TIME_REQUEST,BYTE);
  return 0; // the time will be sent later in response to serial mesg
« Last Edit: November 29, 2010, 08:03:28 am by kerbero » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I know it seems counter intuitive, but did you try putting delay() functions by the serial commands.
I been working on a DuinOS project all weekend.  The serial.print functions gave me allot of trouble, but for some reason if I put delays right after or before the serial commands the trouble went away.
I wondering if it caused by the Content switching and interrupting the serial functions.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
This seems very interesting! Did anyone get it to work with the Mega2560?
Thanks!
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Nice initiative!
Logged
France
Offline Offline
Newbie
Arduino rocks
View Profile
Hello,
I have translated the DuinOS 's wiki in french at http://robotgroup.com.ar/duinos/wiki/index.php?title=Main_Page-FR
and I have updaded several english wiki page and added several useful links in the DuinOS wiki.
I hope this will useful for the Arduino community.
Regards.
Yannick
Logged
Argentina
Offline Offline
Full Member
Sé feliz
View Profile
WWW
Many thanks!
Great Idea!
I think we will have to translate to Spanish then smiley
Regards,
Julián
Logged
France
Offline Offline
Newbie
Arduino rocks
View Profile
I'm working on DuinOS 0.3 Alpha.
I have checked all the changes in DuinOS 0.2 and I have reported them on DuinOS 0.3.
Now in this Alpha DuinOS 0.3 release, I have made :
- update to FreeRTOS 6.1.0
- update to Arduino IDE 0021
With DuinOS 0.3, I have compiled the following exemples without problems :
Does somebody have any idea where I can upload the 0.3 release for downloading by users for testing ?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I'm happy to provide with some webspace for the download on a personal hosting, I'll contact you via PM.
Thanks
Stijn
Logged
France
Offline Offline
Newbie
Arduino rocks
View Profile
@Stijn
I think that I will contact Julian DA SILVA to allow me to commit my changes at http://code.google.com/p/duinos/.
It will be more useful for all community (get source code and show diff changes, download the latest release for the users).
Logged
Argentina
Offline Offline
Full Member
Sé feliz
View Profile
WWW
Sorry, I did not see the replies before.
Of course, please feel free to commit to the Google Code repository. We have created that this year but did not announced it yet.
Regarding the mprintf, please check my previous question to Paula and her kindly answer in entries 5, 6 and 7 of this blog:
http://www.out--there.com/blog/the-devil-is-in-the-details-atmega-startup-to-freertos/
We are cooking new software (don't say nothing yet, it's a graphical programming environment, but shhh) to be released as soon as possible, so DuinOS were not receiving our full attention. I'm really happy that you have ported it to the 0021 and the new FreeRTOS core.
By other hand, we were working along the 2010 on a lot of things, and one of them is testing core that we called the 0Warning Experimental Arduino Core, or just the 0W.  It's here:
http://code.google.com/p/0w-experimental-arduino-core/
We just implemented it with the 0019 version, but it's quiet easy to do the same job for the 0021 version. We have no time now, but were planing to integrate the DuinOS Core with this. It's NOT TESTED AT ALL, but when compiled with Code::Blocks, it has 0 warnings, against the 42 warnings from the original 0019 version (we don't know if the 0021 has some of them, because did not check it).
But for DuinOS v0.4 it will be nice to have it 0W too! Don't you think?
Oh, something I was forgetting. If someone is interested, please find with the 0W core, the following files:
CPPLib.h
CPPLib.cpp
Those add the new() and delete() operators, (with very common and well known iplementations) and the function that allows to have virtual pure destructors.
I'm happy to of having feedback again!
Kind regards, and thanks for all your work!
Julián
Logged
France
Offline Offline
Newbie
Arduino rocks
View Profile
To DuinOS users,
I have updated DuinOS source code for DuinOS 0.3 release in the next weeks (maybe before christmas 2010, I don't know) .
You can get it by svn here
http://code.google.com/p/duinos/source/checkout
We need someone who has an Arduino Mega2560 for testing.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
That's great news!
Are the incompatibilities here still an issue?
http://www.multiplo.org/duinos/wiki/index.php?title=Tracker#Incompatibility_issues_with_Arduino_libraries
Logged
Pages: 1 ... 10 11 [12] 13   Go Up
Print
Jump to:
